Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
No pictuer no sound
I have a sony grand wega model no. kdf-e55a20 I have no pictuer or sound the power light flashes red 6 times in a row then pauses. I think it is the thermal fuse needing replaced. if so wher would it be located withen the tv.
  • 438 Answers
Your user manual will have the flashing light code structure indicating the fault that caused the shutdown there is no thermal fuse in your TV
projection TV`s have integrated protection circuits
built into the circuit design, these circuits turn the
power off automatically when a fault has bin detected this
is in order to prevent a more costly repair, these circuits monitor
power supply , vertical and horizontal deflection
over voltage, or x ray, and also faults with convergence circuits.
Diagnosing these faults require test equipment and a good knowledge of
electronic repair techniques, and also a repair manual.
Posted on Apr 29, 2010
Why does my Sony KDF E55A20 LCD projection television stopped. It flashes green 3 times at power up and then continuously flashes red in 6 flash intervals
The problem is sort of complex. This could be the main power supply, or the high voltage supply. There is also a chance there is a short on one of the boards and the main supply is tripping to protection.
This is not something you can fix at home. In consideration of the service cost, and most likely the circuit boards and many of the parts will no longer be available, you should consider a new set!
Jul 16, 2014 | Sony KDF-E55A20 55 in. LCD Television
My tv won't turn on anymore. The red light flashes 6 times then pauses for a couple seconds then starts flashing six times again. Just keeps doing it repeatedly
try unplugging the tv and waiting a minute and try it again if its still the same? It sounds like a Capicitor problem on the Power supply.
Dec 26, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
My Sony Grand Wega KDF-E55A20 will not turn on with the remote or manually. The red light flashes 6 times then off.
6 times is the lamp thermal fuse or lamp. its a thermal that sits on the bottom of the lamp area.
remove the fan and you will see the siler disk with black base cut the wires and slide the new one in on the side secure it on the old thermal and your fixed.
Nov 04, 2010 | Sony KDF-E55A20 55 in. LCD Television
Sony Wega Tv powers on w/ green power light and
need to know how many time the red light is blinking there should be a pause. 4 blinks is a fan, 3 blinks is the lamp door is not closed 6 blinks is thermal sensor.
Apr 22, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Grand Wega turns off and comes back on
sounds like your lamp is getting weak, you need to replace it.
Jan 12, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My sony 50" wega just quit. No picture , no sound , no nothing ?
If you see standby red light blinking on Tv front with 3 seconds interval then count its blinks from pause to pause and let me know, its an error code.
And if TV does not even show standby light then check fuse in power supply that would be blew off for some reason, replace it.
Still problem? let me know with exact model number of your Sony TV.
Thanks.
Jan 02, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a Sony KDF-E55A20 rear projection, it will shut off pic/sound for 15 seconds then come back on for 15 min...then the same...I had a problem with this about 3 weeks ago and cleaned the bulb vents and...
Hopefully it's still under warranty or you purchased an extended warranty. My concern is that it is either a power supply issue or a lamp ballast issue. If it has overheating in the past then there may be other issues going on.
Would suggest bringing it into a good trusted service shop.
Sony KDF-E55A20
Dec 19, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
290 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
