Question about Whirlpool Duet GHW9150P Front Load Washer
Bellow ##W10111435 whirlpool washer WFW8300SW02.
We own a Whirlpool WFW8300SW02 FRONT LOADER. We now need instructions to install the Bellow part #W10111435
  • 5,911 Answers
The following link explains step-by-step how to change the door bellow on a Whirlpool Duet front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you have any questions about this repair, please post back and let me know. If the link does not take you directly to the instructions I provided, copy and paste the link to your web browser. I hope you find this information helpful.
Posted on Apr 28, 2010
Front door bellow on model wfw8300sw02 replacement
do you need the part number for the door bellow or what do you need
Oct 27, 2012 | Whirlpool Front Tub Seal Bellow 8181850
Tip
Purchased my Whirlpool front loader 4/2004, we are on our 7th bellow, new inner...
This advice is for the Kenmore Elite and Whirlpool Duet FRONT LOADER style washing machines. A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
I hope you find these instructions helpful and good luck to you.
on Feb 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My duet front load washer is licking water in front left side have any idea and how do u take off the bottom front cover
there are three screws under the front of the panel. make sure its not leaking from the door and running that way. if the bellow or door seal is damaged or bent or torn it will leak. please dont forget to rate me thanks
Jun 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hw do I replae the washer bellow seal on a whirlpool duet washer
The following link explains step-by-step how to change the door bellow on a Whirlpool Duet series front loader:
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
I have found these sites to be reputable and provide great service. Prices differ between them, so shop and compare. The first three sites I've listed have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
May 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Seal blown out need to replace
If you are referring to the door seal (bellow), the following link explains step-by-step how to change the door bellow on a Whirlpool Duet front loader:
Apr 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Where do i find directions to change the bellows for whirlpool duet GHW9150P?
If you have any questions about this repair, please post back and let me know. If the link does not take you directly to the instructions I provided, copy and paste the link to your web browser. I hope this helps you.
Apr 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I need to change the bellow on my maytag front loader. Do you have any instructions?
The following link explains how to change the bellow on a Maytag Epic:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
Later models of Maytag washers are manufactured by Whirlpool, so these instructions should apply. If you have any questions, please let me know. I hope this helps you.
Sep 02, 2009 | Maytag EPIC MFW9700S Front Load Washer
If I replace my bellow seal in my front loader will it leak?
It will not leak if you install it correctly. Click on the following link for step-by-step instructions on how to replace a door bellow:
Inspect the new bellow PRIOR to beginning installation. Make sure the inner clamp that attaches to the wash tub is snug and not overtight. Also, make sure the rubber on the bellow that fits over the dispenser tube in the door area is installed past the flange (raised area on the tube). These are the common points that leak. Please let me know if you need further assistance. I hope this helps you.
Jul 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
How to replace the door bellows seal ?
I need some one to tell me how to install the rubber seal on a bosch maxx Eurowasher front loader washing machine. Part of the seal ripped off so water leaks out. Its only 6 months old and its not covered by warranty.
Jan 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,636 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
