Question about Roper RAS8445KQ Top Load Washer
Roper spin cycle
Ok which of the 3 wires, 2 gray, 1 green do you put jumper wire on to make roper spin, it is not the lid pin, but the tab which the lid pin touches to spin out
  • 5,911 Answers
The "tab" you are referring to is connected to the lid switch. Symptoms of a defective lid switch may include, filling and stopping on the intial fill cycle, a wash tub that will not drain, and stopping right after the wash cycle and not advancing to rinse or spin cycles.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare. If the model number you posted this question under is correct, the part number for a replacement switch is 3949247.
HINT: If you have determined the lid switch to be defective and would like to use the washer in the interim while awaiting parts, you can make yourself a by-pass plug by following these steps:
1. UNPLUG the washer.
2. Remove the lid switch by following the instructions in the link I provided.
3. With the lid switch in hand, cut the white plug off the end, leaving about two inches of wire.
4. Cut the center wire (ground wire - usually green or green/yellow in color) flush.
5. Take the remaining two wires (usually black or gray in color) and splice them together using a wire lug.
You have now made your yourself a by-pass plug that you can re-use if necessary. Take the by-pass plug and plug it in to the timer connector and the lid switch is now by-passed.
CAUTION: You will need to turn the timer off in order to stop the washer now. Only use this as a TEMPORARY repair until you can replace the lid switch.
If you have questions, or need additional assistance, please post back and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful.
Posted on Apr 28, 2010
Washer agitates but won't spin or drain - makes a humming/buzzing sound during those cycles
check the pump,could have a sock or something stuck in it.usually i would say to check the lid switch,open and close the lid,if you don't hear a clicking sound the washer won't go into spin or drain but if you're hearing a humming sound that's the motor watch this video
http://www.youtube.com/user/RepairClinic?v=DwV71h86Gxw it will show you how to get to the pump.pop off the two clips that hold the pump on and remove the pump just pull it backwards off of the motor shaft,now get a piece of wire and strip the ends on it,2 to 3 inches long,unplug the washer before you start to work on it,get your jumper wire and stick it into the wire harness that connects to the lid switch, don't plug it into the ground plug it into the other two wires not the green wire,i'm pretty sure it's the two outside wires and the green ground is in the middle,plug the washer back in and pull the timer out in the spin cycle,if the motor runs and spins you know something is stuck in the pump or the pump is bad,but just to make sure it's not the lid switch and it is the pump put the pump back on and start the washer again if you hear the humming it's the pump or before you pull the pump jump out the lid switch and see if it spins and drains,if it doesn't then pull the pump so you don't have to stick the bad pump back on the washer,all the lid switch is for is so the washer will not run in the spin with the lid open and some washers won't even agitate if the lid is open by using the jumper wire we are bypassing the lid switch to check the washer while it's apart.hope this helps and if you can let us know how you make out so if someone else reads this with the same problem it will help them out too.
Mar 13, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
My Roper top load washer stops in mid cycle and will not drain or do anything else
Most of the time that is lid switch failure. The lid switch must be engaged before the tub can spin. You can bypass the lidswitch to see if that is the problem. The lidswitch has 3 wires. 2 live wires and one ground wire which is green and bolted to the frame. Tie the 2 live wires together and see if the washer will work. You can use it that way but is could cause harm if anyone was to try and grab clothes out the tub while it is spinning full blast.
Sep 23, 2012 | Roper RAS6233KQ Top Load Washer
My kenmore ad 80 series washing machine won't spin
The lid switch is probably out. Bypass it and see if she magically comes to life. Their are 3 wires to the lid switch 2 of which are live wires. Jumper them 2 live wires and see if she runs in spin.
My home video: Washer won't spin It's a doozy
Jul 20, 2012 | Kenmore Washing Machines
Water fills and stop
Chances are the lid switch is bad. Sometimes you can see the switch located on the left or right side of the top where the lid closes but sometimes its located under the heading. In either case the lid switch is attached to the cabinet. To remove the cabinet
1) Unplug the machine. 2) At the head, or control panel, find the two screws that hold it to the case. Some are on the left and right front lower corners of the panel, and some are vertical facing s on the rear left and right side. Also on some models they are in the front but you have to pull the end caps off the sides of the control panel. Further more in some of the newer models you have to take a thin paint scraper and slide under the left and right normers to press the clips in to release. 3) Remove the 2 screws and then pull the panel from the lower part of it towards you and roll it backwards. 4) Disconnect the lid switch connection in the the middle where the two grey wires and the green wire block connects to the body of the machine, usually near the middle under the panel. 5) with a flathead screwdriver pop out the two brass retainer clips on the right and left side. 6) Open the lid slightly where you can grab the case, not the tub, just the case, and pull forward and surprise!!! You just took the complete top, sides and front of the machine off.
7) get a jumper wire and find the block that you disconnected that wasn't attached to the caseand place the jumper where in the holes where the is a wire other than green, which is ground. What your doing is bypassing the lid switch. Now with jumper wire in place, plug the machine in, turn to the spin cycle and turn it on. If it works you juist verified the lid switch is bad.
May 10, 2012 | Whirlpool Inglis IP4400 Washer
CAN'T SPIN OUT
do you mean the little prong that sticks into the lid switch to make the lid switch funtion so that it can spin you need to order the piece that he broke off on the lid or If he is mechanically inclined have him open the top find the lid switch connection and use a jumper wire from positon 1 to positon 3 on the lid switch wire connection this makes the unit run normally whether or not the lid is open or closed if he is mechanically inclined two phillips scews in back of unit to open the head
Apr 28, 2010 | Roper RAS8445KQ Top Load Washer
Roper washer spin cycle does not work
Hi if the machine goes dead when it reaches the spin cycle then the problem is likely caused by a defective lid switch. If when reaching the spin cycle you hear humming or clacking the problem will be a bad coupling. Listed here are the way to fix the 2 items. Here are the directions for a bad coupling. Kenmore's, Whirlpool's and Ropers are direct drive machines this means they don't have a belt. Instead the transmission is connected directly to the motor via a coupling. This is what a coupling looks like: 0c6b869.jpg To confirm this pull the machine forward enough that you can lean it back and it will stand back under it's own weight. Wedge something underneath the chassis so it does not fall on you while your accessing the bottom. Go under the Machine and locate the motor, You will see the pump connected to the motor connected to the transmission. 1. Unplug the wire harness from the motor then. 2. Use a screw driver remove the 2 clips holding the pump in place and remove or push the pump out of the way. 3. You will need to remove the 2 screws from the brackets holding the Motor in place with a nut driver. 4. With a screwdriver remove the 2 clips holding the motor in place (be careful to support the motor as the clips comes off) 5. remove the motor and drop it onto the floor. Now you will see the coupling..one side on the motor the other side on the transmission the rubber connector in between. Replace the coupling if broken or worn and reassemble the washer in reverse order. Now you should be all set. Be aware you may smell rubber on the first couple loads this is normal after replacing a coupling. if your problem is lid switch, this is located normally either in the control panel or about half way down on the right side under the lid. This is a safety feature to stop you opening the lid while the machine is in a high spin. Once you have located the switch trace the wires back to the wire harness in the control panel. Disconnect the lid switch from the wire harness and with an ohms meter check for continuity on pin 1 & 3 (the 2 outside pins not the middle this is a ground) You should find you have no continuity and should replace this switch. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Dec 04, 2009 | Televison & Video
Roper RAX4232RQ4 wont spin or drain
Hello, Your problem is going to be with your lid switch, this is located normally either in the control panel or about half way down on the right side under the lid. This is a safety feature to stop you opening the lid while the machine is in a high spin. Once you have located the switch trace the wires back to the wire harness in the control panel. Disconnect the lid switch from the wire harness and with an ohms meter check for condinuity on pin 1 & 3 (the 2 outside pins not the middle this is a ground) You should find you have no condinuity and should replace this switch. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 22, 2009 | Roper RAS6233KQ Top Load Washer
Roper Washer Wont Spin Out
Probably a bad lid switch. Open the control panel. Disconnect the lid switch wire connector on top of the cabinet under the control panel. Make a small insulated jumper wire and insert it into the wire that is still connected to the control panel. Set the timer to spin. If it spins replace the lid switch in the cabinet. If not, replace the timer.
May 05, 2009 | Roper RAS8445KQ Top Load Washer
Washer stops half way through rinse
check the lid switch on the washer loosen the two screws on the control panel end caps pull the control panel slightly forward and tilt on its hinges then you will see a connector under the panel it has three wires one is gray one is green i think the other is tan unplug the connector and put a jumper wire from gray to tan to by pass the switch lower the control pane and start the washer to see if it continues if it does replace the lid switch
May 24, 2008 | Roper RAB2121KW Top Load Washer
Wash goes silent at the rinse and spin cycle
if the wash water isn't draining you have a bad lid switch back out the two screws at the bottom of the control panel in the back pull the control panel forward tilt it back on its hinges on the body of the washer you will see a connector with three wires grey green purple make sure the knob is in disconnect the connector and put a jumper wire from gray to purple where it goes to the control panel pull out the knob and see what happens
Mar 30, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Roper RAS8445KQ Top Load Washer Logo
93 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
