Question about Campbell Hausfeld 26 - Gallon Air Compressor
Should I upgrade my pressure regulation on my hausfeld 26 gallon
Looks like the regulation is shot. It wont shut off by switch and it stays on till the overpressure blows. I have always been unhappy with the compressor because it didn't have enough volume to run a lug wrench. Should I look into getting a bigger bore pressure switch?
Thanks!
Remove the pressure switch and look for oil inside it, where it senses air pressure. Also may just be burn't contacts. Clean them with Wet&Dry paper.
Your compressor is TOO Small on the CFM side to power high volume air tools, like a cut off wheel,air chisel or your impact gun ,if you use it too long.
It's not tank volume,it is the compressors ability to make air quicker than you use it, and at a steady 100# or more,none stop.
The only real fix is a very large single stage unit or the best is a two stage. Those two options are expensive.
Posted on Apr 29, 2010
My 5hp 13 gallon compressor won,t run when you turn it on there is no wind nothing at all how do i bypass the switch and hook it direct
you don't connect it up direct unless you want to destroy the compressor and burn the motor out
check for a reset or thermal overload button if it just shut down when over pressured
replace the pressure control switch is the best fix after checking out the motor condition
Jul 04, 2017 | Campbell Hausfeld 26 - Gallon Air...
I have a campbell hausefield vs series air comp and when it reaches full air supply and shuts off air leaks (alot) out of the switch i replaced and nothing changes.
There is a check valve on the tank where the line from the pump goes to. It should also have a smaller line running to the pressure switch. If the valve or spring inside is broke or stuck it will leak as you describe. You need Campbell Hausfeld part number CV221502AJ.
Dec 22, 2010 | Campbell Hausfeld 5HP 26 Gallon Single...
Electric compressor motor problem
Unloader valve on switch. That switch is not bleeding off cylinder head pressure,when it shuts off.
Apr 06, 2010 | Campbell Hausfeld 26 - Gallon Air...
I have a 26 gallon campbell compressor elec. Problem is runs fine for a min. then shuts off and on every couple of min does not get to max psi
REPLACE THE PRESSURE SWITCH BUDDY THESE CAN BECOME FAULTY WHICH IS THE CASE OF THIS PROBLEM BUY THEM ON EBAY FOR CHEAP THE PRESSURE SWITCH CONTROLLES YOUR ON AND OFFF AND STOPING PRESSURE SO THAT HAS GOT TO BEE THE PROBLENM OR TRY AND TAP IT A BIT TO MAKE IT WORK
Oct 21, 2009 | Campbell Hausfeld 26 - Gallon Air...
25 gallon air compressor wont shut off,changed air regulator
You have a valve plate problem . It could be a slipped "o" ring to a bad reed valve. There are rebuild kits for that purpose. The kits include a valve plate assembly. It covers all the bases. When you look at this area pay attention to the partitions of the head gasket/"o"ring. You may avoid the cost of the kit.
Feb 25, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I have a 33g craftsmans air compressor oilless
have a 26 gallon air compressor , changed regulator switch but it still wont shut off
Feb 22, 2009 | Craftsman Air Tools & Compressors
Adjust PSI
The compressor does not get over 40 psi. It simply does not pump over that.
Aug 31, 2008 | Campbell Hausfeld 26 - Gallon Air...
Campbell Hausfeld 26 - Gallon  Air Compressor Logo
102 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
