Question about Samsung HCM5525W 55" Rear Projection Television
On my Samsung HCM5525W the television turned off but the red light is on the timer, we do not have the remote control. How do we get it to turn on ?
  • 438 Answers
If you unplug your tv for a minuet more or less this will reset the TV to default values , timers off, otherwise this my also indicate a unit internal fault and requires technical attention
projection TV`s have integrated protection circuits
built into the circuit design, these circuits turn the
power off automatically when a fault has bin detected this
is in order to prevent a more costly repair, these circuits monitor
power supply , vertical and horizontal deflection
over voltage, or x ray, and also faults with convergence circuits.
Diagnosing these faults require test equipment and a good knowledge of
electronic repair techniques, and also a repair manual.
Posted on Apr 28, 2010
Testimonial: "excellent quick response"
Tv color is too red
the red screen control if located can be turned down until the picture is normal.
Sep 01, 2012 | Samsung HCM5525W 55" Rear Projection...
MY SAMSUNG TV MODEL HCM5525W 55 IN IS STUCK IN TIMER MODE AFTER IT WAS UNPLUGGED. DO YOU HAVE ANY SUGGESTIONS TO FIX THIS PROBLEM?
You need to reset the tv to factory mode by pressing a code with the tv off,,,, mute--182--power and wait to see the menu appears on screen chose *reset to factory* press ok and wait until process done, them turn it on .
Dec 18, 2010 | Samsung HCM5525W 55" Rear Projection...
TV won't turn on after a repair
you changed all the eprom info but didn`t "save to ram" before un-plugging ac cord, you will have to call a tech and be sure to advise him what you have done so the tech will be sure to bring service manual, info will have to all be re-entered, video-tek
Jun 10, 2009 | Samsung HCM5525W 55" Rear Projection...
Samsung 55" model hcm5525w
its the convergence problem in your power supply board
please check out this links
for convergence board ics reparing it your self
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
and for convergence settings
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
thanks.
Oct 05, 2008 | Samsung HCM5525W 55" Rear Projection...
Convegence board
your model has the Ics and resistors on the sub delection PCB board. You can get a new replacement board at the following link with free tech support to help you install it as it the entire large circuit board on the right side of the set. You need the board called the P54A chassis Sub deflection board under their Samsung parts category.
Heres the link.
http://servicemanuals.vstore.ca/
Aug 16, 2008 | Samsung HCM5525W 55" Rear Projection...
New Convergence board but need help adjusting convergence still
If the new sub board didnt fix the problem you will need a new convergence board as the sub deflection boards with the ICs only powers the convergence board. thats a complete seperate board. Let me know if you need more assistance.
May 22, 2008 | Samsung HCM5525W 55" Rear Projection...
Convergence Problem...now won't turn on!
You most likely shorted one if not both new IC's and that will cause the set not to start. I would say that replacing the board is probably the best bet but, be careful of plug placement.
Nov 30, 2007 | Samsung HCM5525W 55" Rear Projection...
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Samsung HCM5525W 55" Rear Projection Television Logo
341 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
