Question about Compaq PS110 Computer Speakers
What is the polarity of the dc power supply jack?
  • 147 Answers
The foremost (point) is positive and the latter negative.
Posted on Apr 28, 2010
2 Suggested Answers
  • 298 Answers
SOURCE: Need to know polarity of power supply for JBL
Look where the plug goes in
There will be a C shape with a dot in the middle. Follow the line attached to the dot and you will see a + or - which is the polarity. Next you need to know Voltage. Look in the same area, or on the label for this info. If there is NO info by the power plug, it might be AC, which has no polarity - just plug it in. The label may have this information and will say something like 12VDC or 12VAC that is the key. DC Matters (+ and -) AC does not.
Posted on Mar 26, 2009
What is the polarity of the dc power lead
Hi, using a continuity tester, check point of Jack connects with shield (external metal square) of USB connector, that´s minus ( - ) polarity.
Feb 07, 2016 | Computers & Internet
Tip
Power supply polarity for Viking K-2000-DVA
The center pin of the power jack on the unit is negative (-) 12 volts DC. It is also common to all of the input common terminals. This is important when using a common power supply for other equipment such as 12 volt battery backed system for an alarm system.
on Dec 30, 2013 | Viking K-2000-dva-multi-input Voice...
Kmx02 wont turn on
Make sure the plug for the power cord is the same polarity and DC or AC for the mixer. Also make sure the inner diameter is correct for the station power jack as well.
As long as power from the supply is correct and adequate, theother potential sources of problems can be a blown internal fuse, broken power jack circuit tracks/traces, bad solder joints, dirty switch contacts, some contact cleaner sprayed in the gap of the switch toggle and then flipped rapidly for a number of times might clean it up.
Feb 04, 2012 | Numark Industries Numark KMX02 Dual Deck...
I need a replacement AC power adapter for FPE1080 TV
Hi, i have personally substituted laptop power supplies for those kind of televisions-make sure the power supply you get is of similar power rating, it should tell you the needed D.C. voltage and M.A. requirements maybe near the power jack-or somewhere on the label. Used power supplies are common at televised thrift stores. Just make sure polarity matches on power supply and tv-careful not to try and force jack into tv-it should slide right in. the voltage is usually 18 to 24 volts with an amperage of 2.5 to 4 amps, or 4000ma or something to that effect, hope this was helpful, Prodzilla
Mar 31, 2011 | Audiovox Televison & Video
What voltage and polarity do the ACS-5 speakers require?
Computers always use DC voltage. Computer speakers receive DC voltage from the computer.
DC voltage has a Positive and Negative polarity.
In the power jack of the speaker, the Center pin is the Positive connection. The outer shell is the Negative connection.
Center hole of the DC adapter plug - Positive.
Outer shell of the DC adapter plug - Negative
Voltage 5 Volts DC.
In case you need it,
http://support.dell.com/support/edocs/dta/acs5/
Nov 29, 2010 | Computers & Internet
I have a Sangean ATS 818cs portable radio but no 6v lead input
Yes you can use any 6 volt DC for your radio but the most IMPORTANT thing to remember is to connect the terminals in the correct direcction. First of all you can solder a red wire from the positve terminal of the battery and a black wire from the negative terminal of the battery. This must be connected to the source of your 6 volt battery.You can buy a good DC jack socket female to be fitted into the vacant spot of your radio and use a male jack to supply the DC. Only be carefully to see the polarity. To avoid any reversing of polarity use can even connect a diode in the forwarrd bias towards the positve terminal. This will prevent any wrong connection of polarity to damage your set. Helpful? Good day
Jul 13, 2010 | Sangean ATS 818 AM/FM/SW Radio
BEFSR41 power supply?
Both the voltage and the polarity should be printed on the case of the router. The polarity should be right next to where the power plugs in.
The polarity information will look something like this:
If you take the router into a local Radio Shack, the clerk will probably be able to tell you which power supply you need.
Jan 09, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Want to know polarity of Zip 100 DC power supply.
I just connected a new power supply to my zip 250MB, with the center pin as positive - and it worked out well :-)
Dec 18, 2008 | Iomega U.S. Power Supply Drive
Lucent AT&T 7610 Cordless Phone power supply
It should be labeled on the side of the phone. My best guess would be AC/DC...as to polarity, you would have to look at the drawing on the side by the jack...
Jul 27, 2008 | Lucent AT&T 7610 Cordless Phone (22063)
CE 21895GE3-A
If you did not get a DC power supply with the phone then it is either an optional item or it does not have the option. Does it have a DC power input jack? If it does, most (but not all) will be labeled with the polarity and voltage. If it is labeled, you could bring your phone to Radio Shack and get help picking out the right power supply.
Jul 24, 2007 | GE 29490GE2 Corded Phone
Compaq PS110 Computer Speakers Logo
111 people viewed this question
Top Compaq Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Tom Chichester
Are you a Compaq Audio Player and Recorder Expert? Answer questions, earn points and help others
