Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Pool pump timer
I don't know how to set the timer it's the one with the round yellow wheel and to timer settings on and off one is silver the other one is gold
  • 565 Answers
Pull the yellow clock dial out, then turn it either direction until the correct time is lined up with the pointer, then push it back in. Turn the thumb screw on the trippers counterclockwise to loosen them, position them where you want them, then tighten them up. The gold is OFF and the silver is ON.
Posted on Apr 30, 2010
Key not in use
Yellow is the color to let you know that there is power to the pump, witch allows the pump to run according to your predefined start up settings. If you turn the power to the Pump off, the yellow light goes out, and after 72 hours, you will lose your pre determined startup settings.
Apr 19, 2014 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Pool pump clock
T104M used WG1573 clock motor:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
The timer mechanism has metal gears, while the clock motor has plastic gears. If the metal gears get dirty and bind, it will strip the plastic gears.
Turn off power, pull timer out of box, Clean out timer with compressed air, and spray WD40, add a bit of white grease to lever where trippers make contact, then replace clock motor ... and buy another set of trippers to have on-hand since they are designed to wear down so timer will last longer.
If timer body is broken so dial does not rotate, then buy new T104 and snap new mechanism into old box. Buying whole T104 with enclosure is cheaper than buying T104M mechanism only.
May 15, 2013 | Pool & Spa
Hi, last month we bought an intex round pool (18' x 54") with sand pump and salt sanitizer. Within the last 2 days the water started turning green. It turns out my husband accidently set the pump...
You don't want to swim in water that has algae... 1st ...Make sure you have the correct amount of salt. See you manual for amount needed. Must set you pump timer first and sync your chlorinator between that time, if pump turns off before chlorinator cycle ends, you will get an "Low flow" alarm. Set you pump timer to run 12 hours and the chlorinator for 10 to 11 of those hours and should see results within 3 days or so. After that, If you live in an area that is hot, 10 hours pump and 8 to 9 chlorinator... Hope this helps...
Jul 13, 2011 | Intex Automatic Salt Water System for ...
There is a silver pin that fits into the periphery of the timer. I think this trips the smaller dial to rotate. If the sprinkler is set to go off at 4am, where should I place this silver pin for it to...
You have Intermatic sprinkler timer.
The silver pin inserts into the yellow dial at 12:00 midnight, and it rotates the skipper wheel.
Skipper wheel is necessary only if you want to skip certain days of the week, otherwise the timer cycle repeats each 24-hour period.
To skip a day, the skipper pin is pushed down for that day. Leave skipper pin up for days you want to water.
Open following links for more information:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
Jun 24, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I'm hooking this up to a pool,quickset 10x30. this is not working for me help.......
What exactly are you trying to do?
Please explain in detail. For example, (I'm trying to connect the pool pump to the timer and set the pump to run 12 hours per day, on for an hour off for an hour, but I don't know how to to set the pins.)
So the more information you can provide the easier it'll be to help you achieve exactly what you're requesting.
Jun 05, 2011 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
How do you set the days that you want the system to operate ?
R88 series timers at Intermatic.
Click on model number to see manual:
http://www.intermatic.com/products/timers/mechanical%20time%20switches/sprinkler%20irrigation%20timers.aspx
Add a comment if you have different timer
At fixya, we're not supposed to copy-paste from manual, but manual says information clearly.
If timer has the day-skipper wheel located lower left of large yellow dial:
Not every timer has day-skipper wheel, in which case timer works same for each day.
TO SKIP DAYS: Turn black skipper wheel COUNTER-CLOCKWISE
until today's day is in front of "14" arrow. Press pins DOWN on days
of NO watering. The skipper wheel must have all pins UP for daily
watering.
Additional instructions:
1. TO SET FIRST ZONE: For watering, push gold pin into slot on yellow
dial at desired ON time. For each 12 minutes of additional watering
add one pin WITHOUT skipping a slot.
2. TO CHANGE ZONES: Leave one blank slot on yellow dial after ON
line (gold pin), and valve will automatically advance to next zone.
3. TO SET ADDITIONAL ZONES: Repeat steps 1 and 2. REMEMBER
to leave blank space between zones
4. TO SET TIME OF DAY: Turn yellow dial CLOCKWISE, until correct
line is at end of silver time pointer. Do NOT turn silver pointer.
5. TO SKIP DAYS: Turn black skipper wheel COUNTER-CLOCKWISE
watering.
6. PUT SELECTOR SWITCH IN AUTO: This switch can be used to turn
the system ON or OFF for manual operation without affecting the set
program.
Nov 24, 2010 | Intermatic R8816P101C -...
How do you set the pool timer
WITH 2 OR THREE FINGERS GRAB THE YELLOW DIAL LIKE A HOCKEY PUCK YOU ARE TRYING TO PICK UP OFF A TABLE.. OK PULL OUT ON THE YELLOW DIAL AND SET THE TIME IT IS NOW TO THE SILVER POINTER , THIS ALLOWS THE DIAL TO MOVE FREE ETHER WAY. NOW IF YOU LOOK CLOSE AT THE LITTLE POINTERS ON THE EDGE OF THE YELLOW DIAL YOU CAN SEE ON ON ONE AND OFF STAMPED IN ON THEM, SIMPLY LOOSEN SCREW A FEW TURNS AND IT WILL SLIDE AROUND RIM, SET THE ON TO THE TIME DESIRED TO START UP (PUMP,WATER HEATER,SPRINKLER) AND THE OFF A FEW HOURS LATER "HOW LONG YOU NEED" (DIAL TURNS TO THE RIGHT).. YOU CAN MARK DOWN THE SPOT WHERE YOU HAVE IT SET AT NOW ! AND COME BACK TO CHECK ON PROGRESS IN A HOUR OR TWO .. HELPED YA ? VOTE .. JAY
Jun 08, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
2010 Easy Set 2500 Gph Swimming Pool Filter Pump (): ok we have the 24 by 52 in intex metal frame pool ...
88 It is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process. On the filter set it to run atleast 1 hour longer than you SWS. set the timer on both at the same time.
May 18, 2010 | Intex 2010 Easy Set 2500 Gph Swimming Pool...
HOW DO I SET TODAY MONDAY, SO THE PUMP WILL START ON WEDNESDAY? I PUT MONDAY IN FRONT OF 14 ARROW AND PULL THE PIN OUT FOR WEDNESDAY BUT AS ALL PINS PASS ON YELLOW DIAL TO GET TO WEDNESDAY AND THE 12 MIN....
http://waterheatertimer.org/images/R8806P101C-timer-778.jpg
1) The silver pin goes at 12 midnight on large yellow dial. This pin advances the skipper wheel each day.
2) Turn yellow dial clockwise until current time lines up with silver pointer.
3) Rotate skipper wheel counter-clockwise until today's day (Monday) is in front of 14 arrow.
4) To skip a day of watering, the skipper pin is pushed down for that day. So you want to push down Monday and Tuesday.
For watering, the skipper pins is up for that day. So you want The skipper pin up for Tuesday.
5) The brass trippers are inserted on yellow wheel. Each brass tripper represents 12 minutes of watering for example. So if you want to water for 1/2 hour, then put two consecutive pins on the yellow timer wheel. For 1 hour, put 4 consecutive pins.
May 17, 2010 | Intermatic R8806P101C -...
I have an old pool timer. How to set it?
yes there should be 2 tab on the wheel one for off one for on set the wheel to the correct time by pulling it up which is printed on the wheel. then set the tabs to your desired time.
Jul 10, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
81 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
