Question about Linksys Wireless-G WRT54G Router
My router isn't sending out a signal for my laptop to find
  • 550 Answers
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Posted on Apr 29, 2010
Paswork
Posted on Dec 22, 2012
  • 221 Answers
It is likely that the wireless is turned off in the router. To access the router, use a cable connected computer.
The default access method is;
1 open a browser (IE or Firefox)
2 in the address bar type in 192.168.1.1
3 the login is blank, the password is admin
4 along the top of the router screen are several words
Like; Basic wireless security....
5 click 'wireless'
6. the first box should be 'mixed
the second type in the network name
click the enable button for the SSID broadcast
7 click the save settings at the bottom
This will turn on the routers radio
  • Bambi Nov 01, 2011
    Mine will not give me any info w/ the login blank
Repeater isn't getting signal
Plug the first router into a LAN port on the router you are using as a repeater. Don't plug into the WAN port. That should make it work
Jun 17, 2012 | Linksys Wireless-G WRT54G Router
My compaq presario v2000 laptop cannot detect the wifi signal of Zyxel router. It can detect all other router brands. I'm sure that my Zyxel router is sending signal because I can detect it using my...
I would guess that all the other wireless routers are broadcasting using the G wireless standard 802.11g and your router is only broadcasting using the newer N 802.11n standard. Your laptop only supports B/G. Check your settings on your router and either change it to G or dual G/N mode so your older laptop can find the network
Sep 17, 2011 | Zyxel Communications NBG416N 11N 150N Wlan...
Hi there, i got a usb air card for my laptop and i want to send out a signal to my belkin wireless router (with a cable) so that it can send out a wireless signal and be able to put my wireless printer on...
Sure, I can help. First off I need to know more information. Are you planning on connecting the printer, through USB, to your laptop then sharing the printer from there to other computers? If so, it is a matter of adding that printer, going into the printer properties, sharing tab, and sharing the printer. Or are you trying to share your printer wirelessly? If so you may need to buy a wireless print server. It acts as a base to share that printer and then allow you to wirelessly find it and connect. If the above doesn't help please tell me the make and model of your printer, laptop, and wireless router.
Best, -Mind
Aug 03, 2011 | Belkin (F5D7230-4) Router (587009)
My router is not sending the wi-fi signal, i already reset it more than 10x and unplugged it and unplugged my modem , restart or turn off my computer i did the whole run> ipconfig ****, still nothing...
Got any other "wireless" device that you can try, such an iPod Touch, to try to pickup a signal from your router?
Does your laptop have a switch or slider or FN-key-plus-some-Function-Key-1-thru-12 to disable/enable the laptop's wireless adapter?
If you take your laptop to another location with "free WiFi", such as MacDonalds or Starbucks, can you pickup their wireless network? If not, then the problem is _NOT_ your D-Link router.
If you use your desktop to connect to the web-server "inside" the router, does the wireless transmitter on the D-Link show as "disabled" or "enabled" ?
Jul 18, 2011 | D-Link Xtreme N DIR-655 Wireless Router
I have router in my room but my wireless signal seems no signal?
was this router already putting out a signal or is this a new installation type deal.
I do need to kno what brand U have to better help you fix this.
NEW INSTALATION
PLUG YO COMPUTER/LAPTOP TO THE NUMBR 1 PORT, TYPE 192.168.1.1,
GOTO WIRELESS follow instructions to get the router to start sending signal......i'm on yahoo messngr rite now if you care to elaberate more
Oct 10, 2010 | Computers & Internet
My laptop window vista can not receive a signal. It says "wireless association failed because windows did not recieve any response from the wireless router or access point. wat should i do?
You will have to make sure your router is sending the signal out. Make sure your laptop has the right access codes. Make sure the router is set to send a signal to b/g/n type adapters like the one on your laptop.
Windows Vista is an easy operating system to manipulate so go into your network program area and double check to make sure all the open access boxes are checked. Good luck. If your laptop adapter is ok, and your router's wireless signal is being sent out properly, your problem is minor.
Feb 15, 2010 | Dell Inspiron 1525 Notebook
The router is not sending out a signal for my laptop to pick up. What are some possible soultions for this issue?
If you can access the router setup page, change the wireless channel to a higher value and save the settings and then check if the router will be sending the signal fine now but if still not reset the router by pressing the reset button for 10 seconds while power is ON and then check if the signal is showing now...
Dec 16, 2009 | NetGear WGR614 Wireless Router
No signal from router
Try turning off the power to the router for 30 secs and then power it up again.
Sep 28, 2009 | Computers & Internet
Signal from router fades in and out
i think there is a heating issue with your router. check it.
Dec 15, 2008 | Linksys Wireless-N WRT150N Router
How do i hook up a westell router to a moterola comcast modem?
Okay, well something is obviously wrong.
This is how it should be connected. Internet to modem, then with an Ethernet cable, connect the modem to the router (jack1) then with another Ethernet cable, connect the router (jack2) to the computer.
If you are still having problems, then contact your company to see if they could walk you through it, or if they needed to set things up.
Also, where are you connecting your laptop from? Is it very far from the router? Perhaps your router's signal strength isn't great enough? (This would mean getting a new, more powerful router.)
Jun 13, 2008 | Westell Wirespeed VersaLink...
Linksys Wireless-G WRT54G Router Logo
545 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
