Question about Panasonic Lumix DMC-FZ7 Digital Camera
Lumix camera keeps saying please turn camera off and t hen on again
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 11, 2011
Lumix closes when turned on from drop
The message please turn camera off and then on again appears when the camera is not operating properly. So the manual says.
If the message persists you should contact the dealer or nearest service centre. But first you could check if you can see any damage. Check if the lens is not stuck. Remove the battery for a little while before you again try to switch on. Also check if the memory card is still in place and the battery door and memory card door are closed correctly.
If nothing helps you could contact the service centre or think of buying as new camera?
Jan 02, 2014 | Panasonic Lumix DMC-LS75 Digital Camera
When I turn my panasonic lumix tz3 on to take a photo, it struggles to focus and then says 'please turn camera off and then on again'. I do that but it just keeps saying the same thing. Anything I can do??
The problem is in the mechanical part of the lens housing, the motor that extends and retracts the lens is slowly seizing up, or the gears have ware and tare, or they need lubrication. This is a delicate job that require a camera technician to remedy the situation. If you continue to use the camera it will eventually stop working.
Jan 15, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Lumix DMC-F3 When I turn the camera on, the display screen says "PLEASE TURN CAMERA OFF AND THEN ON AGAIN" when you do it, it says it again???
There is a problem with your camera Lens Assembly. It is not opening within stipulated time. The lens assy is jammed or damaged. Take it to service center.
Dec 24, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
Please turn camera off & then on again
off the camera again and try to open the menu and try to reset it .if the problem persist send it to the survice center
Feb 03, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
Lumix lens retracts and extends
Belikes, any external object is trapped in between your Lens Motor and Camera Body. You should consult Authorized Service Personnel to handle this trouble.
Jul 28, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Wont take pictures
First of all you should take a look to the little "guide" that I posted to the "stuck lenses" problem for LUMIX. But in your case the camera is very different, so: first thing you should do is (hoping that its just a simple stuck problem, try moving the zoom gently doing circular movements and then more gently in and out with the camera on. VERY GENTLY!!! if that does not help, try disassembling the camera, the structure is similar to the one I described in the text, although its parts are smaller and more delicate. Every LUMIX camera cheaper that $ 1500 seems to have this kind of problems... REMEMBER TO BE REALLY CAREFUL or your zoom will say good bye.
Feb 27, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
Problems with my Panasonic Lumix Digital camera
let me explain to you guys, these cameras are slim line cameras and if dropped or mishandled it is going to give problems. you cant blame the camera if you are not handling it corectly.
Jan 01, 2008 | Panasonic Lumix DMC-FX7 Digital Camera
Panasonic Lumix DMC-FZ7 Digital Camera Logo
97 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
