Question about Philips AJL308 USB/SD radio alarm clock
Screen is dim and I cannot fix it. I used a
Screen is dim and I cannot fix it. I used a flashlight to make sure the settings were correct. Autodim is shut off and its set to max brightness. I also tried to use the brightness control button on the top. Nothing works - its stuck on dim. This happened sometime after I turned the alarm off this morning. I notice the date and time were wrong too. I can only see it with a flashlight. It's only 16 months old and well taken care off.
  • 410 Answers
It has a 12 volt lamp in it that illuminates the display screen. It is not a user serviceable part. You will need soldering skills and tools to replace it.
Posted on Apr 29, 2010
What is the correct way to replace the watch battery?
turn it over and try again. the battery that is
Aug 15, 2015 | Watches
Screen is blank , but I have sound , If I shine flashlight onto screen I can see images , enough to try and set control settings
The "inverter" has failed, causing the screen to be very dim.
Is it cheaper to take the monitor to a "TV Repair Shop",
or to buy a brand-new monitor?
Mar 24, 2015 | Computers & Internet
Dim screen acer 5100-3019
Try going into power option settings and taking the brightness to the max there. Start, control panel, power options, then you should see a setting for battery and for plugin. Hope this helps.
Jun 21, 2014 | Acer Aspire 5100-3019 PC Notebook
Ti nspire cx screen is really dim.
Recharge the battery and see what happens.. Could also be that the autodim feature is fixed to the lowest value (30 s).
Apr 01, 2014 | Texas Instruments TI-Nspire CX Graphing...
Monitor is very dim
Just go to windows button search for battery then
you will see like this and check your screen brightness is it full
Dec 04, 2013 | Computers & Internet
Dell f700 powers up but screen remains blankno picture at all
If you still can see an faint or very dim image on the screen.
Use a flashlight to see if you can see a dim display on the LCD.
If you cant see anything it isn't worth fixing, If you can then you need to change the inverter. You can get them for around $20.
Oct 26, 2013 | Cameras
I have a Compaq presario cq60. when i turn it on the screen is very dim. can c it with flashlight. works fine just very dim. hooked it up to external monitor it works perfectly. what is the problem he
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 06, 2013 | Computers & Internet
I have a CrystalView XT Android Tablet/Netbook. My son tried to dim the brightness on the screen and ended up darkening it out all the way. How can I fix this through the keyboard? As I can't s
i have the same tablet/net-book and also accidentally lowered the brightness past 4/10 of full brightness setting. I couldn't see anything on screen. I found that if i put a bright flashlight to/on the screen, I could see what was on screen, it was dim, but not off. I used this technique to maneuver my way to the settings, display, brightness, and turn up the brightness to where I could see it. I hope this info didn't come too late. WebRepOverall ratingThis site has no rating(not enough votes)
Nov 24, 2012 | Computers & Internet
Dim picture
This is the way how to examine where the problem is. If the screen is going dark. You have to check that you can see the image on screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons (Power on both cpu and monitor), there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken. If you cannot see any icon on the screen. I would say that there are some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or dark spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Feb 09, 2008 | Dell E176FP 17" LCD Monitor
Philips AJL308 USB/SD radio alarm clock Logo
1,134 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
