Question about Sharp Projector lamp Projector Lamp
Sharp projector turns on and then cuts off right away - any ideas
Projector was working but then we moved it and it now will power on but then clicks off right away?
  • 563 Answers
Hi there
First take out the lamp and check for any signs of damage.
If you can't see anything check the Ballast ( Lamp's powersupply )
Posted on Mar 26, 2008
What to do with a image that is cut off?
Hi Anonymous,
Most of the time, when an image is cut off the problem is coming from the source.
I assume you are using a computer connected to the projector? Try using different resolutions in your computer's settings. If you are using Windows, right click on your desktop (away from any icons) and go to screen resolution to make the changes.
I hope this helps!
Mendtronix
Projector Lamps Projector Bulbs Projector Parts Projector Repair Servcie
Jun 03, 2014 | Epson PowerLite 3LCD Projector
I have a sharp notevision DLP xr10x projector. Two red lights, one is the lamp, the other standby/power. I changed the lamp but nothing changed. I can't even turn the thing on. Any ideas?
Hi Stephen,
Do you hear any fans starting when you turn on the projector? Try unplugging and then plugging in the projector. Make sure that the lamp door is secured as the projector will not start if it is loose. You should also reset the timer for your projector. The manual can be found on the site of www.allprojectorlamps.com.
Nov 04, 2013 | Sharp Notevision PG-C45X Multimedia...
My acer aspire one notebook is not connecting projector (Sharp XR-50s). Please suggest me what adjustments has to do in my laptap. Thanks Saibaba B.S
Hook up computer to projector AFTER projector is turned on. Power on.
Right click on your desktop
Click on Graphics Options
Click on Output To
Click on Intel (R) Dual Display Clone
Click on Notebook + Monitor
Aug 24, 2010 | Acer Aspire One PC Notebook
Recently I was using my xv-z90u, I started the projector up and turned it off right away and the bulb replacement lights started flashing and going into a standby mode(two red lights). So I replaced the...
There is no problem here, the sharp projectors just do this until you enter the reset procedure. It comes on a sheet with your lamp. they differ from projector to projector. often involves hold down power and some arrows while plugging in the projector - that will reset the lamp timer and you will be away!
Jan 14, 2010 | Sharp Projector lamp Projector Lamp
My Power light Continuasly blinksand wont turn on?
Lots of times with projectors is when you pack them away for a long time the bulb may become loose or maybe you have a wiring issue. its highly possible that your bulb may have just come loose. this occurs alot when you move it around alot. If it suffered any physical damage like maybe someone decided to use it as a stress relief punching bag then maybe the carbon fiber in the bulb may have snapped or a wire may have come loose inside the projecter. Hope i cleared up some of your confusion, unfortunately i dont have any real solutions for you. sorry. ~~RJ~~
Sep 19, 2009 | Sharp Notevision XG-P20XU Multimedia...
Sharp xr 10s no Power
blown fuse - take the lid off (six screws in the bottom and two in the back). look for a small red button by the lamp (front of the projector) and push it, it doesn't move much but it should work.
If that doesn't work call up 888-go-sharp their repair service.
NOTE - make sure you are NOT blocking the fan of the projector this causes it to overheat and shut down or worse... Make sure to tell your girlfriend the same thing so when you have the argument why she put the pillow on the projector you can at least say you told her not to block the fan.
Aug 29, 2009 | Sharp XR-10X Multimedia Projector
New bulb in now wont work - no power - wont turn on to reset lamp
first, make sure you have the correct lamp. the lamp for the xr-10x-l looks like the xr-10x, but the plugs are different (common mistake). make sure you have the AN-XR10L2/1, not the AN-XR10LP/1. to reset the lamp timer (with the projector plugged in but off), hold down the enter, down arrow, and menu buttons and press the power.
May 30, 2009 | Sharp XR-10X Multimedia Projector
My sharp xg-nv2u will not turn on. i have the power cable plugged in and everything is on....
1.Open the lamp cover and reinstall.
2.open the projector and check the Power Supply
3.check fuse/ thermal cut off switch.
Viren
Jul 13, 2008 | Sharp (BQC-XGNV2U//1) Projector Lamp for...
PG-C30XU projecting criss-cross plaid image.
i suggest you do not have the projector too far away... 7ft away distance would be a Good resolution will also dimm don the square's image in the picture
Nov 08, 2007 | Sharp Notevision PG-C30XU Multimedia...
Sharp Projector
to reset lamp timer, hold down enter, arrow down, and arrow right, then press the power button.
Feb 20, 2007 | Sharp ANW9Z WIDE ANGLE COVERSION LENS...
135 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
