Question about Phoenix Gold Octane-R 10/10d Car Subwoofer
I have a Phoenix Gold Octane Amp and 10d subwoofers. My friend took it out last week, and I want to put it back it, but I can't figure out where the power and ground wires go and where the speaker wire coming from in the car goes.
    Scholar:
  • 111 Answers
Ok, when you look at the amp, the power + and ground - will be on one side of the amp with another smaller opening in between them. That opening is for your remote wire from your radio. Without that, your amp will not receive the input voltage to signal it to turn on. The speakers will go into the remaining open holes. Your RCA wires will be on the opposite end of the amp.
Posted on Apr 30, 2010
I don't know if I burnout my subwoofer neon how can I test if it is realy burn out????
tHE EASIEST WAY IS TO CHECK YOUR COILS WITH A dmm DIGITAL MUTI METER IF ITS A 2 OHM SUBS COILS SHOULD BE VERY CLOSE TO THAT AND VICE VERSA WITH FOR OM=HM SUBS. IF THE COILS HAVE A NO READING OR A VERY LOW READING CHANCES ARE ITS COOKED.
Aug 06, 2011 | Phoenix Gold Octane-R 10/10d Car Subwoofer
Need a box for a 97 f150 2door so how big does the box got to be for two r10d
you need to look into your manual and see the required box size recommendations then you can work from there.if you dont have a manual look one up they are out there
Feb 21, 2011 | Phoenix Gold Octane-R 10/10d Car Subwoofer
I just got 2 phoenix gold octane r 10" subs and i was wondering what kind of box and how big it needs to be
YOUR MAUAL SUGGEST PROER BOX SIZE FOR THE SUBS. IF YOU DONT HAVE ONE LOOK ONE UP ONLINE SORRY MAN CAPS STUCK.
Jun 30, 2010 | Phoenix Gold Octane-R 10/10d Car Subwoofer
Phoenix Gold Octane R 15:0.1
Go take a look at www.rodinaudio.com; go to contact info and call PG direct.
Aug 14, 2008 | Legacy 2CH 800W AMP Car Audio Amplifier
Amp problem, need help!!!
Sounds like one of two problems: either your subs are beginning or have gone bad, or you amp is going bad. What size power and ground wire are you using? You should be using at least a 4 gauge for both. Also what impedence are you running with the amp, ie; 4ohm mono, 2ohms stereo, etc?
Jun 19, 2008 | Phoenix Gold Octane-R 4.0:2 Car Audio...
Please help
That depends on what impedence the subs are. If they are 4 ohms each then just parallel them to the amp + to + and - to - on both of them that will give you a 2 ohm mono load which is fine for that amp.
May 31, 2008 | Phoenix Gold Octane-R 5.0:1 Car Audio...
Amp connection
Parallel would be the best way to wire them. 2 4 ohms subs to one channel wired parallel would be a 2 ohm load for that channel and if u wire them series then 2 4ohm subs to one channel would be an 8 ohm load for that channel.
May 31, 2008 | Phoenix Gold Octane-R 15.0:1 Car Audio...
Hook up
Click for Manual
If you look closely in the manual (zoom in), there is an R under the word Power. It's the remote turn on.
B- is ground.
Apr 12, 2008 | Phoenix Gold Octane-R 4.0:2 Car Audio...
Wiring diagram
The LEd wires need a wire run from the speaker to the Fuse block in your car. The small Red wire from the LED will be the one that hooks to Swtiched 12 Volts supply on the fuse block so that your Led Turns on when you turn the keyswitch on. The Black wire goes to ground, or to a metal part of your cars body, probably the same point where your Amp is Grounded.
The Octane R10 is a Single Voice Coil or SVC.
AMP+ to Sub+
Amp- to Sub -
Use 12 guage wire.
Nov 07, 2007 | Phoenix Gold Octane-R 10/10d Car Subwoofer
Phoenix Gold Octane-R 10/10d Car Subwoofer Logo
134 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Mark Skinner
Jose Velazquez
Jose Velazquez
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
