Question about Acer Aspire 5920-6727 Notebook
An Acer "Install eRecovery Solutions" bar showed up on my screen two days ago and doesn't apper to be doing anything at all but sit there. How do I get rid of it? It is terribly annoying.
  • bobbiekelley Apr 29, 2010
    Sorry, but I'm a technical doofus and don't know what "run & type" means. Run what? and type where? I have to do things in baby steps.
    My bad.......not yours. Thanks for the help.
    Sergeant:
    Novelist:
  • 172 Answers
Hi, go to Start - Run and type "msconfig" (without the quotes) and under Startup find the eRecovery and uncheck it. Then restart and when it finishes restarting you will get a message regarding the Configuration Utility - click on Do not show this message again and done! I hope this helps. Please remember to rate my answer. Thank you :D
Posted on Apr 29, 2010
Corrupt files windows system32 config system
The easiest way to fix corrupted windows system files is do an Acer eRecovery. On power-up, while the Acer logo is showing, press the Alt-key and hold it down while pressing the F10-key repeatedly. Wait while screen shows eRecovery loading. On the eRecovery menu, select restore of system software to factory condition. This will delete all user data from the hard disk and once the restore is complete, you will have to re-enter your initial system configuration settings.
May 25, 2011 | Acer Aspire One PC Notebook
Hi my laptop wont go to windows , it just saying prepare boot to os . can anyone help please
Windows may not be starting due to a driver problem. In any case, see if you can get into the Windows Advanced Options Menu as follows...
1. have the ac adapter connected
2. power on the laptop and watch the screen
3. when the Acer logo is showing, press F8 repeatedly
4. Windows Advanced Options Menu should now start
5. once you are in the Menu, use the up and down arrow keys to select an option
You could try starting with ...
Last Known Good Configuration (your most recent settings that worked)
OR
Safe Mode
where you could do a System Restore to an earlier date when the system was working
If none of this works and you don't have any user data that needs to be saved, then do as follows.
All Acer netbooks have a factory install image on a hidden partition of the hard disk. Suggest you should re-install the original windows factory image. All user data on the C: drive will be cleared by Acer eRecovery which you would start up as follows....
1. have the netbook connected to its AC adapter which is plugged into AC power line
2. power on the netbook and watch the screen as it starts up
3. when the acer logo is showing, hold down the Alt key and press F10 repeatedly
4. until screen indicates Acer eRecovery is starting
5. once eRecovery is loaded, follow the directions given on the screen
May 08, 2011 | Acer Aspire 5315 Notebook
I pressed f10 lots of times and my internet just stopped working ,i wanto reset my klaptop to factory settings please can u help
All Acer netbooks have a factory install image on a hidden partition of the hard disk. Suggest you should re-install the original windows xp factory image. All user data on the C: drive will be cleared by Acer eRecovery which you would start up as follows....
4. until screen indicates Acer eRecovery is loading
May 08, 2011 | Acer Aspire One PC Notebook
I have a acer netbook.when i press standby or close the lid then it become go to sleep mode but problem is creating when press enter button then i cannot start any program or it go to hang position. my...
If your windows xp is not genuine, it likely has been corrupted. This would also explain why you cannot start any program. All Acer netbooks have a factory install image on a hidden partition of the hard disk. Suggest you should re-install the original windows xp factory image. All user data on the C: drive will be cleared by Acer eRecovery which you would start up as follows....
I have an acer aspire one, model: KAV60, that crashed a few days ago and I don't think anything is wrong w/ the hardrive but I cannot get it past the Win. XP "loading" screen..i know I may need...
Launching Acer eRecovery Management
1 You may also launch Acer eRecovery Management by running the program
from the Acer program group in the Start menu, or by double-clicking the
icon if you have created a desktop shortcut.
2 You can choose to restore the system from a factory default image or
reinstall applications and drivers.
3 Follow the instructions on screen to complete the process.
Note: External optical disc drive required. Please see your retailer
for more details.
Enable disk-to-disk recovery
To enable disk-to-disk recovery (hard disk recovery), activate the BIOS utility,
then select Main from the categories listed at the top of the screen. Find D2D
Recovery at the bottom of the screen and use the and keys to set this
value to Enabled.
Jan 19, 2011 | Acer Aspire One PC Notebook
My Acer D250 netbook starts show a white screen the reboots it self, sometimes it not only shows white screen but also gray or it run colourful lines then it restart. When it restart it start working fine...
Suggest using Acer eRecovery Management to attempt problem resolution as follows...
1. begin with the D250 powered off ...
2. if present, remove any external monitor (unplug its VGA connector from D250 left side)
3. power on and immediately press F2 to enter the BIOS / setup utility
4. using the right cursor key, cursor over to the Main tab of the InsydeH20 Setup Utility
5. if D2D Recovery is not enabled, cursor down to it, press Enter key and enable in pop-up
6. save any changes by pressing F10 to save and exit, otherwise press Esc to just exit
7. press Alt and F10 together while the Acer logo is showing to get entry into eRecovery.
8. eRecovery entry is indicated by message at bottom of screen "Windows is loading files...".
9. if not successful, power off, wait a minute then power on again and immediately
10. press Alt and F10 at the same time - do this several times while Acer logo showing.
11. once in Acer eRecovery Management (V7.0.10) screen, just leave it there........
12. if after a day or so, the screen has not changed, the problem is likely NOT hardware.
13. on the other hand, if your screen problem occurs after awhile, then it is hardware.
14. if it is not hardware, then your Operating System is likely corrupt or has a virus.
15. If it is not a hardware problem, you can completely restore system to factory defaults.
16. board level hardware repairs best done by sending D250 to Acer's authorized shops.
Dec 28, 2010 | Acer Aspire One PC Notebook
Factory reset my laptop
NOTE - you will lose all your data and any installed programs if you do a full factory reset. the process will restore your PC back to how your purchased it
This link will explain how to factory reset the PC using Supplied recovery CDs if you have them http://support.acer.com/acerpanam/desktop/0000/Acer/Veriton5100/Veriton5100faq19.shtml
This link will explain how to factory reset the PC using the ACER eRecovery if installed on your PC
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireE360/AspireE360faq67.shtml
If you do have the eRecovery hidden partition installed:- How to recovery your system from bootup
  1. Locate the Alt key, to the left of the space bar, and F10, on the top row of keys.
  2. Power the system on.
  3. When the system is powered on, tap the Alt and F10 keys together at the same time when the Acer splash screen appears.
    It should state "Please wait a moment..." with the Acer logo in the upper left hand corner.
  4. At the eRecovery Management menu it will ask you how to restore.
  5. Click on the restore option you would like to use.
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 03, 2010 | Acer Aspire 5315 Notebook
I have a Acer apsire M6341 destop, the computer got infected with viruses, got a blue screen with warning to shut down.It loads pass the loading sytem window files and stop at the bar screen. there isn't a...
I would recommend downloading Bart PE and than burning an ISO to a CD. Once you run Bart PE get under Command Prompt and enter chkdsk c: /f /r. This can also be done from an XP disk under the Administration console.
Sincerely,
Ryan Deschaine
Systems Administrator
Boxen Solutions LLC
http://www.boxensolutions.com
Email address: ryan@boxensolutions.com
Office number: 262.254.0064
Mobile number: 262.834-5844
Fax: 414.918.8432
AOL: BoxenRyan
Twitter: BoxenRyan
W172 N9175 Shady Lane
Suite 418
Menomonee Falls, WI 53051
Sep 23, 2009 | Acer Aspire 5315 Notebook
Install the eRecovery drivers for aspire 5715Z
First ensure you have enabled D2D from Bios, If bios settings are OK then that message often comes up when E recovery partition is damaged.
Possible solutions are calling Acer and getting a disk to restore recovery partition (best way to proceed)
Or downloading and installing drivers from acer website
Here is recovery procedure from manual, to ensure you are doing corrrectly:
Create backup
You can create and save backup images to hard disk, CD or DVD.
1 Boot to Windows XP
2 Press Alt + F10 to open the Acer eRecovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery Management window, select Recovery settings and
click Next.
5 In the Recovery settings window, select Backup snapshot image and
click Next.
6 Select the backup method.
a Use Backup to HDD to store the backup disk image on drive D:.
b Backup to optical device to store the backup image on CD or DVD.
7 After choosing the backup method, click Next.
Restore from backup
You can restore backups previously created (as stated in the Create backup
section) from hard disk, CD or DVD.
1 Boot to Windows XP.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 Select the desired restore action and follow the onscreen instructions to
complete the restore process
Here Acer download page: Acer Service & Support
May 05, 2009 | Computers & Internet
Recovery...
You don't want to do a eRecovery, eRecovery is used to format the hard drive and install the drivers like you just got it. You want to do a system restore.
1. Click on the Start bar to the bottom left of your screen
2. Select All Programs
3. Select Accessories
4. Select System Tools
5. Select System Restore
6. Click Next
A calender will come up, select the day it was working, probably the day before, click next. After this the computer is going to restart. All done.
Have a nice day!
Dec 22, 2008 | Acer Aspire E380 - Athlon 64 X2 4200+ 2.2...
Acer Aspire 5920-6727 Notebook Logo
79 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
