Question about HP 5510 4-in-one Printer
I have a hp 5510 all in one printer and I just replaced my ink, and now won't work. help?
  • 4,041 Answers
Hi there
Take out the inks again and colese down the printer take all leads out leave for 10 mins or so then start up printer and put ink back in may work, good luck
Pineworks
Posted on Apr 29, 2010
Show me where to install ink for model hp officejet 5510
hello!
first, you need to lift up both the ADF unit and the flatbed scanner glass unit.
then, when the print carriage moves into view, press down and pull the ink cartridge for replacement.
Jul 13, 2011 | HP Officejet 5510 All-In-One Thermal...
Where is the access door for ink cartridge changing to the hp 5510 all in one printer?
you can refer to the link below.. it will be able to guide you on how to replace your ink...
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&product=311255&lang=en&docname=c00033420#N508.
Jun 12, 2010 | HP Officejet 5510 All-In-One Thermal...
Printer # 5510 - How do I open to replace ink cartridge?
If you mean HP OfficeJet 5510 then the following tutorial is for you:
HP OfficeJet 5510 Replace Ink Cartridges
If you do NOT mean HP OfficeJet 5510, please do not fail my solution. Instead, start a new thread with your make, model clearly defined.
Jan 13, 2010 | Office Equipment & Supplies
Printer cartridge error message for office jet 5510 printer
I JUST HAD ADVICE FOR ANYONE THAT IS HAVING INK PRINTER CARTRIDGE PROBLEMS WITH THEIR HP 5510. MAKE SURE YOU ARE USING GENUINE HP INK CARTRIDGE. I HAVE BEEN HAVING PROBLEMS AND THE HP HELP DESK SUGGESTED THIS. NOW IT WORKS PERFECTLY!!!! JUST WANTED TO SHARE THIS INFO IN CASE ANYONE ELSE IS HAVING PROBLEMS!
Dec 11, 2008 | Office Equipment & Supplies
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
Ink location
Hi, I can help you. The ink is behind the print-carraige access door. Here is a link to the printer manual, go to page 63. But by all means download it and save it to your desktop. That is a good printer, but pretty complicated sometimes. Good luck.
http://h10032.www1.hp.com/ctg/Manual/bpu72474.pdf
Mar 09, 2008 | HP Officejet 5510 All-In-One Thermal...
The ink carthridge location
how do I get to the ink cartridge on a hp 5510 all-in one?
Feb 15, 2008 | HP Officejet 5510 All-In-One Thermal...
Hp Officejet 5610
check the belt drive, motor may need a replacement
Dec 16, 2007 | HP Officejet 5510 All-In-One Thermal...
HP 5510 4-in-one Printer Logo
59 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
