Question about Whirlpool Inglis IP8200 Dryer
Inglis dryer does not start. Light comes on
Inglis dryer does not start. Light comes on inside drum and door switch still makes distinctive click sound.
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryerInglis dryer does not start.  Light comes on - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 03, 2010
Inglis IFR 8200 electric dryer - power light comes on but no power to motor or heater. TCO hasn't tripped Any ideas?
Check the door switch! This is the likely culprit if the motor will not start. You can push the button in by hand with the door open and while holding the button in, push the start button. If still no go, check the switch itself does it click when pushed in and released slowly. If you can't hear or feel it clicking, replace the door switch. You can verify the switch function with a multimeter by reading across the switch without power applied and check for continuity as it changes state.
Jan 30, 2017 | Dryers
Why won't dryer start?
The door switch frequently fails on clothes dryers. You can check it by manually holding the tab tight to the panel and attempt to start the dryer. There should be a distinct click of a switch behind the panel when you depress the tab.
If dryer works when manually depressing tab but not when door is closed slightly bend the tab out to futher increase the travel of the tab when the door closes.
No click likely bad switch!
Replacement requires qualified technician. Part is inexpensive and readily available.
Feb 28, 2016 | Whirlpool Dryers
I CHANGED DRUM SUPPORT ROLLERS AND PUT BACK TOGETHER AN IT WILL NOT START
Suggest the following.
  • Check drum light. No light defective door switch. Light yes one leg of 220 circuit OK.
  • Be very sure motor doesn't start when you set to run. Belt may be off the motor and motor is very quite. Fix belt. Motor may be stuck or failed listen to hear if it is buzzing
  • When pressing start button listen for distinctive run relay activation. If when the start button is depressed I would expect to here the relay.
  • Motor run circuit relatively simple. The drum motor and blower are one assembly.
Nov 30, 2015 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer will not start. Power light is on. No coins are stuck in drum liner. No blockage. Recent repair replaced mother board at a cost of $500.00. The same repairman rep
Without a complete model number it's hard to say which direction to go. You might need a door switch, some door switches with an interior drum light will be a 3 wire switch allowing the interior light to come on but not the dryer start when the door is closed. Some dryers had a start relay mounted inside the control panel, which is controlled by the main board, failure of these relays can cause a no-op situation. Pleazer Appliance...
May 06, 2014 | Whirlpool Dryers
My whirlpool inglis ele will not come on????
The Whirlpool Inglis has had a lot of problems with the door switch. Which would keep the unit from starting.
Jan 02, 2012 | Whirlpool Inglis IP8200 Dryer
Dryer turns on but does not start when i push the start button. The timer comes on all the buttons light up, light is on inside dryer, but does not start just makes a sound when i hit the start button
if it's a humming sound the motor is bad or something is jammed keeping the motor from spinning.open the dryer door and move the drum by hand if the drum can't be moved the belt could be jammed on something or there's something stuck in the blower wheel.the blower wheel is behind the duct that the lint filter slides into.if you can move the drum then you most likely have a bad motor,try spinning the drum and push the door switch in and have someone else push the push to start button and see if the dryer will start,if the motor has a flat spot it could start like this.let me know what you find
Jul 14, 2010 | Kenmore 62602 Electric Dryer
Dryer drum is turning, but not drying the clothes. When I open the door, there is heat. Lint has been cleaned out
Check where the dryer vent comes out and make sure that there is a good amount of air coming out. If the fan is blowing, the drum is turning, and there is heat, the likely thing is that the dryer vent is partially blocked. Check the pipe leading out. Bird's nests are not uncommon. The only other thing I can think of is that the door catch is wearing out and the door is popping open, shutting the dryer off mid-cycle. Some dryers will continue to run the timer if the cycle is interrupted and it will appear that the dryer ran its full cycle, but in reality it shut off soon after it started.
Dec 06, 2009 | Whirlpool Inglis IP8200 Dryer
My Inglis dryer will not start when the start button is pressed. I've checked the starter switch with a continuity tester by touching one probe to CO (black) and another probe to NO (white)--it doesn't...
No. Judging from what you are saying, the switch seems to be making. First, I would check the thermal fuse. It is usually located just inside the back of the dryer, mounted on or near the exhaust duct. It's about an inch long and can be checked for continuity. If it has none, it is bad. Second, you could look at a faulty door switch. It is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or the front of the dryer to access the switch. You can test it the same way you tested the start switch. Hang in there!! You'll find the problem. Hope this helped and best wishes.
Jul 26, 2009 | Dryers
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Whirlpool Inglis IP8200 Dryer Logo
611 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
