Question about Frigidaire GLTF2940ES Front Load Washer
What is error 20 on frididaire gallery washer? Clothes just sitting not moving at all?
  • 299 Answers
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Posted on Apr 29, 2010
HOW DO I TAKE BOOTOM BURNER OUT FRIDIDAIRE GALLERY CFES 388REB1
Hello rdbal - Most bake and broiler elements are typically held into place with 4-6 screws or fit(s) in a bracket like connection and then needs to be screwed down. However every unit is different so please contact a professional to move accurately for more information due to safety and liability reasons.
Nov 11, 2012 | Frigidaire Gallery GLEFM397DS Electric...
Frididair gallery series. would like to know how
There is one screw down the center of the adjitator, after removing the screw you pull straight up, sometimes brut force is needed.
Sep 05, 2010 | Frigidaire GLWS1439F Top Load Washer
Replace the belt on our Frididaire Gallerie Series 9/09. It now does not spin when there is a full or heavy load (towels). If it does the belt comes off. Is this a belt problem or the pulley? Thank...
Make sure your belt tensioner is mounted correctly. The belt should be tight enough that it takes a good 10 to 15 pounds of pressure (a good tug) to move it. But the belt should not deflect more than two inches either way. It really sounds like you tensioner.
Aug 19, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a frididaire front load washer, and lately I have been seeing hole like spots on my white or light clothes what is the problem
Check door boot at tub. sometimes is ripped. also check your dryer...at the drum to front panel....felt could be worn and will cause clothes to catch.
Jun 10, 2009 | Frigidaire GLTF1670A Front Load Washer
Washer is extremely loud
defective back bearing and spin basket..onthejob
Feb 03, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Error messages
what are other codes? i believe this could be a cold water issue. check your screens at the fill hoses
Sep 22, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Error 20 AEG washer dryer
On 40c wash hit E20 error so moved programme onto long spin and all ok!
Jan 09, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Laundry tub
The problem is detergent spotting, do the hottest wash for several occasions and add a cleaner descaler preferably two mugs full of washing soda. Regards Advisor
Aug 23, 2007 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire GLTF2940ES Front Load Washer Logo
270 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
