Question about Fisher and Paykel 24 in. DS-603 Built-in Dishwasher
How to change a element in a Fisher and Paykel Ds 603 dishwasher
  • Fisher and P... Master
  • 713 Answers
These units r very tricky to change the element. it involves pulling the wiring loom, hoses and turning it upside down to make it easier. sorry to ask u this but why r you changing the element? please reply and i can help u more.
Posted on May 04, 2010
Why does our dishdrawer tripout the safety switch in the fuse box?we have tried different electrical outlets in the house same result?
User Guides, Installations & Parts Manuals - Fisher & Paykel
https://www.fisherpaykel.com/nz/support/user-manuals/
Fisher & PaykelFind and Download User Guides and Installations Manuals for your Fisher & PaykelAppliances: ... This will help getting a quicker and more accurate result.
Expert Tips, Troubleshooting & FAQs - Fisher & Paykel ...
https://www.fisherpaykel.com/au/support/expert-tips/
Fisher & PaykelExpert Tips. Select a product type to see solutions to most common problems you may encounter with your appliance. Search. -Select-, Built In Ovens, Electric ...
[PDF]user guide DishDrawer Ph7 Eng - Fisher & Paykel
https://www.fisherpaykel.com/.../590199D%20DishDraw...
Fisher & Paykelguide', you can download it from our local website, listed on the back cover. Refer to ...Preference options and how to change their settings ... standard safety regulations.Fuse cover. Fuse. Electrical connection (GB IE only) ... Do not use an extension cord or a portable electrical outlet device (e.g. multi-socket outlet box).
[PDF]Controls (models with LCD) - Fisher & Paykel
Dec 25, 2015 | Fisher and Paykel 24 in. DS-603 Built-in...
My drawer on my fisher & paykel drawer sticks
I found a ball bearing stuck in one of the draw runners ?
http://www.scribd.com/doc/6462163/DD601V2-Manual see if this link still works
Sep 29, 2014 | Fisher and Paykel 24 in. DS-603 Built-in...
DISH DRAWER WILL NOT EMPTY PROPERLY
check the hose is not kinked that lets the waste water out. otherwise change the rotor at the bottom of the drawer. this can be accessed by unscrewing the panel at the bottom of the drawer to reveal the rotor. lift it out and place the new one in. replace the covers. try again.
Jul 10, 2014 | Fisher and Paykel 24 in. DS-603 Built-in...
Beep continuos and cycle stops
Water flood in the base of dishwasher. Check the fault code lights. If F1 then this confirms the problem. Need to find the source of leak.
Mar 14, 2014 | Fisher and Paykel 24 in. DS-603 Built-in...
Water will not empty and beeping will not stop on Fisher & Paykel DD6051
The flood switch has turned on. There is a leak into the base of the housing. Turn mains power off. Open bottom drawer and dry the base using towels etc. Need to find the source of leak. Lid seal or hoses.
Sep 14, 2013 | Fisher and Paykel 24 in. DS-603 Built-in...
Have the Fisher & Paykel single drawer dishwasher ds 603 and put it on a normal cycle last night. It started as per normal and sometime during its cycle it stopped and the drawer now seems locked. ...
It is very likely the thermal fuse has blown or the power supply board has had it. Either way the power to the controller and the drawer lid seal motors is cut off. This is why the drawer is in locked state as the motors have seized.
You have no choice but to force open the drawer to get access to the affected parts. Make sure the mains power to dishwasher is turned off as the base will be live.
Replacing the power board is easy but if the thermal fuse is blown then you are up for a large cost as it is integral in the heating element.
Refer this document for details of parts and location. Heater is item 17 on page 18 and powerboard is item 15 on page 13. (the document is for double drawer model but it just doubles up on parts)
You can get a rough idea of the parts cost from this site. Depends where you live.
Hope you are able to get it fixed.
Jan 27, 2011 | Fisher and Paykel 24 in. DS-603 Built-in...
Dish drawer won't drain
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Dec 01, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
Dishwasher won't *******
Turn mains power off and on after a little time.
Do you get any fault code on the display if you have LCD or if integrated, which lights are on on the drawer door?
Jun 05, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
Fisher & Paykel leaves film
When a film is left on the dishes, the problem is almost always a failed heating element. Dishwasher detergent requires a high temp to fully disolve and be effective as a a cleaner (solvent.) When the element does not come on during the wash cycle, the detergent is never activated.
It is ~possible~ that the thermister has failed, but some sort of error code should be reported if that was the cause.
Good Luck! Please report back what you find. OK?
May 06, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Dishwasher
To the cold tap. These need the cold water to rinse and heat the water with a element inside to wash. cheers
Aug 12, 2008 | Fisher and Paykel 24 in. DS-603 Built-in...
Fisher and Paykel 24 in. DS-603 Built-in Dishwasher Logo
105 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
