Question about JVC GR-D275 Mini DV Digital Camcorder
I can't capture for JVC GR D275U
I have the port 1394, I have the cable, I plug the cable on PC first and then on the camera, I turn the camera on, I open the software (windows movie maker and others) and.... nothing happens.
If the problem are the drivers, I can't get them either. So, could you help me????
  • 10,421 Answers
INEED TO DOWNLOAD SOFTWARE TO CONNECT CAMCORDER TO MY PC TO CONVERT VEDIO TAPE RECORDED
To transfer video from this camcorder to a PC, you need a 1394 cable (also called a "Firewire" cable, and your PC must have a 1394/Firewire connector as well. You can use Movie Maker (which comes with Windows) as the capture software, or you can download Scenalyzer (shareware), Studio (from Pinnacle), or Vegas Movie Studio to do the capture.
Jan 25, 2011 | JVC GR-D870 Mini DV Camcorder
Driver for 1394 port camera model : gr-d770as
Have you tried installing the software from the CD on the PC you are transferring to? There is no drivers for fire-wire.You can buy a a IEEE 1394 firewire to USB 2.0 cable if you do not have a firewire connection on your PC. The software captures the video or still shots.
Dec 15, 2010 | JVC GR-D770 Camcorder
Connect JVC GR-D240ek to vista laptop
Hi and welcome to FixYa,
A firewire to USB will not work. It has to be firewire to firewire. A JVC GR-D240ek uses 4-pin, IEEE 1394 compliant Digital Video Connector [DV OUT] to connect a 1394 cable (also known as a FireWire or i.Link cable) to a laptop equipped with an equivalent IEEE 1394 port. Please note that some laptops firewire port could either be 4 pins or 6 pins.
Soon as that connection as shown above is established, you can use Windows Import Video to capture / download the videos.
Other notes (from the same Windows Help link above) :
  • You can also open Windows Import Video by using Windows Movie Maker. After you connect ... your DV camera, and your computer, start Windows Movie Maker, turn on your DV camera, put it into playback mode, and Windows Import Video should open automatically.
  • You can also open Windows Import Video by using Windows Photo Gallery. After you connect ...your DV camera, and your computer, start Windows Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Photo Gallery, click File, click Import from Camera or Scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
  • You can also open Windows Import Video by using Windows Live Photo Gallery. (This options requires you to install Windows Live on your computer.) After you connect your...your DV camera, and your computer, start Windows Live Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Live Photo Gallery, click File, click Import from a camera or scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
Verify that the laptop's firewire port is 100% up to specs and totally compliant to IEEE 1394.
God luck and thank you for using FixYa.
Jun 18, 2009 | JVC GR-D240 Mini DV Digital Camcorder
Do I need a fire wire card for PC
Hi a firewire input is different from an 1394 port. For the laptop you can buy an firewire interface.
Regards,
Rob NL
Apr 16, 2009 | JVC GR-D370 Mini DV Digital Camcorder
Can a jvc camcorder GR-SXM38US be connect to a IEEE 1394 port on a computer, if so what cable do I need to buy
Nope, that camera only has S-Video and composite video outputs. IEEE1394 is also known as firewire. Newer camcorders will connect via firewire. You will need a video capture card for your computer. Either an internal card or a USB version. Then you can record the video onto your computer.
Mar 07, 2009 | JVC GR-SXM920 Camcorder
Connect old camcorder to new PC
JVC has the support page for the GR-SXM260U here: http://support.jvc.com/consumer/product.jsp?modelId=MODL027120&pathId=25&page=3&archive=true. This camcorder can be connected to a TV with the S-video connection (JVC recommends their YTU94146A S-Video cable) or two RCA connections. If you use an RCA composite cable, you use only one of the two audio connections (white) and the yellow video cable.
To connect this camcorder to a computer, you need a USB video capture device and some type of video capture software. Here are two examples: https://www.amazon.com/Diamond-Multimedia-VC500-Video-Capture/dp/B001FAE8MA and https://www.amazon.com/ION-Analog-Digital-Converter-Composite/dp/B002MT7JFQ .
I hope this helps.
Jul 05, 2017 | JVC GR-SXM260U Camcorder
JVC GR-D50 not seen by PC or Mac via Firewire
Could it be a bad cable or a bent/broken pin where the cable is connected to?
Nov 11, 2008 | JVC GR-D50 Mini DV Digital Camcorder
JVC GR-270U Blue screen with playback
a 1394 cable is specified for the GR - D - 270 but the GR - 270 U , not listed ( does your camera use VHS/c , or mini DV tape ? )
Aug 15, 2007 | JVC GR-AXM710 Camcorder
CPU not recognizing my camcorder
I hope you are connecting the camera to the Fire wire port of the camera, if not, if you are using a desktop, you require a an addon card called IEEE 1394 firewire card, which you have to install it on your motherboard's PCI slot, then using the firewire cable which you get along with the card should be connected to the card and DV port of the camera, then using the MOVIE MAKER software of windows XP, you can download the video.
Apr 03, 2007 | JVC GR-D290 Mini DV Digital Camcorder
Capturing D-VHS thru firewire (1394)
Here's what you will end up doing. ANALOG CAPTURE. I could help if we knew more about the HOST PC/MACINTOSH machine. It's only my opinion that to get a FIREWIRE ANALOG VIDEO DIGITIZER is not a great idea.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
JVC GR-D275 Mini DV Digital Camcorder Logo
178 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
