Question about Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super Capacity Plus Gas Dryer - White-on-White
The drum on my whirlpool duet wont spin - Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super Capacity Plus Gas Dryer - White-on-White
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryerThe drum on my whirlpool duet wont spin - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 03, 2010
2 Suggested Answers
lenwest
  • 150 Answers
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Posted on Jan 30, 2009
My dryer made a loud bang and wont spin
Bridgette, Most common problem is a broken belt when dryer drum dose not turn. Look through the attached links to help diagnose and repair your dryer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Dryer Drum Not Turning
Whirlpool Dryer Drum Not Turning
Appliance Repair Forums
Duet Dryer Drum Belt part 661570 How To Replace
Jul 17, 2016 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Tighten belt on duet whirlpool front loading washer
There is no adjustment for the belt of WP front load. If you hear loud noise when the drum is spinning because the drum bearing was loosen. If you have insurance cover tell them to replace. Else, a cost of repair is expensive.
Oct 20, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool duet sport makes a terrible noise during spin cycle like drum hitting something or belt slipping. There are no error codes or smell of burning belt. HELP!!
the drum bearings are shot,you need to get them replaced,if the drum is actually hitting the sides if the tub this could be a broken spider thats on the rear of the inner drum that holds the drum on if this comes loose it can cause serious personal injury
May 29, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool dryer front loading wont turn the drum i change the control board but still wont work .
did you check the belt to see if it's broke,the belt raps around the drum and the motor,when the motor turns on and spins the belt spins the drum.
Mar 28, 2011 | Whirlpool Duet Front Loading Dryer Rack...
My whirlpool duet washer make a loud banging sound during spin - louder when it goes into super spin
It sounds like the spider or support arms that hold the wash drum have failed and the drum is hitting the wash tub when it is spinning. Try spinning the inner drum by hand and listen for any thumping sounds as it turns. Also examine how it turns, if you notice that is wobbles as it turns, it also means that the supports are failing.
It can be fixed but it might be expensive. Get a few estimates before deciding to repair or replace. Hope this helps you.
Dec 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet makes an awful banging noise when a load of laundry is in the spin cycle. It is completely level and I cannot figure it out.
reach inside drum that turns and try to move it up and down. If there is any movement the spider at the rear of the drum is broken. Will need inner drum and outer rear tub with bearing and seal.
Nov 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150PW1 very noisy when spinning
its most likely bad bearings and basket. usually it happens over wear and tear or overloading.
May 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washer, Clicking noise during spin cycle
i would open the door nad with your hand (glove on if preferred), feel around the intereior of drom for prhaps a nails, or hair clip that has gotten caught in one of the many holes in tub
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Ghw9150p wont spinr
you cleaned out the filter in the pump assambly??? and did you also check inside the throat of the impellar for possible obstruction?its possible that the pump is not pumping(although its on) and not removing water would result in no spin
Dec 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super Capacity Plus Gas Dryer - White-on-White Logo
151 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
