Question about Numark PT01 Turntable
Hi--I´m trying to record old LPs with this numark player and with EZ audio converter but it keeps sayin "Unable to connect to iTunes. Please make sure iTunes has no popup windows open, then hit OK."...I do have mac and leopardplease let me know what to do--
  • 10,319 Answers
Try this link for free driver downloads. They may have what you need to run your program on your computer with your NuMark
http://www.drivermedic.com/driver-medic-driver-updater/updates.php?t=Download.Driver
Posted on Apr 29, 2010
Hello, Since downloading iTunes version 11.05,
You might need to either reinstall the EZ or see if there is an update.
Feb 15, 2018 | Audio Players & Recorders
Numark PT-01 USB Portable Turntable EZ Vinyl/Tape Converter
Pull an old iTunes itl. Lib file from one of your older backups and use that to replace the newer iTunes itl. file
Nov 16, 2017 | Numark ttUSB Turntable
EZ Audio Converter,no sound in iTunes
Presuming you're on a Mac:
System Preferences -> Sound -> Input
Select "USB Audio CODEC"
Repeat all your recording you've done thus far. Worked here.
Dec 14, 2009 | Numark PT01 Turntable
EZ audio converter hangs
not compatible with itunes 9 no solutiuon complain to numark turntables
Sep 16, 2009 | Numark PT01 Turntable
EZ Audio Converter does not export files to iTunes
I've had exactly the same problem, and so far no resolution from Ion. A small bit of good news: the .wav files are on the hard drive, although without any track info. At least on Vista, they are in username/AppData/Local/Temp. The files are name Temp0, Temp1, Temp 2, ...
You can use iTunes to add these files (File/add file) and then convert them to .mp3s, or whatever format you prefer. Or you could convert them first using the tool of your choice, such as Audiograbber.
This is inconvenient, but a lot better than re-ripping the vinyl after EZVinyl hangs.
Jul 25, 2009 | Numark PT01 Turntable
No sound from iTunes audio files
it sounds like EZ A C did not get the audio or EZ put it in a format tha Itunes Cant play. download VLC media player and install it. open the file with VLC and se if it will play it. It will play just about anything it has most of the codex's need to play anything too. if it doesent play it then something is wrong with the input to EZ A C you might have the input muted.
Jun 23, 2009 | Audio Players & Recorders
Won't Export to iTunes
it is not compatible with itunes 9 call numark and complain
May 29, 2009 | Numark PT01 Turntable
EZ Vinyl Converter produces file that doesn't work
Try
Control panel
-Sounds - click on Speech and Audio Devices -
Click onSounds and Audio Devices. or if your in classic view -double click.
Click on Audio tab
Make sure that thedefault devicefor Sound Playback is set to the device hooked up to the speakers
i.e. set it to something other than the USB AUDIO CODEC which is the turntable
Jan 12, 2009 | Televison & Video
Numark turntable records record AND sounds in the room
the mic is in the computer somewhere, there will be a way to mute the microphone either in the vinyl software or in the system settings of the computer!
Jan 10, 2009 | Numark ttUSB Turntable
Playback Problem
They should be recording in mp3.  Then converted into ITunes using AAC.  Itunes will play MP3 format from the turntable.  The best thing to do is to record in that format, then test the files before converting them.  That way you can find out if the problem is with Itunes conversion or the turntable.
Oct 06, 2008 | Numark ttUSB Turntable
Numark PT01 Turntable Logo
83 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
