Question about Refrigerators
Whirlpool GS5VHAXWY00 25 cu. ft. side by side contour door - in door water has stopped flowing. Refrig is 6 months old. Water still flows to ice maker.
  • 1,998 Answers
When you push the button inthe front of the machine it should give power to the valve in the back of the machine .check the valve in the back of the machine where the water line connects to make sure there is no blockage in the line next thing to check is if your getting power to the valve on that side of the valve that the water is connected
Posted on Apr 29, 2010
I have know water for drinking only drips
Have you changed the water filter lately? They need to be changed every 6 mos. They clog up and restrict water flow to your dispenser at the door.
Apr 18, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
The h2o light on display had no colour then turned blue now gone red fridge only 7 months old but have lost manual
The filter/water system is designed to change colors after 6 calendar months, the system does not count the flow of water (unless you have the smart valve unit that measures water). Either way, you can either reset the filter by holding the filter button for 5-10 seconds or replace the filter and hold the filter button then.
Good luck
Jul 13, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
My whirlpool stopped making ice cubes , water dispenser is o.k. and water to ice cube pan (rubber tube) won't stop running (leaking)
You are going to have to check the water solenoid to see if it is operating correctly. The solenoid operates from the AC power through a micro switch on the rotating cam. When the switch operates the solenoid is jerked out and allows water to flow. When the switch opens (timed to fill up the ice tray) spring pressure snaps the solenoid shut blocking the water flow. If the solenoid valve sticks in the open or partially open position, it allows water to leak by.
Jan 09, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not producing ice,already check the basic problems,
The water tube to the icemaker inside the refrig maybe frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 05, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Ice maker has stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
689sshg
May 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
heatman101
sfhgsyw54
Mar 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
3 month whirlpool refrig. whole system seems to be shutting down.
You most likely have a bad pc board. If I were you I would call Whirlpool and have them send a technician out and fix it under warranty. The number should be on your paper work that came with unit. If not, call 1-800-555-1212 and ask for the number. I could try to help fix but if you mess with it, the warranty will be voided.
Oct 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker doesn't work
Is the filter blocked? If you have not changed it recently (usually every 6 to 9 months) then it will prevent water flow. If this is OK then this is usually caused by the control module or water inlet valve going faulty and will need a service engineer visit. Also check for anything blocking / jamming the auge.
Aug 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water not flowing to make ice and to door both not working?
Is the filter blocked? If you have not changed it recently (usually every 6 to 9 months) then it can prevent water flow and start to build up bacteria very quickly - which may cause stomach upsets etc. If this is OK then this is usually caused by the control module or water inlet valve going faulty and will need a service engineer visit.
Aug 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
126 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
