Question about Bosch Axxis WFL 2060 Front Load Washer
Grey spots on our white clothes after wash
We have a Bosch Front Loader, 2 years old. We frequently get grey spots all over our clothes when they have been washed, especially noticable on white coloured clothing. We mainly use cold water cycle, liquid laundry detergent, and conditioner. Any suggestions as to a solution?
  • 1,998 Answers
Do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Posted on Apr 29, 2010
How do i clean Bosch WAE20261AU front loader washing machine
The lint will be in a removable filter and as for cleaning the rubber seal the black grime will most likely be mould. Try a good mould remover.
Apr 27, 2013 | Washing Machines
Have a 4 day old Samsung Front Loader WF330ANB. It is leaving grey spots on my white towels. I do not use Fabric softener and I do not use the HE detergent over the Max fill line. Both Samsung and...
your using to much soap. use 1 tablespoon of detergent. too much soap will cause spots. depending on which cycle your using . might not be enough water on the rinse cycle. nothing wrong with your washer. i'm a certified samsung tech. hope this helps
Jun 03, 2011 | Samsung WF330ANB Washer
Bad bosch
The grey sludge may be due to incorrect soap powder (use only front loader) or excessive powder use. Minimise the powder use and insure you do a very hot wash once every 4 weeks to break down powder that may be building up.
Regards Sam
Apr 15, 2009 | Bosch Classixx WFO 2466 Front Load Washer
Maytag Nepturn TL FAV6800 Grey spots/debris on clothing
Hello davidsonrepl,
I was waiting with someone with more experience to post back on your issue. I haven't experienced this issue it but I would not rule out a transmission seal failure causing your oily grey substance in the wash tub. If you want to investigate further you can get the Service Manual from here
http://www.fixya.com/support/r1655507-found_service_manual_neptune_top_load
take a look at page 38 and on and see if you feel OK with a tear down to the transmission.
Feb 18, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Clothes are not clean How can I take washer aprt to clean soap dispenser???
Make sure you are washing at the correct temp, and that you have the correct prog selected for what you are washing. and that you have suficient powder and or detergent in. Check to see if the water is getting hot, because if it is not , then the heater may not be working, and then your clothes will not be clean.
Hope this helps with your prob.
Plz rate my solution.
Thanks.
Jan 03, 2009 | LG WM-2277HW Front Load Washer
Brown, rust-like marks on washing
Hello I got a Bosch ClassXX5 and got the same problem, white clothes seemed Grey and some clothes seemed washed but not perfectly, until I discovered that the washing machine did not heat water anymore; after the end of the wash cycle the clothes were cold as the program was initially setup to 40C°.....
I used to think soaps were not up to the task and changed brand often, sadly a Bosch product letting me down was not on my mind, since that brand for me was above the rest, quality, strong, during in the time, having electric tools from Bosch without any problem for years!
Oct 11, 2008 | Bosch Classixx WFL 2066 Front Load Washer
New Bosch water not draining
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
Apr 01, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Spots of Grey lint left on clothes after washing
Have you cleaned the filter on the front bottom of the machine?
May 11, 2017 | Bosch Washing Machines
Bosch Axxis WFL 2060 Front Load Washer Logo
1,286 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
