Question about Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator
Pan/drain under the coils in the freezer is frozen over.
The pan/drain under the coils in the freezer is frozen over within 30 days. I defrost it and blow out the drain hole, and it just freezes over.
I added a drain strap kit to the drain hole (alumnium piece that attaches to the heater coil and goes down the drain), but didn't help.
Help!
  • schraub_acct Apr 30, 2010
    I have already tried the recommendations from the other expert: defrost the drain pan, clear the drain hole and tube, and add the hot wire down the drain hole.
    Are there any other recommendations?
  • schraub_acct May 01, 2010
    How do I know if it is the drain that is clogged?
    Or if the heating element just isn't working long enough to melt everything and keep it cleared out?
    Thanks.
  • 6,927 Answers
You will have to clean the drain,bits and pieces of crumbs lodge in the drain,and then the water from the coils from the defrost timer melting the ice from the coils is supposed to run down the drain,to the bottom of the unit,but it is freezing after it melts from the coils,cause it can not drain. melt the ice with hot water,and you may have to use compressed air,from a air compressor to clear it out,then it should work fine, I hope this was helpful,if so,please let us know,thank you.
Posted on Apr 30, 2010
  • Ronny Bennett Sr.
    Ronny Bennett Sr. May 01, 2010
    something is melting the ice from the coils,and is forming under the coils,because it is not draining
  • 4,070 Answers
Here's how I clean them out. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help to kill any mold growing in the lower end.
Make sure it drains quick enough to prevent refreezing by pouring it full of water. It should drain fairly quick. If it's still slow to drain, try to gently pull it from the pan underneath the fridge to see if it's kinked. If it still freezer try a copper wire strap and make sure the upper end is in a position to get hot during defrost.
Posted on Apr 28, 2010
  • Charles T Nevin
    Charles T Nevin Apr 30, 2010
    When you fill it with water does it drain clear in a few seconds or does it take several minutes.
    Is there any water in the tray under the fridge where the water drips to.
  • Charles T Nevin
    Charles T Nevin May 02, 2010
    It it doesn't drain when you pour water in the drain tube it's stopped up.
Why water under crisper ..Frigidaire top freezer
You have a frozen or stopped up condensation drain line. Disassemble freezer to access evap coil and defrost ice in drip pan and drain line. You probably should replace the thermostat(cold control) if it hadn't been set to the coldest setting or if the fridge hadn't been opened for a long period of time prior to this problem. If the drip pan and drain aren't frozen then blow out the drain line with hi pressure air
Jul 23, 2015 | Refrigerators
Sanyo side by side door fridge is not defrosting, what to do?
bonjour,
Trouble comes in 3's
If there is never any water in the drip pan under the refrigerator it is not defrosting and the evaporator drain line may be stopped up. Side by Side refrigerators cool the freezer first and send a small amount of cold air to the refrigerator side. To start defrost the defrost timer stops the compressor and all fans. Next it turns on the defrost heater. This melts the ice/frost off the freezer coils. The water drips down the drain line to the drain pan under the unit. If the defrost heater raises the temperature too high the defrost termination thermostat turns the heaters off. When the defrost timer finishes it turns off the heaters and turns the compressor and fans back on. If the drain line clogs with food the water does not drain out and when the compressor starts again the water freezes. If this keeps happening the ice gets higher and bigger until it clogs the coils and the freezer does not get cold. If the defrost termination thermostat turns off the defrost heaters too soon all the frost is not melted from the coils. And the coils soon clog and the freezer gets too warm. No defrost usually means either a bad defrost timer, a clogged drain line, a bad defrost termination thermostat or some combination of the three.
If the drain line is not stopped up you can try this.
Remove all food from freezer and refrigerator, open the doors and unplug the cord. Wait 30 hours for all the frost to melt.
Keep the doors open and the cord unplugged the whole time. Empty the drain pan to keep it from over flowing. After 30 hours plug it back in and wait for 1/2 cup of water to turn to ice in the freezer. Then you can put the food back in. The problem can return if the unit is not defrosting. Or you can call a service technician.
Jul 11, 2012 | Refrigerators
Ice at bottom of freezer and fridge is over cooling
Check you drain system. If you are mechanical unplug the unit and remove the back cover at the bottom. Locate the drain tube running down to the drain pan. If it is frozen, use a hair dryer to thaw it. If it is clogged with debris, vlean it out. Locate the drain pan under the evaporator coil and pour hot water down the drain until it is clear. Sometimes the defrost element is positioned to far away from the drain pan so carefully reposition it closer to the pan.
Jan 23, 2010 | LG Refrigerators
Water Leak around left front wheel
I would check the defrost drain inside the freezer. this is real easy to do on this model refrig.
  • remove bottom basket (if it isnt frozen in place) and the shelf above it.
  • in th back just below the coil cover in the freezer section there is a ledge that will most likely be frozen over remove this ice using a hair dryer or hot water which ever is conveinant for you
  • you should uncover a drain hole flush this drain with hot water I use a turkey baster or large syringe to forcefully push water thru to clear anything in the drain
  • put it back together and you should be good to go
when ever the unit goes into defrost (which is about twice a day) the water runs over the ledge and then out of the door by the hinge puddling up next to the wheel. this unit has a hard fiberglass drain pan that is built in and unless it has been dropped i cant imagine the drain pan being damaged.
Let me know if you have any other questions Peyton
Mar 07, 2009 | Kenmore 74192 / 74194 Top Freezer...
FREEZER ACCUMULATED WATER FROZEN NOW DRIPPING THRU TO FRIDGE
The drain in the freezer is blocked. Just below the cooling coils is a drain, when the defrost heater cycles on the water is suppose to go down the drain and into a pan under the ref.
Feb 13, 2009 | Whirlpool ER2MHKXPL 22.0 Cu. Ft. Freezer...
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Water on bottom of freezer
most commercial freezers have a drain to the back of the compressor area where the condensate goes into a pan and is boiled off into the air by a loop of hot gas tubing in the pan or an electric heater in the pan. when it defrosts the ice on the coil melts and the water flows out . if the tubing gets plugged the water flows out of the pan and down into the bottom of the box where it refreezes on start of the next refrigeration cycle. clean and clear drain with a shop vac or air hose where water can flow out of pan under the evaporator coil when it defrosts. if you have a domestic residential freezer , most of these have no defrost and neeed to be shut down and manually defrosted every few years. if you leave the door ajar or it doesn't seal well ice builds up and can accumulate in the bottom as frost etc. it would be mosyt unusual for a residential box to have a defrost clock, drain and all, but possible and same rules apply. find the drain and clear with shop vac .
Nov 02, 2008 | Woods Freezers
Ice acculumates in the bottom of freezer
Defrost drain tube is plugged. Drain is a round hole about the size of a quarter below the evaporator coils. (behind back wall of freezer.) Take a turkey baster with hot (not boiling) water and shoot it into the drain hole until water runs through it (into drain pan under refrig.)
Aug 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Bottom of freezer has water dripping into it
A bad freezer door seal causes condensation that freezes at the bottom of the unit. I realize you said the drip pan was full of ice, but if the drain is clogged, that will happen. If that unit has the pan at the very bottom, condensation can also contribute to this.
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator Logo
75 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
