Question about M2K Garfield: It's All About Math Math (Ages 7-9) (GRF16AM201) for PC
What is p(even or prime) for a single die roll
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 146 Answers
Even numbers = 2 , 4 , 6
Prime numbers = 3, 5
there fore total probability of getting either even or prime number in single die roll = 5/6
Posted on May 27, 2010
Am I in my prime years?
30 is not old, if you want kids and you are single but have a stable job and home environment look into adoption.
Jan 04, 2017 | Pregnancy
I was driving my chevy 1500 and it died and does not seem to be getting any gas
if truck was made after 1988 its sure to have some sort of PCU module and the later types even will tell you exactly why it wont run , but you'll need to hook up a code reader to see what the problem is , but a owner can diagnose some things themslefs , just by using there good hearing .
start by turning key to run not start listen !! did you hear fuel pump prime in tank ?? then shut off this is telling you fuel pump ckt is ok may take several times to hear it
crank engine over listen to fuel injectors click on engine top (takes two people) injectors actually click as they are opened for fuel ?? a old paper towel roll tube held to your ear helps to hear
Aug 05, 2016 | Cars & Trucks
I have a 2008 FLHTC,I start it up take off go about 30 feet it dies no power roll a foot or so power on roll agin power off Trouble codes P1511 & P2101 Please HELP.
Hi Anonymous, what does Harley know, you are now mind melding with the master, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable especially the "NEGATIVE" cable where it bolts to the frame.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below. Good luck and have nice day. xlch@mail.com
Jul 01, 2015 | 2008 Harley Davidson FLHTC Electra Glide...
Sthil bg 86 blower prime bulb work but blower dies try prime again nothing it put pressure in tak
It could be starving for gas at high rpm.
Check the plastic gas lines between the gas tank and the carburetor.
Replace if even the tiniest crack.
Aug 06, 2014 | Stihl Genuine Sthl Bg 86 Leaf Blower...
My 2005 harley sporster 1200 keeps on stalling after an hour or so of riding. the odometer goes first then it putters for a bit and dies. and when i try to restart i can't even get it to roll over
Hi Sa_larade, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections check negative cable at both ends. (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
7. Security alarm not disarming
For a prime suspect please visit website below and good Luck.
Harley Davidson Sportster error codes and how to access them
Apr 15, 2012 | 2005 Harley Davidson XL 1200 C Sportster...
It will start out with a good flow then will not pump any water even though it is keeping its prime.
You have some debris floating around somewhere. If you are pumping from a pond or a rain-barrel, you might have debris clogging the inlet. Or maybe you have a stone in the impeller - if your outlet is on top of the impeller a stone will sink to the bottom so you could have flow initially, but the stone would be carried up to clog the outlet within a few seconds. Or you might have stone in the hose feeding into the impeller - that stone could roll back down the hose even though you don't loose prime.
Jun 28, 2010 | Flotec 1 - 1/2 Sprinkler Pump Composite...
What is the probability of rolling a even number or a prime number on a number cube? write fraction in simplest form
even nos: 2,4,6
prime nos:2,3,5
ie 1 is the only no. which is not desired
probability of getting one=1/6
hence probability of getting either even or prime no is
= 1-1/6 = 5/6
Apr 07, 2010 | M2K Garfield: It's All About Math Math...
2006 tri. scrambler somtimes stops running,as if ran out of gas but has half tank. will start 10 minutes later.
check which setting your gas petcock is on, reserve / run / prime, check it with all these settings, either some **** in there or rubber inside is crumbling.
Nov 26, 2009 | Triumph Scrambler Motorcycles
Car will not start
For clarification:
When you turn the key to start, the engine will not roll over?
When you turn the key to the run position, do you here the fuel pump prime, a humming noise from the gas tank?
Have you replaced any other electronic components, key cylinder, body control module?
Let me know.
Regards,
Apr 11, 2009 | 1998 Buick LeSabre
M2K Garfield: It's All About Math Math (Ages 7-9) (GRF16AM201) for PC Logo
241 people viewed this question
Top M2K Computers & Internet Experts
k24674
Terry Hair
WilliamMcCaffrey
WilliamMcCaffrey
Level 1 Expert
Are you a M2K Computer and Internet Expert? Answer questions, earn points and help others
