Question about LG WM-2277HW Front Load Washer
0E light flashing. Says something about drainage problem. No manual. Is this something easy to fix or need of service?
  • 1,998 Answers
There are (2) pumps. A drain pump amd a recirculating pump.
Loc K345 part # 4681EA2001C Recirculating Pump Motor about $30
Loc K340 part # 4681EA2001D Drain Pump Motor about $50
http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
hope this helps also if you type your model number into google with user manual you ca download it free
Posted on Apr 29, 2010
Toshiba 62MX195 faded flashing screen
There are some parts in any television set that can be DIY, In your case, I would suggest to read in the light engine replacement and see if that is something you can do.
Sep 17, 2008 | Toshiba 62HM95 62" HDTV
Nikon SB-29s Ring Light Flash won't fire...
check it with another camera.try to seek the help of an expert photographer or visit the site of nikon for more details.replace with fresh batteries and try once more.thank you
Jul 11, 2008 | Nikon SB-29S TTL Ring Light Flash
Ld14aw3 error code 0e lg dishwasher
LD 14AW3 Service Manual pdf
Mike - Here is the service manual.
Use - ld14aw3
Apr 07, 2014 | Dishwashers
Start light flashing, wont wash
see this and fix it. if necessary replace it. God bless you
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace.
Motor Control Module
The motor Control Module is located inside the cabinet down near the motor. This recieves the signals from the main control module then relays this information to the motor. Check all connections sometimes a communcation problem is just a loose connection. The Motor Control Module is easy to replace. To check this further you will need to refer to your tech sheet or service manual.
Sep 27, 2012 | Washing Machines
My intake/drain light is on. I have run my garberator. What else should I do to try and fix the problem?
A flashing "Intake/Drain," means something is wrong. It doesn't necessarly mean, "no water coming in," or "poor drainage." But of course, we should check those things first. What are the symptons? What part of the program does the "Intake/Drain" flash?
Oct 28, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Flashing lights on the base
I took it to a panasonic service center. They seem to recognize it and said its related to a flash ROM malfunction. Which usually needs to be replaced. In india they estimated the avg cost of replacing that to be around USD $20- $25. I have not got it fixed yet...
Sep 01, 2009 | Panasonic KX-TG9341T Cordless Phone
0E flashing on Westinghouse LF708C Washing Machine
Had the same problem. After checking that all the hoses etc were clear and no blockages, then suspected that the pump (cost $90 Australian dollar) was faulty. The Westinghouse service technician acknowledged that that was probably the problem, which I then confirmed by pulling out the pump, and then carefully connecting 240V across the pump terminals. Certainly was a faulty pump. So I spent the money on a new pump and installed it and now the washing machine (6 to 7 years old) works fantastically.
Apr 10, 2009 | Westinghouse Washing Machines
0E Error
Apr 10, 2009 | Westinghouse L2046NV Monitor
LG WM-2277HW Front Load Washer Logo
284 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
