Question about Samsung Digimax A503 Digital Camera
Camera does not focus especially when zooming. it went thru xray at airport.
    Brigadier General:
  • 11,967 Answers
The airport x-ray does not affect your camera. You may have a lens problem. Try these: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 29, 2010
When zoom in and out while on Auto Mode, the focus went off focus and took some time to adjust. How do I stop that from happening?
I would consider focus shift when zooming normal. Most small digital camera zoom lenses do that. If your auto-focus is slow, all I can suggest is patience or a newer/better camera.
Oct 30, 2014 | Cameras
Fuji instax mini 25 film can go through x ray?
X-rays can fog many types of film. If you are flying you can declare that you have film, and have them manually inspect it rather than sending it through the x-ray machine.
Mar 02, 2011 | FUJIFILM Instax 200 Instant Film Camera +...
My Kodak V1233 shows a lighted screen but I can
If it makes you feel any better, the airport screener cannot damage your camera in any way.
Jul 08, 2010 | Kodak Easyshare V1233 12.1MP Digital...
Out of focus especially noticeable in digital zoom
Digital zoom only enlarges the pixels causing the picture to become fuzzy. Don't use it. Only use optical zoom.
Oct 14, 2009 | Nikon Coolpix 8700 Digital Camera
Focus and or Zoom problem
double check that its still in auto focus, i went a whole day trying to figure out why my camera wouldnt focus, and i had auto focus off
Jul 12, 2008 | JVC GR-D770 Camcorder
Compact Flash + Airport X-Rays / Metal detector
Put all your gear in the xray and do not carry it through the metal detector. It is all safe for modern electronics, and they wont let you carry in the metal detector in the states anyways.
Oct 04, 2007 | SanDisk ULTRA II 4GB Compact Flash Card...
Kodak easyshare DX7630
X Ray machine would not harm the device. What Hi temp means I do not know- discuss it with the Kodak Support site.
Jun 21, 2007 | Kodak EasyShare DX7630 Digital Camera
Focus Problem
As stated on page 145 of the A2 manual: "When using this camera with the optional supplementary lenses, the accessory must be specified in section 5 of the setup menu. For more information on the Wide-angle Converter ACW-100 or Telephoto Converter ACT-100, contact your local Konica Minolta dealer. A firmware update is provided with these products to activate this option."
Sep 13, 2005 | Konica Minolta DiMAGE A2 Digital Camera
Are x-ray safe?
Your film, maybe. Some sources say that you'd have to run your film through -many- Xray machines to even begin to fog it, but many traveling photographers say they've had film fogged or ruined this way. Better to have them physically inspect your film rolls. Just tell them you have film and don't wish to run the risk of it being fogged, and would they please manually inspect it. Your camcorder, highly unlikely. FYI, some photographers were puttting their film in lead bags. But some airports have Xray machines that step up the power if they cannot see through something, resulting in guaranteed fogged film.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Samsung Digimax A503 Digital Camera Logo
57 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
