Lost papers for bike computer - Computers & Internet
    President:
  • 2,351 Answers
Somewhere on the device is the name & model no#
Post it here....
Posted on Mar 25, 2008
SOURCE:
I lost the keys to my bike so I wired n a new ignition bike turns over but don't start
The key and switch are programed together if it is computer controlled , and sets a new code every time it is removed.
Feb 23, 2015 | Motorcycles
Build dates
Hi, Probably not, normally build dates are in weeks and years. Therefore your bike was built in week 12 of 2009, this would be March 16 to 22. Sorry a 2010 bike she ain't, your rego papers are correct
Jan 28, 2014 | 2010 Husqvarna TE310
I lost my yamaha r15 bike key
I had the same problem with my ZX10R losing the master key to which all other keys need to be coded from and I am assuming that Yamaha might use a very similar system in which the key gives off a signal that is picked up from your bikes electrical system even before the key is placed into the key barrel if your key is not chipped and is a regular type key then one can be cut fairly simple or replace the key barrel with a new one and set of keys . But if you have lost the master key that codes all other keys for your bike then it can become a very expensive job running into the thousands of dollars easy because replacement of the security system that is integrated into the whole bikes computer and electrical system is a very complex and expensive system to replace . There are key coders that you might be able to use costing a few hundred dollars instead of thousands of dollars and without the need to replace your bikes whole security system as well as people that offer the service to recode your keys depending on the difficulties of your system . You will need to start looking on youtube for methods or devices or people that offer that type of service and start by searching for lost key transponders or key codes and then finding out if your system is compatible and can be given a new code and set of keys hopefully this will be the case because there isn't much of away around other than the very expensive total system replacement of your bikes security system . I have lost my master key and can not get any replacements cut and I have lost nearly all of the copied spare keys that were originally coded from the master key so I have attached a key permanently hidden on my bike that the transponder can pick up as a signal and I use a normal key to fit in and turn the key barrel as normal without the fear of losing the coded key , as well adding a few anti theft devices of my own like a hidden cut off switch , disc brake lock with alarm etc so I can make key copies at any key cutting place for a few dollars .
Nov 28, 2013 | Yamaha YZF-R15 Motorcycles
Lost key honda
you should take that with rego papers and id to your honda dealer and he should be able to cut one for you.hope this helps
Sep 26, 2013 | Honda CB 500 Motorcycles
Lost my ignition key how do I remove the ignition or can I have a lock smith make a key
get the serial number off the bike and bring it with you ownership papers to a kawi dealer and they can order you a new key. Cheaper then replacing the ignition.
Aug 28, 2011 | 2001 kawasaki ZX-6R Ninja
MY SIGMA 1009 COMPUTER SCREEN SHOWS 0 MPH WHILE RIDING.SEEMS AS THOUGH IT IS NOT TRANSMITTING ANY INFO. SOMEDAYS IT WORKS PERFECTLY.
You want to make sure the magnet on the front wheel is being picked by the receiver on the fork. Sometimes that magnet attached to the spoke will move on the spoke so that it no longer closely passes by the receiver. If the magnet has been lost, check with you can check with your local bike shop for an extra.
Feb 26, 2011 | Sigma Sport BC 1009 STS Wireless Computer
I brought a relaigh cordless cycle computer i think its a 12 function one for my old bike but now i want to put it on my new bike but my new bike has different wheels sized 26x1.50 but i have lost the...
26 inch wheel becomes 29 inches when you add on tyre depth ( 1.5 * 2 )
29 x Pi is 91 inches
Computer setting should be 91.2 inch or 2316 mm
Nov 29, 2010 | Cycling
I bought gta 4 and lost most paper with the serial number
If you have lost all purchase receipt and pertinent papers, try your luck by going back to the store where you bought it and ask if they could provide you with a serial number. If not, then you can just buy another license. Remember, software piracy is illegal and would get you into trouble.
Apr 03, 2010 | Video Game Consoles & Games
Computer needs to be set up need instructions
Here is the manual in adobe pdf format for you to view and/or print.
http://planetbike.com/files/8001and2manual.pdf
Good Luck!
Apr 06, 2009 | Planet Bike Protege 8.0 Bike Computer
After I removed a paper jam, it seems my computer has lost my printer. Now the (IN Use/Memory) keeps flashing. It will only print a blank sheet of paper, because the computer can't find it. It is a...
It appears I lost you in Live Chat, at any rate based on the information you have provided, I can only determine there was a hardware malfunction, possibly caused by the jame and the unit most likely needs to be serviced, sorry I could not be of more help.
Thanks
Feb 27, 2008 | Computers & Internet
Open Questions:
-\&;-WINDSTREAM Customer Support Phone Number #{+ I:8OO-828-O294 }.U.S.A This windstream USA phone number is ranked #2 out of 2 because 7,728 windstream USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the windstream USA Customer Support department for problems like Where to buy, Complaint, Customer support, Repairs, Returns. As far as we can tell, windstream USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. windstream USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact windstream USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling windstream USA Calling windstream USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from windstream USA Customer Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with windstream USA's Customer Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare windstream USA's phone numbers against each other. Contacting windstream USA in General While I8OO8280294 is windstream USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach windstream USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact windstream USA.
Oct 16, 2019 | Best Computers & Internet
AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr
Oct 16, 2019 | Computers & Internet
Computers & Internet Logo
26 people viewed this question
Ekse
Alun Cox
