Question about Wurlitzer Jukebox CD Player
Rowe Jukebox Model R-93
Older Rowe Jukebox Model R-93 with attached 6 cd changer. Lost the settings when replacing the battery in the control panel. Need to know how to reprogram it.
    Scholar:
  • 195 Answers
I suggest that you get a manual from www.victoryglass.com if you do not already have on, all the instructions for setting up the CCC will be in the manual.
Regards
Alan Hood
ami-man
Posted on Apr 29, 2010
  • mike ladowitz Mar 24, 2011
    test
    alan i have a rowe ami r93 it gave me an error #36 and i put it in tto service mode and typed 699 to reset and now it doesnt play please advise thanks
Rowe Nostalgia jukebox will only play a few of the numbers of the 100 cd;s. Is there anyway to reset it so it will play all numbers?
You will need to go into the programming section on the menu.
I suggest that if you do not have a manual that you obtain one from Rowe Ami, Victory Glass or distribution.
Have you initalised all of the CD's on your jukebox? Every time you replace a CD you have to initalise it.
Regards
Alan Hood
ami-man
UK
Jan 31, 2010 | Wurlitzer Jukebox 1015 One More Time...
I've owned an Antique Apparatus CD-91 counter model CD jukebox for more than 15 years, and it's only been used in homes. Around 8 years ago, I started to have a problem where the CD, once place on the...
Hi Nick,
If you still have this problem I would contact Bruce Wentworth in the USA, listed below are his details.
Regards
Alan Hood
ami-man
UK
Bruce Wentworth A&B Jukebox Repair 56 Old County Rd. Plaistow NH 03865. A&B Jukebox Repair specializes in the repair of Rowe circuit boards in Rowe ...
www.abjukeboxrepair.com/
Jan 18, 2010 | Pioneer PD-F1007 301-Disc CD Changer
Have lost key and need to replace right side bulb on wurlitzer 1015 cd one more time
If the lock is a standard lock for the model of your jukebox then you should be able to get a replacement from the distributor.
Look on the back of the jukebox for a serial number plate. This will tell you the manufacturer and the model number etc. The jukebox could be a Wurlitzer, Rowe Ami, Rock Ola or Antique Apperatus.
Once the details are known you could get a key from www.victoryglass.com in the USA.
Regards
Alan Hood
ami-man
UK
Nov 12, 2009 | Wurlitzer Jukebox 1015 One More Time...
How do I slow the speed of the 45s on my rowe r-92 jukebox .The records are playing a little too fast
The turntable motor on the jukebox range of R-84 to R-93 is none adjustable.
If you are in the USA then the motor operates on 60hz but in Europe it would have to be on 50hz to do this a different pulley is used.
The Rowe Ami part numbers are as followes:-
30791907 Turntable Motor Assembly 60hz
30791908 Turntable Motor Assembly 50hz
21817801 Motor Pulley 60hz
21817802 Motor Pulley 50hz
These can be ordered from a Rowe Ami dealer or you could try www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Oct 28, 2009 | Wurlitzer Jukebox 1015 One More Time...
Rowe Jukebox CD-100E. When I turn it on the
AT THIS TIME YOU ARE NOT SURE IF THE PROBLEM IS IN THE LASER ASSEMBLY, OR THE AMPLIFIER?
BORROW OR RENT, AN AMPLIFIER HOOK IT UP TO THE OUT PUT ON THE LASER OUT PUT ON THE LASER CD OUT PUT. LOOK AT LASER UNIT IT HAS A MARKING ON IT THAT SAYS AUDIO OUT PUT. PUT CABLE TO A SECOND AMPLIFIER.
THAT WAY IF IT STILL FADES. THEN THE CD LASER IS THE PROBLEM . IF THE SOUND IS GOOD THEN THE AMPLIFIER IS AT FAULT
DOCTOR FIX IT
Oct 23, 2009 | Wurlitzer Jukebox 1015 One More Time...
Need to get wurlitzer jukebox working
Place a help request on the following jukebox forums, you will need the jukebox makers details (Rowe Ami, Wurlitzer, Rock Ola or Antique Apparatus etc) and the model number and what fault you have.
www.phonoland.com
www.jukeboxmadness.com
www.arcadecontrols.com (go to message board and then jukebox)
Regards
Alan Hood
ami-man
UK
Jun 16, 2009 | Wurlitzer Jukebox 1015 One More Time...
Song Programming
With regards to your problem with the Rowe Ami 100 cd jukebox.
Do you have a manual, if not I suggest you buy a printer manual or one on CD and refer to the Programming and Installation section.
In order for the jukebox to know about the cd's that are installed in the jukebox it has to initialize all or the changed cd's that have been replaced within the jukebox.
Put the jukebox into the Service Mode (the service mode should appear on the display)
Type 3 to select the Initialize sub menu
Type 0 and full initialize will appear on the display
Press Popular to start the initialization
Place the jukebox service switch into the normal mode
Initiazation will take around 30 minutes to complete.
Regards
Alan Hood
ami-man
Jan 05, 2009 | Wurlitzer Jukebox CD Player
Does not hold memory of programmed options
I do not know what type of jukebox you have but the the battery will be in the Central Control Computer, this is the case with the Rowe Ami version of your jukebox. It is a 3 volt lithium (disk type) battery.
Regards
Alan Hood
ami-man
UK
Nov 29, 2008 | Wurlitzer Jukebox 1015 One More Time...
Rowe jukebox
I take it that the jukebox accepts selections when you type them in. Also that you have tried selecting the A side and the B side records.
Is the switch on the CCC (Central Control Computer) set to Record it should not be set to Video.
Rowe Ami jukeboxes are very pone to dry (cold in the USA) joints.
If you can solder then the following items need to checked for dry joints.
Power Supply PCB (printed circuit board)
CCC
Mechanism Control Board
When taking out the plugs pull on the plugs (not the wires)
Look on the soldered side where the connectors pins are fitted for any cracking around the soldered joint ( this is the sign of a dry joint).
Resolder any suspect joints on all of the boards and refit into the jukebox and test.
If this does not cure the problem then the boards will be needed to be sent to a Rowe Ami specalist, I am one of these in the UK.
Regards
Alan Hood
ami-man
UK
May 30, 2008 | Wurlitzer Jukebox 1015 One More Time...
Open Questions:
See all Wurlitzer Jukebox CD Player Questions
Wurlitzer Jukebox CD Player Logo
932 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
