Question about Craftsman 20 Hp 42" Deck Lawn Tractor
20hpcraftsman3000 smoked and died. restarted with
20hp craftsman 3000 smoked and died. restarted with aircleaner off. runs bad loud popping and misfiring from the carb like it was the exhaust. Can anyone help please?
  • 718 Answers
Sounds like a major malfunction in the carb to much fuel getting fed to the cylinder, either get a rebuild kit for that carb or buy a new one. If you are unsure about rebuilding, take it to a service center in your area.
Posted on Apr 29, 2010
I have a poulan/craftsman 306A runs ok but smokes like crazy and unburnt fuel dripping from the exhaust,compression is good but wont rev as high as it should and wants to die when actually cutting
sounds like a bad carb. replace it or if you have a pressure tester test the fuel inlet with a low pressure and see if it holds. if it doesn't it's junk
Sep 21, 2013 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Car exhaust is puffing out smoke in intervals
Sounds like its misfireing or possibly bad gas
Mar 18, 2013 | 1998 Ford Mustang
Backfires when I take off
backfires to the Aircleaner (can cough or pop)
or to the end of exhaust tail pipe.
the former is bad cam or spark timing or both.
the latter is rich fuel mix and exhaust leaks.
air plus fuel equals muffler explosions. extreamly loud.
Mar 04, 2013 | 1998 Suzuki Esteem
B&S 20hp craftsman 46" dls3500
When you cleaned the carb did you clean out the metering jet with a needle and blow out. It only takes a tiny spec of dirt to raise hell with these small carbs.
May 29, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
I have a Craftsman Yard Man 6.5hp push mower with a Briggs & Stratton engine. The engine starts and runs fine for about 30 seconds or so then slowly dies out. It turns over slower and slower until it...
Have you checked the choke that it is off after you get the engine started,the black smoke is definitely from the choke, if you take the carb off and check that the needle closes when it should,as one can easily do an adjustment by bending the float/tab,rgds
Sep 25, 2010 | Briggs & Stratton Garden
Lt1000 20hp. briggs electrics on carb it will run when you pour i
Check fuel lines for clogging.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 13, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
When i start my lawn mower, white smoke comes out and it is spitting oil out
Crankcase is over full. Check oil level more carefully before adding. ALSO ALWAYS when cleaning the deck REMEMBER AIR CLEANER UP .
It you lay it down on the wrong side oil can get from the crankcase to the muffler and carb and aircleaner. Thats oil smoke you see.
Oct 21, 2009 | Craftsman Garden
Craftsman mower with 20hp B&S Intek won't start/run
That throttle cable issue sounds like it may be the culprit. the cable housing (the outer casing for the wire throttle cable) may not be anchored correctly. Which may be allowing you to move the throttle without any change at the butterfly control on the carb. make sure the cable housing is anchored at both ends.. by the throttle control and at the carb area.. That may be your problem... hope it is that simple...
K
Jul 23, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Engine runs like POP-POP-POP.Fuel solinoid?
Hi..my name is Keith...this is kind of a hard one to answer...when im not there...but i would suspect weak fuel..i would drain the tank and put fresh in and a new fuel filter..and if that dont help..then you might need a carb cleaning or overhaul..i hope this has helped..if not..write me back
Jun 28, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman DT4000 Running loudly
believe i had same problem this is what i did i took took the head cover under the carb and my needles was bent had to replace them now it works great again
May 19, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
296 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
