Question about Roper RAX4233PQ Top Load Washer
Wont fill with water? work 4 2yrs - Roper RAX4233PQ Top Load Washer
  • 1,998 Answers
First you have to check the valve in the back of the machine sometimes people that are on well water get deposits that build up on the inside 2nd you would have to check to see if you have power going to both sides of the valve . you do this by removing the entire washer cover. If you do not have electrical experience in testing for voltage please call a technician the valve is what brings the water into your unit
Posted on Apr 29, 2010
My washing machine wont fill up with water, what would the problem be, ive cleaned the hose at both ends so its not blocked?
usually the hot and cold water solenoid fail stopping water to flow
replaceable part
location
in where the hoses attach to the washing machine
May 09, 2016 | Washing Machines
My maytag atlantis washer wont work on clld water only works on hot why is that?
It could be the screen is plugged on one end or other in fill house,or water fill selenoid the part where your water fill hoses connect to washer.Hope this helps or let me know and we will try something else.
Aug 08, 2013 | Washing Machines
Kenmore 800
the height of the drain hose the higher the hose gets above the washer the higher the water will fill up to
Aug 02, 2013 | Dryers
Fills with water but wont stop filling and wont change to different cycle just keeps filling
check water pressure, it need to be about 20psi. also remove fill hoses and check the screens for dirt. clean it if necesary. also check water valve at fill hose connection. it has screens also. clean if needed. if all is ok then replace water valve.
Feb 07, 2011 | Washing Machines
Maytag pav2300 wont stop filling up. New timer
After the water fill, Switch off the mains, allow little water bleed through the hose that goes to the level switch. As the water flows try fixing into the level switch block.
Clean the water drips to dry and switch on the m/c. It should be alright since you say that the switch is OK when air is blowed!
Apr 01, 2010 | Maytag PAV2300 Top Load Washer
Ice maker wont fill.water dispenser on door is working
Could be the filter. Can you bypass the filter? How about the incoming water line. Is there presure there?
Aug 26, 2009 | Frigidaire FRS26R4A Side by Side...
IT wont start washing
if it fills with water or has filled and wont go any further then suspect the door switch< latch assembly has switch> if it doesn't fill then possibly water valve not working,if neither of these seem accurate then please give more info
Apr 20, 2009 | Kenmore 42822 Front Load Washer
Diswasher wont fill
Faulty fill valve?
Timeing out with insufficient flow of water?
Hot water to hot and locking up valve?
Apr 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Wont call for water
Is the valve behind the refrigerator opend?
If yes, you intake water hose can be frozen, if so, defrost the fridge manualy.
Dec 10, 2007 | LG LRSC26910 Side by Side Refrigerator
Roper RAX4233PQ Top Load Washer Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
