Calibrating a Fujitsu Touch Screen 152TA-R4 monitor
I have a Fujitsu Touch Screen 152TA-R4 the monitor will not calibrate. It keeps giving me a error message when I go through the process and follow the instructions. I'm running XP 32 bit.
  • 1602 Answers
SOURCE: Unable to Calibrate: Dell E153FPT
CHECK THE DRIVERS OF THE MONITOR, TRY TO UPDATE THE DRIVES
RESETING THE REFRESH RATE LOWER THAN IT IS NOW
IS THE RESET BUTTON THAT WILL SET THE MONITOR BACK THE THE MANUFACTURE ORIGNAL SETTING,
THAT MITE AN OPTION ON THE COMPUTER ITSELF, SHORTING OUT THE BOIS ON THE MOTHERBOARD BUT WHEN YOU DO THAT YOU CLEAR EVERYTHING ELSE LIKE HD,KB,MOUSE, CDROD,DVD,FLOPPIES, MONITOR SETTING,
ROD
Posted on Feb 12, 2009
  • 48 Answers
SOURCE: HP 4600 printer with error message 51.2M and loud
Replace your magenta cartridge first. If the problem persist I strongly recommend a service tech. Error 51.2M is an magenta scanner(laser) error or DC controller.
Posted on May 25, 2009
  • 34 Answers
SOURCE: sony ericsson M600i touch screen not working,not calibrating
it can be touch pad problem.
Posted on Jun 21, 2009
  • 5 Answers
SOURCE: sometimes when i turn up the monitor the screen is
Make sure the connectors are securly connected.
Posted on Sep 15, 2009
  • 10 Answers
SOURCE: I am trying to calibrate the touch screen and it
Your touchscreen is defective. Please contact Panasonic official service center http://heartlandsi.com to arrange a repair. It's covered under warranty.
Posted on Sep 29, 2009
We have a VReader and the touch screen doesn't
Try calibrating the touch screen (means of doing this can be found in the user manual). If, after calibrating the screen the touch screen is no longer responsive, I'm afraid that the screen is "ka-put" and will require a repair or replacement.
Jun 24, 2013 | Cell Phones
LA PANTALLA TACTIL NO FUNCIONA
google translated
TOUCH SCREEN NOT WORKING
DO NOT OPERATE AS TOUCH PANTLLA
Touchscreen computers and handheld devices are the newest wave of technological gadgets as of 2010. While these devices function impressively, they can malfunction just like any other technical device. Troubleshooting the touchscreen is simple and often will correct any issues.
Identify how the screen is behaving. A touchscreen will malfunction in one of two areas--sensitivity or position. If you touch the screen and the cursor is not centered on your finger, this is a position error and requires recalibration of the screen. If you touch the screen and it does not register your touch without pressing hard, this is a sensitivity error. If you touch the screen and nothing happens, this can be a sensitivity error or a malfunctioning screen. Calibrate the screen. For all main errors, calibrating the screen will correct the issue. Every device has a different method of calibration but can usually be found under a "Tools" or "Diagnostics" menu option. Reload the device. For handheld devices, remove the battery and let the device rest for no less than five minutes. For computer or computer system devices, power down the device, disconnect the touchscreen device from the computer and remove any power cords to it. Allow the device to rest for five minutes. Reattach the device or reinstall the battery and power up the device. If issues persist, reload the software for the device. For handheld devices, do a full wipe of the device and return it to factory specifications. For add-on devices to a computer or computer system, uninstall the device and reinstall the drivers. If reloading, registering or calibrating the device does not work, consult the manufacturer for possible warranty replacement options.
Feb 26, 2013 | Computers & Internet
What does calibrating a ipad mean
Whoever used the term "calibrating an iPad" may have been referring to touch screen calibration.
Some touch screens need to be adjusted, or "calibrated", or the device may act as if you touched a different spot on the screen than you did. The iPad screen does not need to be calibrated.
If the iPad make a mistake about what spot you touched, the error may be due to:
  • a defect or damage;
  • a screen protector;
  • a cold finger;
  • a hand that is holding the iPad and inadvertently touching the screen;
  • a finger that is inadvertently touching the screen.
Apr 26, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Screen seems OK but there is no way to interface as it does not respond to touch. Unit is 255w and about 2 years old.
The solution to this problem is for you to calibrate the screen. Before calibrating the screen, i will advice you reset the gps. To reset your device, hold down the power button for about 15 seconds, it will restart itself and power up fully, if the touch screen does not still work, then calibrating the screen will do the job for you. To calibrate the screen, follow the steps below:
  1. Turn off your nuvi,
  2. Hold the upper left corner of the screen, then turn on the nuvi,
  3. Release the power key once the garmin screen appears,
  4. Continue to hold the upper left corner of the screen for 30 seconds till a white screen with 'touch dots' appears,
  5. Then follow the rest of the guide from there.
It might take a few tries before it works for you but you have to keep trying till you get it right. I am very certain that this will work for you.
Dec 31, 2010 | Garmin nuvi 255W GPS Receiver
Calibrating touch screen
calibrating touch screenProblem with Pioneer AVH-P5750DVD Car DVD Player
May 20, 2010 | Pioneer AVH-P5700DVD Car DVD Player
Calibrating posiflex jiva 5800
There should be a calibrate program in your posiflex. If it still doesn't want to calibrate, check whether the touch screen glass is worn out / cracked since you might need touch screen replacement
Aug 09, 2009 | Posiflex Jiva 5800 All-In-One...
ROD
Feb 12, 2009 | Dell E153FPT 15" Flat Panel LCD Monitor
Calibrating the stick and screen
Go into system and choose calibration.
Dec 17, 2008 | Palm Tungsten E Handheld
UNABLE TO CALIBRATE TOUCH SCREEN
The only possible fix is to try to clean the edges of the screen in case any particles are trapped between the screen and the case, this can confuse the touch screen.
Do this with a soft toothbrush, it will not damage the screen.
If that doesnt work then in all likelihood the screen is broken, it can be replaced but this is not trivial. There are guides on the internet on how do do this.
Dec 30, 2007 | Nintendo DS Console
Calibration of my MobilePro off
We've put together some useful tips on calibrating your MobilePro * When calibrating your touch screen be sure to use the same amount of pressure that you apply during normal use. In general, the lighter the better. This allows the screen to recognize taps consistently. * When calibrating your touch screen hold the stylus over the calibration point until it moves to the next point. Holding it for this period will lead to greater accuracy than just tapping the spot quickly. * When calibrating your touch screen support the screen from the back with your other hand. Try not to grasp the screen from the side with your thumb on the front. * When calibrating your touch screen do not let anything other that the stylus accidentally touch the screen. For example, don't rest part of your hand on the screen to help steady the stylus. * Once you've completed the stylus calibration, be sure to perform the double tap calibration as well. This will ensure greater accuracy.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
