Question about Kenmore 46462 Front Load Washer
Internal breaker? I blew a breaker in the house and now the washer doesn't work...is there an internal breaker in the new front loaders?
  • Rick Ead
    Rick Ead May 11, 2010
    start by making sure you have power to the machine first.Secondly take an extension and plug your washer into a different outlet to check if you dont have a meter if you do have power to the back of the machine the next step would require a technician unless your able to troubleshoot throughout the wiring of the machine
  • 10,319 Answers
You have a shorted out timer contact in your machine. There is no breaker nor fuse in this machiune neither sorry to say. A new timer will fix yours
Posted on Apr 28, 2010
My GE Washer has no power. There is power at the wall. The schematic shows an internal fuse on the Red White RW wire. Can't find the fuse.
the fuse is usually located inside the panel but sometimes elsewhere? along the back side coverd by a plate
Apr 11, 2015 | GE Washing Machines
No power. Will not turn on
It may have tripped the internal breaker, and or the house circuit breaker. Go tot the house fuse box and check that first.
Mar 05, 2014 | Whirlpool Gold GU2275XTVy Dishwasher
Electrolux front loader washer ewd1477 flashing start/pause button. interrupted during wash cycle by power outage. start/pause button now flashes and won't start any cycle.
Try to turn circuit breaker off, or unplug unit, for about 5-6 minutes. This is a hard reset and should reset the internal controls to restart the unit properly.
Dec 29, 2012 | Electrolux Washing Machines
My front loader does not get no water in it
Hello - Washer not filling with water can be caused by many reasons. Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Are the house valves turn on fully? Contact a professional to move forward accurately?
Oct 24, 2012 | Electrolux EIFLW55HIW Front Load Washer...
My kenmore front loader runs, but will totally shutdown, reset, several times, and then quit...I can not get it to run a full cycle, then it trips the breaker, after it appears to trip the internal...
You must be using either too much soap or the wrong soap or simply have items jammed between tubs giving off this phenom. Just a tad of HE soap is all that is needed or else you'll wreck the freight train and make the washer have a cow. The motor will overwork itself trying to fix the over suds detect. If an item of clothing is jammed between tubs the suds error will also pop up.
Apr 27, 2011 | Kenmore Front Load Washer
I have a Pressure Washer with a Comet ZWD 4040 Pump. It recently had a new Unloader Valve fitted. It has suddenly developed a problem, the pressure goes up to 3000psi and then drops back to 2000psi. I...
Derek, Hi and welcome to FixYa. I am Kelly.
I just now happened across your post and note it is 3 months old. Hopefully you already have the problem solved.
If not.. looking at the pump history of having the un-loader valve replaced it sure seems that the current un-loader valve is sticking. When an un-loader valve is removed the internal housing is sanded smooth and everything about the un-loader valve is coated with Lubriplate #105 White Grease. I get the feeling that who ever did the un-loader valve repair failed to sand / clean the housing and use White Grease for the final assembly.
You should remove the valve... Sand the housing and get some Lubriplate #105 white grease (auto parts store) in a tube. Lubricate it liberally and reassemble it. If should work fine after that.
Thanks for choosing FixYa,
Kelly
Sep 15, 2010 | Comet GXD2527G Pressure Washer Pump
F3 error on whirlpool duet front loader
F03 = HEATER SC TO GROUND
The Heater has a internal short circuit.
Short circuit of Heater to Ground.
Measure insulating resistance of heater between contact and housing
(norm. 2 M?).
Replace heater.
Perform test program.
Nov 11, 2009 | Whirlpool Washing Machines
Breaker blew and when flipped back on, microwave didn't work
yes there is a 15 amp fuse that needs to be changed in behind the front control panel
Aug 21, 2009 | Whirlpool MH7140XF Microwave Oven
Simpson front loader won't power up !
that wa the first thing that came to my mind i think your on the right track call a service department give them the make model number of the washer they should be able to help you locate a reset switch if it has one . good luck
Jun 22, 2009 | Washing Machines
Kenmore 46462 Front Load Washer Logo
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
