Question about Konica Cameras
Konica Hexar AF (silver)
I have a Konica Hexar af (silver) that I recently purchased used about one month ago. It is basically new but unfortunately I ran into what I think is a circuit board issue. When I turn the camera on the display panel shows every numerical value there is. Also when I press the Select button, the display reads E11 which most likely means an error of some sort. I've removed the battery and replaced it. Any help would be greatly appreciated.
thank you,
- Devin
SOURCE:
  • 4 Answers
SOURCE: shutter release/AE lock and control panel display
Same problem that would not allow me to take a picture without pressing the LOCK button on my Nikon 8700. Here is how I believe I fixed the problem:
Turn the camera ON.
Press MENU button on your camera to bring up the menu.
Scroll down to SET-UP, open the SET-UP menu by scrolling right.
In the SET-UP menu, scroll all the way down to FUNC (Controls) on page 2/3 , open the FUNC (Controls) menu by scrolling right.
You are now presented with 2 options:FUNC and AE-L, AF-L)
Select the FUNC option by right scrolling.
Choose the 2nd option: i.e the mountain, flower and timer icon (distance, macro and self-timer icon) by right scrolling.
Press the MENU button to get out of the menu.
Attempt to take a picture without pressing LOCK.
Should work! Anyways, it worked for me.
Cheers.
Posted on Jan 22, 2009
  • 59 Answers
SOURCE: "No Card" showing in screen
Check the lock slider on the memory card. it will be on the side. if that fails connect your mem card to a pc and format it.
Posted on Apr 04, 2009
SOURCE: moultrie camera locked up.
THROW IT IN THE TRASH! NO MORE PROBLEM.
Posted on May 04, 2009
ginko
  • 19396 Answers
SOURCE: EEE error on my Konica Hexar AF
If you are using Windows xp , download the UVC driver update from http://www.microsoft.com/downloads/deta … laylang=en.
If that is not enough follow the threads below about EEE and USB drivers.
EeeUser ASUS Eee PC Forum
EeeUser ASUS Eee PC Forum / Camera drivers
Posted on May 30, 2009
SOURCE: fuji s1 pro problems
I cannot solve the problem, but will say that in searching for a solution to my problem, I read in the manual that if you are not going to use the camera for a while, to take the batteries out. This is probably why you now have a malfunction. I sympathise - only now do I know this myself, having not referred to the manual very much in the past eight busy years. Sorry for your loss.
Posted on Sep 16, 2009
HOW DO I SET MY CAMERA TO AUTO FOCUS
The D90 has three different autofocus modes. In the AF-S mode it will not shoot until it has focused. In the AF-C mode it will shoot when you press the shutter release button even if has not focused. In the AF-A mode the camera switches between the AF-S and AF-C modes so either can apply.Also, bear in mind that the camera doesn't really know what you're taking a picture of. It may focus on something other than your subject. If you're in the single-area AF mode then you control which of the eleven focus points the camera uses. In any of the dynamic-area AF modes the camera decides.For full details on how the various modes work, please consult your manual. You might also check out the Nikon D90 video tutorial.
Apr 24, 2012 | Cameras
Purchased an eos50e with tamron lens 28-200mm a few years ago, can the lens be used with a digital camera
its not possible to use the lens with digital camera .........but can you be more specific about the digital camera with which you are trying to use the lens
Aug 07, 2008 | Canon Cameras
I have three new Metz 58 AF-1N's, and a Nikon
take a silver paper and put in front of the slave censer when you take the photo flash on camera as master should go on silver paper OR used slaveunit
Jun 30, 2009 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
Nov 25, 2008 | Konica Hexar Silver 35mm Point and Shoot...
Sad photographer
Sounds like you need to get your camera fixed by Nikon.
However, you say the auto focus stopped working, you didn't switch to a lens that uses a mechanical focus linkage do you? The D40 only supports lenses with AF-S or AF-I type autofocus drives. AF-D and AF-G types without AF-S or AF-I don't autofocus.
Also, check that the A/M switch on the lens is in the correct position.
Manual focusing is quite difficult to do accurately with an AF camera. The screen inside the camera is not optimized for this. If you are sure you are focusing accurately but the pictures you take are still out of focus, the mirror may need adjusting. I can provide further info on this if you require, but if you're within warranty, i'd recommend that route first.
Nov 19, 2007 | Nikon D40x Digital Camera
AF system DiMAGE E223 employ
The DiMAGE E-223 uses Video AF to focus. Camera-to-Subject distance is calculated based on CCD output where the subject image is captured (TTL CCD AF system).
Sep 19, 2005 | Konica Minolta DiMAGE E223 Digital Camera
Type of AF
The DiMAGE E201 uses Video Auto Focus. Camera-to-Subject distance is calculated based on CCD output where the subject image is captured (TTL CCD AF system).
Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
What autofocus modes does the DiMAGE A200 employ?
AF single or AF continuous can be selected. In AF single mode, focus is calculated and set when the shutter-release button is pressed partway down. This mode is mainly useful for a stationary subject. In AF continuous mode, camera continues to focus on a moving subject even when the shutter-release button is pressed partway down. It is convenient to capture the moving subject. Full Time AF that continues focusing without pressing the shutter-release button can be used in both AF modes.
Sep 15, 2005 | Konica Minolta DiMAGE A200 Digital Camera
What autofocus modes does the DiMAGE A2 employ?
AF single or AF continuous can be selected. In AF single mode, focus is calculated and set when the shutter-release button is pressed partway down. This mode is mainly useful for a stationary subject. In AF continuous mode, camera continues to focus on a moving subject even when the shutter-release button is pressed partway down. It is convenient to capture the moving subject. When setting spot focus point in AF continuous mode, subject tracking can be used. (Subject tracking can be turned on/off by the recording menu. ) When selecting the Spot Focus Point, Full Time AF can be used*. * Full Time AF can be turned on/off on the setup menu. * Sensors mounted on the grip and on the eyepiece detect when the camera is held.
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
Cameras Logo
237 people viewed this question
Top Konica Cameras Experts
myxelpyxel
Ekse
Lawrence Oravetz
Are you a Konica Camera Expert? Answer questions, earn points and help others
