Question about Lexmark X2580 Wireless All-in-One InkJet Printer
Which holes should add which color inks for Lexmark x2580 Printer Cartridge?
  • Lexmark
    Lexmark May 11, 2010
    I'm not sure I understand what you're asking but the Lexmark X2580 printer uses # 2 color cartridge which goes in the right side of the carrier and # 3 mono/black cartridge which goes in the left side of the carrier.
  • 4,041 Answers
All printer are the same ways to refill the inks up go to this website it will show you how it done there is a few Videos there for you to see how it done
But must tell you it not allways work with Lexmark rifills.
http://www.youtube.com/watch?v=pnCPB9Clk5c
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 29, 2010
Lexmark x2580 cartridge error
Try cleaning the copper strip that runs up the front of the cartridge (not the bottom) use a paper towel and some windex and wipe it off. if that does not work the cartridge may be shot. It does happen randomly or can be causedf by a power surge.
Nov 04, 2017 | Lexmark X2580 Wireless All-in-One InkJet...
Lexmark x2580 all in one printer
The Lexmark X2580 only uses the #2 & #3 cartridges. You can purchase it online at http://bit.ly/TkGrwB.
Aug 22, 2012 | Lexmark X2580 Color Inkject All-in-One 600...
HOW DO I REPLACE THE INK .I BOUGHT THE INK BUT FOR GOT HOW TO PUT IT IN
In order to replace the ink..please follow the following steps
#1
Spread out a piece of newspaper where you plan to work. Remove the supplies from the refill kit. The Lexmark 44 will have one bottle of black ink, one thumb drill and one syringe. The Lexmark 43 will have one bottle each cyan, magenta and yellow, three syringes and one thumb drill.
#2
Remove the label from the ink cartridge. The black refill hole is at the top of the ink cartridge. Use a toothpick to check the color of each fill hole on the color ink cartridge. Generally, the magenta is at the top of the cartridge, the yellow is at the left center and the cyan is at the right center.
#3
Use the thumb drill to open up the fill hole to fit the syringe needle. Place the tip of the thumb drill on the fill hole and twist until the hole opens up larger. Do this for each color hole on the color ink cartridge.
#4
Fill each syringe with 7 ml of color ink (one for each color) and 15 ml of black ink. Insert the syringe needle into the bottle of ink and pull the plunger upwards.
#5
Place the tip of the syringe needle into the fill hole. Slowly press down on the plunger. If the ink seeps out while filling, stop filling the cartridge and wipe up the ink with a paper towel. Some cartridges may not need the full amount of ink. Repeat this step for each of the colored ink fill holes.
#6
Replace the ink cartridge in the carriage of the printer. Run one to three test pages to cycle the ink and check the printing. Use any document with color on it for the Lexmark 43 and any document with black text for the Lexmark 44.
Thanks
Oct 06, 2010 | Lexmark X9575 InkJet Printer
The new ink cartridge smears near the last sentence of the page. is there a way to clean it? This printer is a Lexmark X2580.
Perhaps the Lexmark X2580 User's Guide will be able to help you. Just click on this link: http://bit.ly/a9VQt7. Scroll to Achieving better print quality, Page 37, for instructions on how to clean the printhead. Hope this helps.
Jul 12, 2010 | Lexmark X2580 Wireless All-in-One InkJet...
Print cartridges #34 & 35 won't work in my Lexmark x2580 printer.
The cartridges compatible with the Lexmark X2580 printer are given below:
18C0190 - #2 color cartridge.
18C1530 - #3 black cartridge.
However, if you are a residence of USA or canada then you can call Lexmark technical support, so that they will replace the #2 and #3 cartridges for you free of cost.
you may call at 1-800-332-4120
hours of operation are given below:
Monday to Friday: 8 AM to 11 PM EST. Saturday: 12 PM to 6 PM EST.
Apr 10, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
start
control panel
printer and fax
right click your printer, choose properties
go tab by tab and look for print quality and then try
something like this
choose econo mode, or ink saving mode to start.
try to print in grayscale mode and use only the black ink cartridge.
that should be your new default, and you don~t have to change it from winthin other programs
Mar 30, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
I can't seem to find the right cartridge(s) for my model -- X2580. Help
Your printer takes a number 2 color cartridge and a number 3 black cartridge.
I found them avalable at Circuit City. Here is a link:
Lexmark Ink #2/3
Nov 05, 2008 | Lexmark Office Equipment & Supplies
Printer cartridge missing
Make sure ur using the correct cartridge.....
for X2580 the cart number is 2 and 3
1.Cleaning the copper contacts on the carts as well as the copper contacts inside the cartridge carrier......
2. Remove the carts....and install the carts thru the solution center...(Start-programs-lexmark-solution center-maintenence -install carts
Clean the ink nozzel using a wet paper towel.....do not whip it ..just press and hold the nozzel....do this 3 or 4 times....
then
Install the carts...
open solution center.....click maintence tab...click on "clean to fix horizontal streaks"...
-----XXXX----
Apr 09, 2008 | Lexmark All-in-One Printer with PictBridge
Lexmark X2580 Wireless All-in-One InkJet Printer Logo
63 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
