Instructions for assembling trac pipe fittings
  • 20 Answers
Tip
Arihant Pipe Fittings Hastelloy Pipe Fittings
used to connect two pipes. The connection provides a firm bound to the pipe which ensures mechanical and structural strength to hold the equipment. It also ensures the free flow of liquid in the process. Arihant Fittings Hastelloy Pipe Fittings are of high resistance. Our products are tested under the highest of pressures to ensure a very high pressure sustainability. All of our hastelloy pipe fittings manufactured are subject to an impeccable surface finish. We are likewise promised to quick conveyance of hastelloy pipe fittings and try to provide same day delivery of all products. The hastelloy Pipe Fittings are manufactured to sustain very high pressure and product warranty. The leading manufacturer of hastelloy pipe fittings, ARIHANT FITTINGS represents considerable authority in the assembling and supplying of top notch pipe fittings and valves for framework designing arrangements. We trust that the items we produce and the designing arrangements we give are a piece of the achievement of our clients and essential in guaranteeing the well being of the individuals who work with these segments in high-risk conditions. Security in all workplaces is our significant concern.
on Nov 16, 2016 | Miscellaneous
How do I remove a fuel tank from a 2004 Buick Rendezvous
First of all, there is a recall for gas tank replacement for your vehicle. The dealer will replace it free. The link will get you to the document in PDF form
Redirect Notice
It looks like there is a bracket on one end of the tank hidden by a heat shield
FUEL SUPPLY SYSTEM Fits Buick Rendezvous
Feb 08, 2015 | 2004 Buick Rendezvous
How do you remove a crank assembly from a Star Trac 6430 recumbent bike
Here are the instructions from Star Trac:
http://support.startrac.com/documents/docs/635-4007A.pdf WebRepOverall ratingThis site has no rating(not enough votes)
Jun 10, 2012 | Cycling
How to assemble a DP Fit for life dual trac 20
dp trac 20 weight lifting mechine how can i assemble
Dec 18, 2011 | Cars & Trucks
Trac star 4500 have a message el stl what does mean
I'm a technician for StarTrac. Visit my website to learn more about me and my company. Contact me directly and I'll give you what ever free advice I can offer. I'd love to help if you don't mind passing on the good word.
Brian Clark (or Christine Reid)
No Assembly Required Fitness Equipment Repair
www.wefixfitnessequipment.com
Oct 20, 2010 | Startrac Fitness Products Star Trac 4500...
How do i remove the top console where the compass is located in a 2003 ford sport trac
It is really easy to do. If you have a sunglasses holder (or a compartment overhead) open it and remove the 2 screws in the compartment. That should be it, from there just gently pull the assembly away from the roof, there are 2-4 clips holding the assembly in place. From there remove the main wiring harness and you are good to go. I have removal instructions with pics at www.autoclockrepair.com
Sep 25, 2010 | 2003 Ford Explorer Sport Trac
How do i remove gas tank
NOTE Always maintain cleanliness when servicing fuel system components.
  1. Relieve the fuel system fuel pressure.
  2. Drain the fuel tank.
  3. Raise the vehicle.
  4. Disconnect the fuel tank wiring harness connector at the body pass through.
  5. For 3.4L engines, disconnect the quick-connect fitting at the inlet side of the in-pipe fuel filter.
  6. For 3.4L engines, disconnect the quick-connect fitting on the fuel return pipe, near the fuel filter.
  7. Disconnect the fuel tank evaporative emission (EVAP) pipe quick-connect fitting near the fuel filter.
  8. Remove the fuel feed, the fuel return, and the EVAP lines from the fuel pipe retainer.
  9. Remove the retaining nut for the EVAP canister bracket.
  10. Loosen the fuel tank filler pipe hose clamp.
  11. Disconnect the fuel tank filler pipe from the fuel tank.
  12. For 3.5L engines, disconnect the EVAP vent pipe near the fill pipe hose.
    NOTE Do not bend the fuel tank straps. Bending the fuel tank straps may damage the straps.
  13. With the aid of an assistant, support the fuel tank and remove the fuel tank strap attaching bolts.
  14. Remove the fuel tank from the vehicle and place the fuel tank in a suitable work area.
  15. If the fuel tank is not being replaced, go to the Installation Procedure.
  16. Disconnect the fuel tank wiring harness from the fuel sender assembly.
  17. Remove the fuel sender shield from the fuel tank.
  18. Disconnect the fuel feed and return pipe quick-connect fittings at the fuel sender.
  19. Disconnect the EVAP vapor pipe assembly from the fuel sender.
  20. Remove the fuel and/or EVAP pipe assembly from the fuel tank.
  21. Remove the fuel sender assembly.
  22. Remove the EVAP vent solenoid valve.
  23. Remove the EVAP canister.
To install:
  1. Install the EVAP canister.
  2. Install the EVAP vent solenoid valve.
  3. Install the fuel sender assembly.
  4. Install the fuel and/or EVAP pipe assembly.
  5. Connect the EVAP vapor pipe to the fuel sender assembly.
  6. Connect the fuel feed and fuel return pipes at the fuel sender.
    NOTE Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  7. Install the fuel sender shield to the fuel tank and tighten the shield nuts to 53 inch lbs. (6 Nm).
  8. Connect the fuel tank wiring harness to the fuel sender assembly.
  9. With the aid of an assistant, position and support the fuel tank.
  10. Install the fuel tank retaining strap attaching bolts and tighten the fuel tank retaining strap bolts to 35 ft. lbs. (47 Nm).
  11. Install the EVAP canister retaining nut and tighten the retaining nut to 53 inch lbs. (6 Nm).
  12. Connect the fuel tank filler pipe to the fuel tank and tighten the fuel tank filler pipe hose clamp to 22 inch lbs. (2.5 Nm).
  13. Connect the fuel feed pipe quick-connect fitting at the inlet side of the fuel filter.
  14. Connect the fuel return pipe quick-connect fitting near the fuel filter.
  15. Connect the fuel tank EVAP pipe quick-connect fitting near the fuel filter.
  16. Connect the fuel tank wiring harness connector at the body pass-through.
  17. Lower the vehicle.
  18. Add fuel and reinstall the fuel tank filler pipe cap.
  19. Connect the negative battery cable.
  20. Inspect for fuel leaks with the following procedure:
    1. Turn ON the ignition for 2 seconds.
    2. Turn OFF the ignition for 10 seconds.
    3. Turn ON the ignition.
    4. Inspect for fuel leaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 15, 2010 | 2001 Pontiac Aztek
I cannot remove the caliper carriage to remove the front rotors on my 05 sport trac
There should be two (2) fairly large hex-head bolts on the back side of the hub assembly. Spray the bolts with some WD-40 (taking care not to get any on the other parts of the braking system. Use an extension handle (small piece of pipe) over the handle of your 3/8 inch rachet. This should provide you with enough leverage to break free the retaining bolts. Make doble sure the socket you use fits over the bolt head very snuggly, otherwise you could cause rounding of the bolt head and make the job twice as difficult. Alway try using a SAE socket, and then try a Metric socket to see which one fits better. Many US manufactured cars are using metric bolts in these applications. It's only a 2005, so they should break free with a bit more leverage than the short rachet handle. I personally use the pipe that comes as a handle on my small hydraulic jack, but any pipe will suffice.
Apr 21, 2009 | 2005 Ford Explorer Sport Trac
Heating & Cooling Logo
189 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
