Question about Vizio P50HDTV10A 50 in. Plasma HDTV
TV looses picture and sound. Will not turn back on
The TV suddenly cuts out and you hear a pop. simular to the sound when the TV is turned on. The green light stays on. I've have unpluged it, repluged it, waited for the green / amber light to flash until it stays amber, then turn it on and sometimes it will work. but know it won't.
  • Vizio Master
  • 12,061 Answers
Www.plasma-television-repair.com/Sample-Preview-Plasma-Tv-Repair-Training-Manual.pdf -
Above is a training manual, this should help you find and fix the problem if you wish to DIY. If you DO, decide to DIY, you MUST MUST get a Service Manual, for your exact make & model. it will be similar to the Training manual, but explicitly for your set. I do not recommend it however.In my professional opinion, you should contact Vizio and ask for an approved local service center, then, get a "Quote" for repair.
With faults such as this, it is important to leave them disconnected from the wall, as it is entirely possible, for a faulty, TV, to cause a fire, an explosion, or both. Anytime one hears any sort of "pop" similar or not, is grave cause for concern, as usually this means some sort of component failure, in a high voltage area.
Posted on Apr 29, 2010
My t.v. turns on for 20 seconds then it just cuts the picture off but i can still hear the sound
The way to test whether or not the television needs to be repaired is to do some things to it after it has cut off the picture. Making sure you can still hear the sound but no longer see the picture turn the volume up and down. If you can hear the volume increasing and decreasing, but you cannot see the volume indicator itself on the screen then you'll know that possibly the inverter(s) is/are loose or that the inverter board needs to be replaced. If you can see the volume indicator moving back and forth across your television screen then you might have a problem with your signal source i.e. your set top box (cable box/satellite tv box), your connecting cables or the connections themselves.
Apr 21, 2011 | Memorex MLT1921 19 in. LCD TV
TV goes blank - no sound or picture
Sounds like a bad capacitor or two in the power section. Do you hear a hissing sound also?
Nov 18, 2009 | Pioneer PRO-510HD 53" Rear Projection...
Tv comes ON but no picture
the light source is out. the new lamp will cost around 250 easy fix.
Jun 04, 2009 | Akai PDP-5016H 50 in. HD-Ready Plasma...
No picture but has sound
The problem can be caused by a bad sustain board (Ysus Zsus) , the popping sound is often caused by a capacitor blowing up.
The TV must be taken apart and tested before eventually replacing sustain boards.
Apr 27, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
No sound on sharp aquos LC32D6U
The problem is the silicone grease under the audio IC has melted and is shorting the audio circuit. To fix this, you'd have to clean the melted residue off the audio IC. It is a complicated job and I suggest calling your local Authorized Sharp service center to do this repair.
Jan 03, 2008 | Televison & Video
Have a beautiful picture but no sound
your problem is in sound section only. 1 signal line for sound coming from vif section 2 supply to audio section. 3 component fail in audio output section. 4 loose contact in audio section 5 speakr & its connecting wire.
Sep 27, 2007 | Sylvania 6427TE 27" TV
Audio ok, but Video goes from color to black.
the tv turns on fine, but after 5 - 30 min or so, "sometimes MORE " the picture all of a sudden go's black. Sound is ok it is 100% loose contact problem. 1 please check for any connector or print for loose. 2 in signal processor ic there might be loose. remember there is no component failure.
Sep 24, 2007 | JVC AV-32D305 32" TV
No sound
Hi, Probably you first have to determine if the "no sound" is the TV or your source (cable box). Try another source such as a DVD player hooked to the audio/video inputs of the TV, if still no sound then you have confirmed that it is the TV, if there is sound, then it is the cable box (in some cases it may be just the cables connecting the cable box and the TV; try wiggling it a bit, might just be loose). If it is the TV, go through the routine of the setup/menu; look for audio, stereo, SAP, etc, try different settings (pls log down original setting in case no change and you have to revert back). If all else fails, try the "thump test" this will help you determine if its a loose/cold solder problem inside the TV. Give your TV a good whack at the side, top or back, if sounds comes on even briefly, it's a loose/cold solder problem, if not then you probably have to have the unit serviced by a qualified professional. Good luck and kind regards.
Aug 26, 2007 | TruTech PLV16320 Television
Snap crackle pop
Check the Flyback, had same problem, replaced it and the unit worked good.
Oct 15, 2006 | RCA P46921 46" Rear Projection Television
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
639 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
