Question about Pioneer PD-M423 CD Player
Where does the cables from the cd player connect to.
    Brigadier General:
  • 8,546 Answers
Depends on the capabilities of the device you're connecting it to.
Typically, the analog Audio Out RCA cables would go to any corresponding Line Level input; the coaxial- or optical-digital audio would go to any compatible connectors on the receiving unit.
Posted on Apr 29, 2010
How do I connect my NAD cd-player?
If you have a receiver with a digital rca input, buy a good quality coaxial cable and connect it from the digital output of you cd or dvd player. The digital/analogue converters inside the receiver are almost always better than the ones in the cd player. If running cd to a stereo receiver, just use a good quality pair of rca interconnect cables. Red is right, White is left.
Jun 09, 2016 | NAD Audio Players & Recorders
94 Honda Prelude Factory Car Stereo/CD Player
The BUS wires are a serial data link, probably incompatible with other makes of CD player. I'd hesitate to connect it to +12v, this may cause damage. If anything try connecting it to BUS.C through a 1kohm resistor to start with.
Perhaps you need something like this to make it work. http://www.caraudiocentre.co.uk/product_m-alpine-kcm-122b_p-20941.htm
Oct 21, 2007 | Car Audio & Video
03 chevy silverado aftermarket cd player
Maybe the sudden shock when connecting cable blew out the in-line fuse
Jun 16, 2013 | Cars & Trucks
Mp3
The problem is that a CD has a stereo signal and the Marshall is mono.
You could make a simple mixer cable with resistors as a completed cable is not something you will find easily.
Take three 1K resistors joined at one end and connect the open ends of those one each to the three terminals of a stereo plug that fits you CD player.
Connect a mono plug and cable with "hot" to the joined connection of those resistors. Connect the ground shield of that cable to the barrel connection of the stereo plug that one of the resistros is also connected.
NOTE: if you use the "line" output of the CD player, then use 10K ohm resistors instead of 1K.
May 06, 2010 | Marshall 15 Watt Guitar Amp
I want to wire a subwoofer and amp to player
1. cd player connection, audio out (stereo) rca cable
2. from cd player rca cable, connect it to amplifier audio in (stereo).
3. speaker output wiring connection going to spkr. box.
Apr 16, 2010 | JVC FS-2000 Shelf System
I just bought some speakers and a receiver, cd player no instructions, how do i connect it myself
- Use a cinch- cable (red&white) to connect the cd player to the input (often called CD or AUX) of the receiver
- Use standard speaker cable (two copper wires per wire) to connect each speaker to one speaker-output on the receiver
- Plug in the power cables
- Select the right input (or source) on the receiver
- Voila! Press play on the cd player and sound should come out!
Oct 08, 2009 | Audio Players & Recorders
Movie has no red color only green and yellow
Remove & re-seat the component video cables at both the TV and the DVD player.
If the problem continues, disconnect BOTH ends of the BLUE cable and the RED cable. Connect the BLUE cable to the RED jack at both the DVD and TV, and connect the RED cable to the BLUE jack ob both the TV and DVD. If the RED color comes back and the BLUE is missing, then replace the RED cable (the red cable is broken and will not pass the signal that it is connected to).
If all works, reconnect the colored cables to the corresponding colored jacks at both the TV and DVD player.
If the RED color still won't display, isolate the trouble to either the DVD player or TV by connecting the DVD to another TV w/ component jacks. If the RED is still missing, it is a problem inside the DVD player - if the RED displays, it is a problem with the TV.
Sep 30, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
I need help connecting sony dvp ns 300 to a jvc tv. I can't watch dvd at all, confused about the wiring where does it go?
The CD/DVD player has three output ports:
(i) Line out Video used to connect the yellow pin of composite cable.
(ii) S-video out use d to connect an S-video cable.
(iii) Component video out (red, blue, green) used to connect a component video cable.
So, in order to connect the CD/DVD player to the TV, the TV should have either of the corresponding input port on it.
However, the video quality transmitted by component video cable will be the best among the three.
So, you may connect the TV and the CD/DVD player using an appropriate cable.
All the above connections require an additional audio cable to transmit audio from the CD/DVD player to the TV.
In this case, you may use an RCA (red and white) audio cable to connect the "R and L" audio out port on the CD/DVD player to the corresponding "R and L" audio in port on the TV.
Performing all the above steps will help you get the DVD player work with the TV.
wish u good luck!!!!!!!!!!
Sep 17, 2009 | Sony DVP-NS300 DVD Player
Connect a CD Player to the Peavey XR600 Amp
go to radio shack and get1-3-ft. radioshack gold series RCA A/V CABLE NUMBER(15-3030) OR(15-3031) IT DEPENDS TO DISTANCE BETWEEN PLAYER AND AMP.(ANY AUDIO CABLES WILL SOLVE THIS PROBLEM BUT GOOD QUALITY MEANS BETTER RESULT.
Nov 26, 2007 | Audio Players & Recorders
Pioneer PD-M423 CD Player Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
