Question about Hitachi Magic Wand Hv250r Hand Held Massager
Does not vibrate, I had no transformer
When i purchased my Hitachi massage the person did not tell me i needed an transformer so i simply purchased an international multi head adapter, plugged it into the wall, it worked for 2 seconds then all i could feel was the motor turning, there was no vibrating. I pulled the head off and it looks like the coiled spring was pulled out of the plastic drive shaft from the motor. Where would i send my massager to have this fixed professionally?
  • Hitachi Master
  • 1,830 Answers
To the manufacturer.
Posted on Jun 27, 2017
2 Suggested Answers
Annais69
SOURCE: Sounds like its working, but nothing happens
I had the same problem with mine, it's due to the fact that the smaller spring has become un-lodged from the ******** itself.
You will need:
1. Roll of electrical tape.
2. Utility Knife
3. A small slot head screw driver OR a pair of needle nose pliers.
The solution is to unscrew the silver ring so that is can be moved up and down. Now, you need to use a utility knife and cut the blue rubber off of the spring. Once you have the blue rubber but off you can see a large spring with another smaller spring inside. Push the head of the ******** till the larger spring's coils are an 1/8 to 1/4 of an inch apart. Next take either the small slot head screw driver or a pair of needle nose and jam the smaller spring back into the hole in the center of the white plastic piece inside of the larger ring. Next plug it in to make sure the vibration is working, reattach the silver piece and tape the larger spring with electric tape.
Posted on Oct 28, 2008
Input 120v 60hz 25w output 3VDC 1500 mA I need a new transformer for an Acuvibe plug in class 2 Model D3-15A
Buy a generic multi voltage charger or any cell phone charger (they run on 3 volts) from a local electronics store or cell phone accessory shop, then solder and shrink tube your charging adapter onto the leak on the charger. You most likely can't buy the original charger. When you install the old charger end on the new charger end that plugs into your device make sure you pay attention to the polarity, one lead is market with a white stripe, one with none.
Sep 13, 2016 | Brookstone Mini USB Personal Massager
I recently purchased a C4380 All-In-One and will be using it over the next few months in Europe. Can I simply use a plug adapter or do I need a DC power adapter?
No, you will need a step-up transformer (power adapter) and not just the simple plug adapter, as voltage in the US is 110V, while in continental Europe it is 230~250V. You can purchase this at any electronics shop.
Hope that helps. Kindly "accept" this solution if you found it helpful.
Thanks.
Jul 04, 2008 | HP Office Equipment & Supplies
My Model N0:D3-15A Transformer needs replacement
  • I have not been able to find a replacement transformer anywhere! I have been looking online and in stores for an entire week. This is the second time, I have blown a transformer. I believe we have to purchase a new unit once again.
Jul 19, 2014 | Brookstone Softtouch Acuvibe Body Massager
When was the first vibrating chair made?
Massage chairs were first brought to market in 1962 by the Family Inada company. Today, Japan is the largest consumer of massage chairs with some surveys suggesting that over 20% of Japanese households actually own a massage chair. By comparison, massage chair penetration in the US market is estimated to be in the neighborhood of 1%. The current massage chair market is dominated at the top by a three dominant manufacturers: Fujiiryoki, Family Inada, and Panasonic. After the purchase of Sanyo by Panasonic, Panasonic announced plans to eliminate Sanyo as a brand for all current Sanyo consumer products.
Dec 25, 2012 | Furniture
I Need a New Power Transformer for hitachi model 50fx48b projection tv.Where can I can I purchase Transformer.?
www.tvrepairworld.com should be able to get any part for your Hitachi. Just click the contact button on the right side of their homepage and indicate your model number and what youre needing
Aug 20, 2011 | Hitachi 50FX48B 50" Rear Projection...
It seems to have power going thru it..but no vibration...help
The small sping has come out of the shaft from the motor.If you open the unit you will see that the motor has a little impeller and a shaft with a slot in it. The little spring inside of the massager head is suppose to ride inside of that motor shaft with the little tab on the spring lining up in the slot. It's really flimsy and after I fixed mine it fell out again after 5 minutes of use. It needed a stiffer spring or a different way of engaging the motor shaft. I'm still working on this...
Apr 09, 2011 | Hitachi Magic Wand Hv250r Hand Held...
Need new transformer and cord to connect to Chair massager
You can get the cord on the link below.
http://www.zis4u.com/brookstone-adapter-12vac-2000ma-p-364.html?cPath=40_41
Good Luck and please rate 4 thumbs up for the free answer
Jun 27, 2010 | Brookstone Health & Beauty
Hitachi Magic Wand Hv250r Hand Held Massager Logo
232 people viewed this question
Top Hitachi Health & Beauty Experts
ray gallant
Are you a Hitachi Health and Beauty Expert? Answer questions, earn points and help others
