Question about Rancilio Silvia Espresso Machine
Coffee barely dripping out when trying to pull a shot
I have had my Rancilio machine for five years. the coffee is barley dripping out when trying to pull a shot. I have never had this problem before. It is not the grind or the tamp. I am doing everything the same as always. I hear what sounds like the pump though not sure if it sounds as strong as usual.
  • 4 Answers
Your filter is blocked. It can be one of two things.
1. Coffee - this is obvious
2. Calcium - if you have hard water (i.e. your hot water kettle has white stuff in the bottom attached to the element)
The sure fire solution is to address both and the procedure is easy.
Since the filter is stainless steel, it can take the high temperatures of a stove top. Put the filter directly on the element and set to high for 10 minutes. This will burn off any coffee clogging the filter. After that, mix equal parts of water and vinegar in a pot, put the filter in and boil at max for 15 minutes.
This should do the trick. If it works for you, please click "yes" on "this is helpful", otherwise click "no". I searched for over a year to understand that my issue was a combination of two things so nothing worked for me. Clicking on yes/no would help the community understand if there are other unknown issues.
Posted on May 04, 2014
    President:
  • 1,618 Answers
Check the shower screen in the head make sure it is not blocked with coffee oils, if it is hold it over an open flame and that will burn out the oils, when it cools re assemble and run the head without the filter holder to make sure you get a nice flow of water.
Posted on May 04, 2010
How do i fix the Coffee flow from only dripping through?
if it has a filter ,replace. use vinegar through the water resevoir. fill it and turn it on.
May 26, 2014 | Rancilio Silvia Espresso Machine
I have a Rancilio Silvia around 5 years old. After around a year, it stopped reliably producing dry steam. I have very hard water, but despite regular vinegar cleaning, cannot seem to get it to steam
I work on industrial machines have done so for 15yrs
if your machine is anything like the prof rigs in terms of engineered design then what you are noticing is the pressure release valve working-letting any unused and pressure + water drain from the group head to a small plastic black box below the stainless housing panels/drip tray after extraction is complete.
What i describe should only happen after the shot stopped.
you should hear it and see it the water for about 2seconds after you stop the extraction manually/automatically
Dec 30, 2013 | Rancilio Silvia Espresso Machine
My Rancilio Silvia, about three years old, does not seem to be generating sufficient pressure. Standard espresso grind requires about two minutes for a shot and coffee is bitter. Is there any way to...
First things first, remove the screw and shower in the head and clean. Then change grind to something a little coarser, since we are testing the machine we will not tamp the coffee(we are doing this to have a constant in our coffee brewing equation). Note how long it took to brew, if it brewed longer than 40 secs, then adjust grind and try again. If coffee shots looks better and taste better then we are on the right track, we are looking for any thing between 15 and 30 sec depending on the coffee blend from light to dark. If you are getting the same results over 40 secs for a shot no matter what grind you use then the pump needs to be replaced.
Nov 28, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia - Water coming from behind into the drip tray when pouring a shot.
Correct
When you are finished and turn the pump off, the 3 way valve opens and relieves the pressure in the brew head so you don't get an explosion of coffee when you remove the portafilter.
Oct 26, 2010 | Rancilio Silvia Espresso Machine
We have a new coffee house with new machines. Our rancilio sometimes has water coming out all around the basket when trying to pull a shot. What is causing this?
You need to change the group head gasket. They only last about 1 year and then should be changed. Get 2 because they usually fail on Friday and you have a party on Saturday.
The gaskets get hard from the heat and don’t form to the filter any more so they leak.
When you get the new gasket.
Empty everything out of the machine (water tank, drip tray, etc.) Turn the machine upside down on a towel. This way you can see what your are doing.
Remove the filter screen and diffuser from the brew head. The black O-ring is your gasket. Carefully pry it out. Clean the opening good before you install the new gasket. Insert the gasket with the beveled side down (on the inside edge of the O-ring is the bevel). Once you have the gasket in place, use the portafilter to finish seating the gasket.
Sep 04, 2010 | Rancilio Silvia Espresso Machine
Coffee sprays from portafilter spouts while pulling shot
Either the group gasket is dirty or damaged. Also check the basket for damage.
Jul 21, 2010 | Gaggia Classic Espresso Machine
Rancilio Silva - coffee lost its punch
Try backwashing the group with purocaff.
Are you using coffee ground at the store or do you grind just before use?
How fresh is the coffee less than a month or more?
If more than a month(whole beans) it is no longer useful.
If more than a 3 days(ground), that is stale also. It will be very diffucult to get good espresso from that(not impossible, but difficult).
If using store ground, it cannot be ground older than a week(coffee loses flavor and taste minutes after being ground). Try getting less coffee more often and adjust the grind setting that you use. If you have always used setting 3 on the store grinder try 2.5.
If grinding at home adjust the settings on the grinder to a slightly coarser grind and fill the portafilter slightly over the top of the basket, now tamp to the indent(fill line) in the basket. that should be sufficient to pull a great shot.
May 17, 2009 | Rancilio Silvia Espresso Machine
I need help with my rancilio
check pump,maybe pump touching body or metal hose make noise
Aug 26, 2008 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
211 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
