Question about Alarm & Keyless Entry System Dodge Vehicles
My 2005 Dodge Grand Caravav remote entry quit working, My garage reprogramed the computer and it worked for several months and then it quit again and every time they reprogramed it again ir didn't last but a few days
  • 12,061 Answers
These devices are just a bother... I get similar FOB's sometimes in my shop, A considerable amount of problems are caused by bad batteries, or bad battery contacts. You need to get the procedure to "Re-program" your units. Usually, it is a simple job, and I am sure you would be up to the task. Also Often, depending on exact type, the Antenna connection, can be "dinky" and need attention. Usually, a "Reset" remove battery and reprogram, sorts the problems out. However sometimes you get one that faults all the time, this is caused by damaged RAM onboard the IC, that "Runs" the FOB, Also often they get fractures in the solder joins, on the actual PCB, Often may problems are permanently sorted by a quick going over of suspect looking joints, with a Hot soldering iron. I have given you some handy links below. Also a manual for your vehicle.
http://en.wikipedia.org/wiki/Remote_keyless_system
http://www.keylessride.com/
http://www.ehow.com/way_5344037_troubleshooting-remote-keyless-entry.html
http://www.ehow.com/how_6194237_program-keyless-entry-remote-fob.html
Above how to program Dodge keyless entry, may be of help.
http://carpdf.net/2005-dodge-grand-caravan-owner-manual.htm
Above is a manual, inside there are programming instructions too.
Posted on Apr 28, 2010
Keyless remotes not working
Try reprogramming the remotes. Here are the instructions for the procedure. Hope it helps. Cobra!
Programming NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
NOTE: To program (or reprogram) the keyless entry remote transmitters into the RAP module, perform the following steps:
  1. Make sure that the anti-theft system is not armed or triggered.
  1. Turn the ignition switch (11572) from OFF to RUN eight times within ten seconds, ending in RUN. If the RAP module has successfully entered program mode, it will lock and then unlock all doors.
  1. Within 20 seconds, press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed. Repeat this step for each transmitter.
  1. If the door locks do not respond for any keyless entry remote transmitter, wait several seconds and press the button again. If the door locks still fail to respond, refer to Inspection and Verification.
  1. Turn the ignition switch to the OFF position, or wait up to 20 seconds after step 2, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the RAP module will lock and unlock all doors one last time to confirm.
Jun 06, 2010 | 1998 Ford F150 Regular Cab
I have a 1/2 hp craftsman opener, it has the premium wall console, keyless entry and two remotes, chain driven. I installed it about a year and a half ago, it's worked fine since. Just recently, it would...
I would pull the logic board and check for loose or missing connections/traces on the printed circuit board. You can also foll the 110v line and make sure it has not worked loose.
Nov 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Some remotes work others only turn lights on and off
possibly bad relay/wireless board? keyless entry uses same board?
Aug 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keyless Entry won't work when it's cold
I HAVE THE SAME PROBLEM, I BELEIVE IT IS THE WEATHER . THE ONLY WIIRELESS THAT DOES WORK IS THE CLICKER. I HAVE NOT HAD WITH THAT ONE.. U COULD TRY RE-PROGRAMING
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Jan 20, 2009 | Chamberlain 950CB Remote Control
2005 Scion Tc keyless entry not working
You can take the car to the dealer and he can reprogram the remote for you. Or you can buy the programming instructions for $9.95 from here: http://www.keylessride.com/order/programming_post.asp?lbfix=yes&make=Scion&remoteyear=2005&model=tC&frid=76C74C4F
You will need a working key to reprogram your remote.
Dec 18, 2008 | Vehicle Parts & Accessories
Keylees entry and remote controls do not work at the same time
There are two types of technology with this operator (rolling code and non-rolling code). This operator will except one or the other but not both. It is not uncommon for a rolling code (Security+) remote or keyless to lose the "rolling"part of its technology and become a non-rolling code device so it is not compatable with the rolling code technology. You will need to replace the one remote or keyless that is not like the others.
Nov 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
FAN SPEED ONLY HAS HI SPEED
Have the blower motor resistor checked first. Losing several speeds on the blower and still working on one or more is normaly the resistor.
Oct 26, 2008 | 2000 Dodge Grand Caravan
Alarm & Keyless Entry System Dodge Vehicles Logo
104 people viewed this question
Top SMC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a SMC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
