Question about Olympus ? Stylus 500 Digital Camera
Regrding Olympus Stylus 500.. When turned on the lens cover opens half way twice then closes with a green flashing light and beeping sound.
Have just solved similar problem with mine. Problem turned out to be that the lens cover was very slightly dented in. It didn't really look dented at all, but just wasn't quite symmetrical and was a bit more recessed on the side away from the shutter button. This was causing it to rub on the case when it tried to slide. (Mine had been not sliding completely shut for a while before it stopped opening properly too).
To fix it I undid two small cross head screws which let the front panel be prised off. On mine, with the front panel off, the lens and lens cover mechanism all worked perfectly, as the problem was that the lens cover was rubbing on the front panel. If yours is still broken with the front panel removed, then your problem is not the same as mine...
I used a small screwdriver to push out the metal bar on which the top of the lens cover slides, pushing on the right hand end of the bar to slide it left and out through the USB connector compartment door. That lets the top of the cover come off the bar and move freely. To take the cover off, it has to be detached from the arm which moves it. There is a pivot trapped in a slot in the arm, but once the cover is off the bar at the top, it can be moved down so that the pivot reaches the bigger hole at the bottom end of the slot in the arm. This lets the whole lens cover come off the camera.
I then used a screwdriver to gently push out the middle of the cover until its shape was more symmetrical. (I'm not sure a screwdriver was ideal for this, as there are now tiny lumps in the cover where I was pushing it).
Putting it back together was the reverse of taking it apart, although you can test whether it's fixed or not before doing up the screws holding the front panel on.
Posted on Sep 19, 2010
My camera turns off with the lens half way in, and when i try to turn it on it makes a beeping sound and the red light flashes . the screen stays blank/black, whats the problem how can i fix it??????
Hi, it could be that the lens got some dust or even sand particles between the lens covers. You might need to take it in to your local camera repair shop for a more detailed answer, but I had the same issue with my lens cover that only closed half.
Hope this helps.
Regards
Jun 28, 2012 | Olympus T100 Digital Camera
When I open the shutter door on the front it does not seem to switch on - the battery is charged - the green and orange light on the back flash and beep ???
2 thoughts. 1, with both green and orange lights flashing the manual indicates that that means that the battery is not charged. This site provided an answer to a similar question that suggested cleaning around the battery area [see Bill BS answer to Wendy]. 2, To you and Wendy, I had a similar problem and a call to Olympus suggested the likely problem was not battery related. When you open the slide, and if you press down on the cover, around where the "s" on olympus appears, that keeps the lens extended. Don't know why that is, or how to permanently fix, but it seemed to work.
Dec 07, 2009 | Olympus Camedia C-50 Zoom Digital Camera
Olympus Stylus 840 - lens won't open
you need to take it or send it for repair. There is nothing you can do yourself.
Olympus Stylus 840 Repair - Google Search
Mar 23, 2017 | Olympus Stylus 840 Digital Camera
Turns off due to sliding lens cover
may need to replace the screws in the door or even tighten them up
Dec 30, 2008 | Olympus Camedia Stylus 300 Digital Camera
Dropped Camera - Lens won't close
Generally speaking if your camera cost $500 or less, and you can't fix it yourself, it is cheaper to just buy a new one.
Jun 30, 2008 | Olympus ? Stylus 500 Digital Camera
Outside shutter cover will not open
The only thing I can recommend is to manually push the cover open. But, it will probably stay that way, and not close.
Mar 12, 2008 | Olympus Stylus Verve / ?-mini Digital...
Olympus Camedia D-565 Problem
you left it too long for a free replacement
But it is worth contacting Olympus as it is know this one was a lemon.
Jan 15, 2008 | Olympus Camedia C-350 Digital Camera
Weatherproof
The Stylus 500 weatherproofing protection is equivalent to IEC Standard publication 529 IPX4. The camera will not be damaged by water splashed from any direction. The camera can be used outside in adverse weather conditions. If you are taking pictures when the camera is exposed to rain or snow, make sure that the optical components (lens, flash) are not covered with water. Water droplets on the lens may affect image quality. The Stylus 500 is designed to operate at ambient temperatures of 32?-104?F and relative humidity 30-90%. Please note that the camera is weatherproof, not waterproof, and cannot be immersed in water. Olympus will not assume any responsibility for any camera damage caused by water getting inside as a result of misuse by the user.
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Olympus ? Stylus 500 Digital Camera Logo
98 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
