Question about GE Energy Star WCVH6260F Front Load Washer
Ge frontload washer pausing in the middle of cycle
Why is my ge frontload washer pausing in the middle of a cycle? it will happen randomly the last couple of days doesnt matter what setting. also not fully draining on occassion...
  • 1,998 Answers
As to the not draining properly check the pump Ive had to change many of these pumps on this type of front loader or you can go into the diagnostic of the machine. if you remove the bottom panel theres a technician sheet there it tells how to go into the diagnostic menu: first unplug the machine for about 30 seconds then replug the machine then hold in signal then delay then signal then delay after which you willhear the door lock click then ull get a t-01 number use the dial to scroll to t-02 then push start this will give you the error code and tell you whats wrong with your machine compare the code to the technical sheet provided inside your machine remember to clear out the error code when you fix the problem
Posted on Apr 29, 2010
I pressed the pause button to add a garment to my Whirlpool frontload washer. After doing so, I pressed the hold to start button, but the washer would not restart the cycle.
Switch the power off from the power outlet for a few minutes , then switch on and reset the wash cycle . Front loaders are not designed to add clothes mid wash.
Mar 18, 2015 | Whirlpool Washing Machines
Fridgidaire frontloader washer stuck on pause
Hello Angela Gilmer - Usually when "PAU" displays on the screens, it indicates that the unit thinks that the door is not securely latch when you started the cycle, or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume washer. If proves to be ineffective, try reprogramming the unit by unplugging it or flipping the household circuit breaker off. If fault reoccurs, then it typically means that the unit has a faulty door latch. If you aren't certain that the door is properly shut, then the latch assembly may need replacing. Contact a professional to assist with the repairs.
Jan 20, 2013 | Frigidaire GLTF2940ES Front Load Washer
My washer initial had a rinse cycle problem where no rinsing occur after washing, now it spreads to the wash cycle where it is pausing at the this cycle, need urgent advice
The problem is you are not getting cold water fill. (rinse is all cold water fill) Check to see if the inlet screen is plugged by turning valve off that supplies cold to the hose attached to the machine, then removing the hose at the machine and checking the filter inside the water valve where the hose was just removed from. If screen is not blocked, replace water valve.
Nov 20, 2011 | GE Washing Machines
Washer will pause in mid cycle, once you push the pause cycle it will run for a while then will pause again, after about 5 to 6 times a load it will complete.
Hi
Thanks for using FixYa. You’ll need to clean the filter which is located on the front bottom of the washing machine right below the washer window. It is held up by three screws. Take out the screws and clean the lint. You’ll find in the lint some small clothing, coins and other small things.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 15, 2009 | GE WSXH208A Front Load Washer
GE Frontloader - will spin @ beginning of cycle, but never again
Check the switch on the door where clothes are loaded. I may be failing intermittently.
May 23, 2009 | GE WSXH208A Front Load Washer
Washer keeps pausing
you may have something in your drain pump.
1) Remove the three screws in the bottom remove bottom panel.
2) Remove drain pump cover (have towels or pan to catch water that comes out)
3) Remove any debris from pump, check that the impeller is not damaged and can be moved freely.
4) reinstall drain pump cover and bottom panel
Let me know if it helps
Sep 07, 2008 | GE WBVH6240F Front Load Washer
Shuts off in middle of cycle
I am having the same problem w/ our brand new front loader washer, it pauses constantly, and even when I can get the load to finish, I have to drain and spin atleast 3 x before I can even attempt to put in dryer, at this point it is taking me hours to do one load of laundry!!
Ugh-- Service man is coming tomorrow, so I will share what I learn...
Apr 19, 2008 | GE WBVH6240F Front Load Washer
Spin Cycle doesn't work on our GE Energy Star frontloader, please help
You may have to remove the lower panel and clean the drain pump filter. Easy job, once the panel is removed the filter will be right in front. Get a bucket and unscrew the filter cover (3 very small screws at the bottom of the front panel) and you should find a ton of lint and stuff in there. This model has a pressure switch that detects if there is water in the tub. If so it will do this pause and slow spin. Once the pump filter is clean you should be good again. It worked for me.
Apr 08, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
703 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
