Question about Vizio Televison & Video
My Vizio HD TV speakers are making a cracking sound, and will the make a long extended high pitch buss. The it will go back to normal and repeat. We had the cable TV guy oour her and he thinks it is our tv. No problem on the other tv's. Any ideas?
  • 1 more comment
  • oreo7707 Apr 28, 2010
    I have ATT Uverse. The box is made bi Cisco
  • oreo7707 Apr 29, 2010
    Anyone else have an Idea.
    My Vizio HD TV speakers are making a cracking sound, and will the make a long extended high pitch buss. The it will go back to normal and repeat. We had the cable TV guy out and he thinks the problem is with out tv. No problem on the other tv's. We have ATT cable service and have a cable box made by cisco.
    I hooked up external speakers and am still getting the cracking sound.
    Hi its L32
  • 566 Answers
Hi oreo
I`m going to help you with your tv but first;
Could you give me your tv`s model number?
Posted on Apr 29, 2010
  • 1 more comment
  • Jacques Marin
    Jacques Marin Apr 29, 2010
    o.k it is a 32" tv with audio out at the back.
    Do you have an amplifier or receiver that you could connect to that output?
  • Jacques Marin
    The idea is to isolate the audio section that might be faulty
  • Jacques Marin
    Also you could try to connect the cable(from the cable co) directly into your tv set to see if the problem persist.
    Guru:
  • 416 Answers
Do you use a cable box? If so, what kind (ei. Motorola)?
Posted on Apr 28, 2010
  • Adam Halfhill
    Adam Halfhill Apr 29, 2010
    Have your cable guy change that box. You said you have another TV that doesn't have the noise. Could you move either the TV or box to see if the problem follows? I've seen cable boxes to some strange things, from half a picture, bright dot in picture, crackling audio, no audio... on and on.
Vizio tv repair?
Sounds like power supply board is bad
Jul 27, 2016 | Vizio Televison & Video
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
High pitched noise coming from back of Viore LC32VH56A. Not speaker related.
A refurbished set!
Its a coil or transformer that is not tightly mounted or is vibrating hard enough to make the sound, If this is a refurbished set that is why it was returned and exchanged-----
Two ways to fix---locate which board is bad and correct the problem with Hot glue on the individual part making the noise OR just replace that board.
Dec 08, 2012 | Viore LCD32VH56A 32" HD LCD Television...
Vizio high pitch noise while watching
It sounds like the speaker wire it not grounded good. It sounds like a high pitch whistle or crackle.
May 05, 2012 | Vizio E470VL 47 in. HD-Ready LCD TV
Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Apr 07, 2010 | Vizio VW32L 32 in. LCD HDTV
Loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
Dec 22, 2009 | Vizio L37 Television
I have no power to my television. The vizio power logo is not even yellow.....unplugged and plugged back in and nothing....please help
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Dec 15, 2008 | Vizio L37 Television
Televison & Video Logo
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
