I need a new receiver for my V250 wireless mouse and key pad. How do I go about getting one?
    President:
  • 2,351 Answers
Hi britt767, just click the link below.
http://www.buylogitech.com/store/logius/en_US/DisplayCategoryProductListPage/categoryID.11200000
Good Luck & Kind Regards.
Mike
Posted on Mar 25, 2008
I cant get the mouse to connect to my laptop
Desktop or Laptop ?What type of mouse ??...
Enable a Mouse for a Laptop
Without the ability to drag and drop and point and click, a laptop computer is merely a desk ornament.
Most laptops are manufactured with a built-in mouse in the form of a touchpad.
If the touchpad fails or if you just prefer working with a mouse, it is easy to enable a mouse for use with your laptop.
Purchase a mouse that is compatible with your laptop.
You can find compatibility information on the manufacturer's website.
If the mouse is wireless, make sure that the USB receiver is included, or purchase it separately. The mouse will not function without the receiver.
Insert the batteries in the mouse if you are installing a wireless mouse.
The battery compartment is generally located on the bottom of the mouse.
Connect the USB mouse to the USB port on the computer.
If you are using a wireless mouse, connect the USB wireless receiver to the USB port.
Turn the computer off and then on again if you are enabling a standard mouse with a wire.
This will instruct the computer to run the "new hardware" wizard, which will walk you through the installation of the mouse, and your mouse will be enabled.
Turn the wireless mouse over, and locate a small indentation with a button.
You may need to use the tip of a pencil or pen to depress this button.
Simultaneously press the button on the mouse and the small button on the USB receiver.
This will initiate communication between the mouse and the receiver.
Hold the buttons down for about 5 to 10 seconds until the light on the mouse comes on.
Test the connection by moving the mouse.
If the cursor moves, you have successfully enabled the mouse.
If not, check that you have the batteries installed.
Try pressing the buttons independently of one another.
Press the button on the receiver until the light blinks and release it.
Press the button on the bottom of the mouse until the light on the mouse is lit.
This should enable your wireless mouse.
sign up
http://ftp.pisd.edu/guide/wireless-keyboard/wireless-keyboard.pdf
Wireless Mouse to Your Computer & Laptop
Connecting a wireless mouse to your computer is a great way to reduce clutter around your workplace. Also, it is an alternative to using your laptop's directional pad.
Wireless mice work just as well as wired mice for most computing needs.
The only detail that wireless mice lack compared to wired mice is the DPI (dots per inch) and the frequency rate, which is essential to the "fast twitch" movements in gaming.
However, most people do not need highly responsive mice; therefore, wireless mice are perfect for any other computing activity other than gaming.
Insert batteries into your mouse. If your mouse is rechargeable, charge it in the docking station provided with the mouse.
Buy a wireless adapter that works with your mouse.
If your laptop is enabled with wireless technology or Bluetooth, skip to the next step.
Install the drivers for your mouse.
Reboot the computer to apply the changes.
Power on the mouse and let the computer recognize the new hardware.
If you are using a mouse that requires software to run, enable the mouse in the software that is provided to you.
http://www.sunvalleyus.com/Article/LaptopKeyboardInfo/46.html
also
Laptop computers generally have built-in pointing devices such as touch pads that you can use to navigate the operating system on the go.
However, touch pads and pointing sticks are small and generally far from ergonomic.
At home, you might like to connect a full-sized mouse for greater comfort.
Computer mice connect in a variety of ways, and you should be able to find a mouse what works with whatever peripheral ports your laptop has.
As a general rule, any mouse that works with a desktop computer also works with a laptop.Laptops use the convenient touchpad and integrated scroll mouse that allow you to use just your finger to navigate Web pages, documents and open files and programs.
Just like all other hardware, the laptop's integrated touchpad and mouse can experience errors and problems that cause you to lose functionality for a length of time.
Whether the laptop's mouse is not working because of internal errors or conflicts with another device, several "tricks" can work to restore it.
Locate the function "Fn" button on your laptop in the lower left corner of the keyboard.
Look in the keyboard's upper row (the F1 through F12 buttons) for an icon of a touchpad or computer mouse.
This keyboard button acts as the toggle switch to enable and disable the built-in mouse and touchpad function.
Press and hold the "Fn" button together with the mouse icon button.
Look for the disable/enable symbol that briefly displays on your screen.
Slide your finger over the laptop's mouse and attempt to use it as normal.
Press the Windows keyboard key if using Windows 7, type "main.cpl" in the search box and press "Enter."
Press the left arrow key to navigate over to the "Device Settings" tab.
Press the tab key to reach the "Enable" button in this section.
Press "Enter" on your keyboard. Press the tab key to reach the "Disable internal pointing device" check box.
Press the space bar to remove the check mark.
Put your finger on the touchpad, and move the pointer down to the "Apply" button.
Click "Apply" to save the settings. Close the mouse "Properties" box.
Press the keyboard "Windows" logo key to open the "Start Menu."
Press the arrow keys on your keyboard to navigate to the "Shut Down" or "Turn Off Computer" menu. Press the up or down arrow key to highlight "Restart."
Press "Enter" to restart your computer and attempt to use the laptop mouse as it should normally function.
Open the "Control Panel."
Go to the "Add and Remove" or "Uninstall" programs section.
Highlight any secondary mouse devices in the list that you have installed for your laptop, such as an external USB mouse.
Select the "Uninstall" option to remove any software and settings associated with this secondary mouse.
Restart your computer and attempt to use the built-in laptop mouse as normal.
Check to see if the mouse is working properly.
Press the keyboard's "Windows" button to open the "Start Menu."
Press the keyboard's arrow keys, "Enter" button and "Tab" to navigate to and open the "Control Panel."
Go to the "Hardware and Sound" section, and press "Enter." Navigate to "Device Manager," and press "Enter" to open it.
Find "Mice and other pointing devices from the list" and open its "Properties" dialog box.
Select the "Driver" tab and choose "Update Driver."
Allow Windows to search the Internet for drivers and to update them automatically.
Restart your computer after the drivers are updated, and use your mouse as normal.
http://www.webdevelopersnotes.com/articles/laptop_touchpad_not_working.php
Aug 11, 2013 | Computers & Internet
Have puchased. a acer wireless optical mouse how do I change over from the present mouse pad?
Theres nothing you need to do much, just plug in the wireless transmitter drive into the usb port, then download driver if one is required. Press the link button, usually a small button located under the wireless mouse.. then you should be good to go. You can disable the mouse pad, usually there is a button or a fn key to disable the mouse pad.
Jan 31, 2011 | Computers & Internet
My Dell cordless mouse by Logitech will not point to where I need it. It will not go to where I want it without moving it all over the screen and sometimes that will not help. I have new batteries in it....
Make sure your mouse is as close to the wireless receiver as it can be. If you are in a officle multiple people can be using wireless and there's only so many channels. So put the wireless receiver right next to your mouse pad and reconnect the both of them.
Apr 06, 2010 | Logitech Cordless Mouse
I haven't used a touchpad before. I haven't had a
There are lot of people who can't get used to the mouse or (touch pad as it is called) on the lap top. I know, I am one. I hate the touch pad. Easiest solution is to use a regular mouse with a USB connection. Or you can buy a wireless mouse. If you carry around a lap top, it becomes a must that you have a laptop case. So, a wireless mouse is not going to be a hindrance. Best option would be a wireless one. Buy one. Put the CD that comes with it in the drive. set up the receiver (just install the program that came in the CD. That is it.) Put battery in the mouse, and press a button (a small button called connect) at the bottom of the mouse. And you are all ready to go as usual. This connect thing is a one time operation. You need to repeat it only when you change the battery. I guess you will get used to the key board in a weeks time. If the touch pad start acting up, you can disable the touch pad, so that only your mouse will be active. I am not sure what icons you are referring to, but if they are on the key board, most keys of the laptop have multiple functions. They are kind of colour coded.Look closely on the Fn key. you may notice that it is a little gray. You will also notice other markings that are gray on the keyboard. This means when that key is pressed in combination with Fn it has a new function. For example, Fn and F6 will decrease the brightness of the screen. Fn and F7 increases. Fn and F8 will turn your wireless on or off. There a few other functions like that too.
Feb 05, 2010 | Computers & Internet
Need software for V250 Cordless Mouse & Number Pad Kit for Notebooks
Here is the web link to download the software from Logitech.
http://tinyurl.com/yd2ssqo
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Nov 03, 2009 | Logitech V250 Keypad, Mouse
Why wireless mouse doesn't move the cursor?
Remove the battery of the mouse and install new one and then press connect button from the mouse side and the receiver side also.and use the mouse pad .
Sep 21, 2009 | Computers & Internet
Wireless mouse/ keyboard will not work when 2nd computer is on
There must be interference on the signal from the mouse by the second PC
Make sure that there are no power cables close to the mouse or receiver, I have seen this cause problems many times.
You could also try changing the channel in the router settings in case this is causing the problem, it may be on the same channel as the mouse but only interferring when the second PC is turned on, ta, HPC
Nov 16, 2008 | Logitech V250 (9675380403) Mouse
Key tronic wireless mouse quit working
Sounds simply broken to me. Time for a new mouse.
May 23, 2008 | Key Tronic UNPLUGGED PS2SB01...
Mouse and keypad won't both work at the same time
Install the keyboard and mouse each in half hour increments. This is because when the receiver is first plugged it, it is looking for devices that will be synchronized to it. Even after synchronizing your device to the receiver, it still "looks" for other devices for 25 minutes. If you install another cordless product at the same time in close proximity, it is possible when you press the connect button on the second cordless device that it does not synchronize.
Please let me know if this works..
Apr 11, 2008 | Logitech V250 (9675380403) Mouse
Microsoft Wireless Optical MOuse
I've noted that certain mousepads do cause problems- it seems to be with the graphics on the pad- reflective/light/dark areas on the pad cause the different movement patterns. I'd guess a pad with a dull non-reflective & uniform color might be best.
Sep 13, 2007 | Microsoft Wireless Optical Mouse USB...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
