Question about ASUS SCB-2424V-U CD-RW/DVD-ROM (Combo) Burner
I lose the Cd with the drivers of SCB-2424V-U how can I get it to install? thanks
  • 185 Answers
The website won't allow to send direct link but from here you can access the firmware download and then you can use any program to burn cds i.e. Nero, Roxio, DVD plus, etc.
select your OS, device model: Optical Storage Slim Combo SCB-2424V-U
it will show 3 files 2 are manual 1 is firmware
if it works don't forget to rate me
thx
Posted on Apr 29, 2010
Phone code for spice scb 04
i want spice battery scb-05 for QT-50 mobile handset
Sep 16, 2012 | Cell Phones
Jeep grand cherokee 2.7 crd I have a problem about code p0243 thans for your help.
DTC P0243 - Turbo/Super Charger Wastegate Solenoid A
Description: Open or shorted condition detected in the turbocharger wastegate solenoid control circuit.
Here is the flow chart for that code (some images could need to clicking for zoom)...
P0243-WASTEGATE PRESSURE CONTROL PWM
For a complete wiring diagram Refer to Section 8W.
When Monitored: When the ignition is on.
Set Condition: The ECM detects an open or short circuit in the Wastegate solenoid circuit.
Possible Causes
DAMAGED WIRING HARNESS OR CONNECTORS
WASTEGATE SOLENOID
(F504) FUSED IGNITION SWITCH OUTPUT OPEN
(K139) WASTEGATE SOLENOID DRIVER CIRCUIT OPEN
(K139) WASTEGATE SOLENOID CIRCUIT SHORTED TO GROUND
(K139) WASTEGATE SOLENOID DRIVER SHORTED TO VOLTAGE
(K139) WASTEGATE SOLENOID DRIVER CIRCUIT SHORTED TO ANOTHER CIRCUIT
ECM
INTERMITTENT CONDITION
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 9 - ENGINE - DIAGNOSIS AND TESTING)
Diagnostic Test
1. DAMAGED WIRING HARNESS OR CONNECTORS
Turn Ignition off.
Disconnect the ECM harness connectors.
Disconnect the Wastegate Solenoid harness connector.
NOTE: Check connectors - Clean/repair as necessary.
Are any wires or pins damaged?
Yes
Repair or replace any damaged wire or connectors.
Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL).
No
Go To 2
2. WASTEGATE SOLENOID
Reconnect the ECM harness connector.
Reconnect the disconnected Wastegate Solenoid harness connector.
Turn the Ignition on, engine not running.
Connect an incandescent test light across the supply and driver pins at the Wastegate Solenoid harness connector.
NOTE: The ECM will perform a self check of the circuit after approximately 30 seconds, which should light the incandescent test light.
Does the light illuminate brightly after 30 seconds of being connected?
Yes
Replace the Wastegate Solenoid.
No
Go To 3
3. (F504) FUSED IGNITION SWITCH OUTPUT OPEN
Connect an test light between the Wastegate Solenoid connector Fused ignition switch output circuit and battery negative.
Compare the test light brightness to that of a direct connection to the battery.
Does the light illuminate brightly?
Yes
Go To 4
No
Repair the open (F504) Fused Ignition switch output circuit.
4. (K139) WASTEGATE SOLENOID DRIVER CIRCUIT OPEN
Measure the resistance of the Wastegate Solenoid driver circuit between the Wastegate Solenoid harness connector and the ECM harness connector.
Is the resistance less than 10 Ohms?
Yes
Go To 5
No
Repair the open (K139) Wastegate Solenoid control circuit.
5. (K139) WASTEGATE SOLENOID CIRCUIT SHORTED TO GROUND
Measure the resistance of the (K139) Wastegate Solenoid driver circuit between the Wastegate Solenoid harness connector and battery negative.
Yes
Repair the (K139) Wastegate solenoid circuit shorted to ground.
No
Go To 6
6. (K139) WASTEGATE SOLENOID DRIVER SHORTED TO VOLTAGE
Measure the voltage between the (K139) Wastegate Solenoid driver circuit at the Wastegate Solenoid connector and battery negative.
Is the voltage less than 1 volt?
Yes
Go To 7
No
Repair the (K139) Wastegate solenoid driver shorted to voltage.
7. (K139) WASTEGATE SOLENOID DRIVER CIRCUIT SHORTED TO ANOTHER CIRCUIT
Measure the resistance between the (K139) Wastegate Solenoid driver circuit in the ECM harness connector and all other circuits in the ECM harness connectors.
Yes
Repair the (K139) Wastegate solenoid circuit shorted to another circuit.
Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL). (Refer to 9 - ENGINE - DIAGNOSIS AND TESTING)
No
Go To8
8. WASTEGATE SOLENOID
Yes
Refer to the INTERMITTENT CONDITION Symptom (Diagnostic Procedure).
No
Replace the ECM.
Keep us updates.
May 04, 2011 | 2003 Jeep Grand Cherokee
WEB CAM CD LOSE
install driver genius 2007 then connect ur cam & select the drivers u want to download
please vote for me
May 23, 2009 | Logitech Webcam
Failure to install Realtek HD Audio
hi..there... are you sure using the correct mainboard cd installation for this one? 'cause example : if your mainboard brand is asus you can't using cd driver installation from foxcoon. it's not mach driver progam..
better you check again your mainboard brand and type is same with cd installation or not. if you losing your cd installation you must looking for it or download it from your mainboard website by typing your mainboard brand and type ( EX; driver ASUS P5P800 )
Feb 02, 2009 | ASUS P5P800-MX Motherboard
My cd printer is lose?
Do you mean lost?
If it is lost, here is a link for all the drivers for your printer.
http://support.lexmark.com:80/perl/support/support.cgi?ccs=229:1:0:572:0:0
Select your operating system and download and install the drivers and software.
Dec 29, 2008 | Lexmark X1240 All-In-One InkJet Printer
For my webcam
lo please I have proplem.I chang my windows after I cant use the webcam also I lose the CD for the webcam pc camera driver please u can help me to install agine thank so match
Oct 19, 2008 | Creative Labs WebCam Live!
Benq Dc 1300
Hi Have lost my BenQ Dc 1300 driver Cd and now i need de Software Thanks
Jul 29, 2008 | BenQ DC1300 Digital Camera
Driver cd is losed
It is highly recommended to always set a system restore point before installing a device driver. This willhelp if you installed a wrong driver. Problems can arise when yourhardware device is too old or not supported any longer.
Here is the link :
http://www.driver-central.com/Gemini_D16_4.30_Windows_98Me2000XP-20443-7382-driver.html
Jul 22, 2008 | Computers & Internet
ASUS SCB-2424V-U CD-RW/DVD-ROM (Combo) Burner Logo
48 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
