Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Picture won't come. Started and when changing to PIP and activating the picture will show on one of the split windows. This does not work anymore.I have audio till channel 25. The screen sometimes open all green and sometimes gray. 4 months ago I got a technician fix pretty much the same problem.
  • heribertoped Apr 29, 2010
    I do appreciate the advise but last time $370.00 lasted four months,now if I call him again another
    $300-350 and who knows for how long.For the same amount I can get a new 50' plasma. I wanted to fix it because I liked very much this rear projection,it was very clear and crispy with very good sound.I have another 50' plasma and I mostly prefered to look at my favorite programs on this one.
    Thanks for taking the time to answer.
  • 438 Answers
Your tech may not have found the underlying fault that caused this problem for you to begin with, your tech may be the best solution for you as they already know the fault and he must diagnose a little further into the circuit to find out why the component is failing for a 2nd time.
Posted on Apr 28, 2010
Testimonial: "Thanks again falspet for the answer. I do have digital and analog multimeters,soldering iron with supplies,don;t have a shop manual, about basic skill"
  • Fal Mueller
    Fal Mueller Apr 29, 2010
    i`m sorry but to be able to help you further you must have some test equipment like a digital multimeter, a basic oscilloscope and isolation transformer soldering iron and supply's and quite seriously a shop service manual and also some basic skills in electronic servicing.
    if you are in this category lets begin to trace your fault down and repair it...
  • Fal Mueller
Split screen
either you have the PIP engaged (two different pictures) or if same picture twice a digital issue in the set.
Look for PIP and turn it off or if a swap button see if it swaps the pictures--will tell you if PIP is issue or not.
Jun 07, 2012 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
How to split my screen on my 60 inch LG plasma TV? My wife would like to watch a show while I play my PS3 at the same time?
Unless the set has a PIP feature (picture in picture) you cannot do it.
PS3 would be hooked to one input (selected for PIP) and tuner in set for the main picture.
Mar 12, 2012 | LG Televison & Video
Please tell me lg factroy setting codd
Hello
I don't understand your post. About what settings you wants to get it to its factory settings or its lost password problem!. If the password probelm,
If you ever forget your password, key in '7', '7', '7', '7' on the remote control
If picture settings must be set to factory settings do the following.
Reset is unique to each function: Manual config., Position, Split zoom, PIP position
and sub picture size for double window.
- Use the Reset option to initialize the adjusted settings.
Press the MENU button and then use [up/down] button to select the SCREEN menu.
2. Press the [=>] button and then use [up/down]button to select Reset.
3. Press the [=>] button.
• You can initialize Position, Split zoom, PIP Transparency, PIP position, PIP size
OK.
Mar 15, 2011 | LG RU-42PX10 42 in. HD-Ready Plasma...
PIP function does not work, the settings is greyed out also! I have a wii, PS3 and freesat :)
Hi nikkicollier,
PiP for your TV works between two different sources. This means between a component source and an HDMI source or between an HDMI source and another HDMI source. PiP also works with a PC connection, e.g. when using the TV as a computer display. PiP does not work between two component sources. The setting will be grayed out when you don't have a configuration that is supported, as the Samsung TV's are usually able to automatically detect which sources are plugged in and available.
I'm not exactly sure what sort of configuration you want your PiP to work in, but try one of the following configurations.
  • TV Cable (through VCR or other via Component input) with Satellite in PiP (via HDMI input)
  • PS3 (via HDMI Input) with Satellite in PiP (via Component Input)
  • Wii via HDMI Input) with PS3 in PiP (via HDMI Input)
You can usually find an HDMI cable for much cheaper at an electronics supplies shop, Radio Shack, or on eBay or Gumtree.
To change your PiP settings:
  1. Press the MENU button on the remote control. Select Picture and press Enter.
  2. Select PIP and press Enter.
  3. Press the enter button again, and press up or down to change the setting to On and press enter again.
    Note:
    If PIP is activated the screen will display in widescreen (16:9 aspect ratio.)
  4. Press the up or down buttons to select the Source then press the Enter button.
    Select the source of the sub-picture by pressing the up and down arrows and then pressing the Enter button.
    Note: The sub-picture can serve different source selections based on the what the main source is set to.
    Note:
    You may notice that the picture in the PIP window becomes slightly unnatural when you use the main screen to view a game or karaoke.
You can download the full PDF manual for your TV here (large download at 26MB.) Much of the PIP information can be found on pages 13 and 14.
Good luck, I hope that helps.
Mar 01, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
How do you split the screen to watch two different shows at once?
to watch two defferent channel in one screen,u just need to activate the PIP feature of you tv..PIP means picture in picture.
May 20, 2010 | Pioneer Elite PRO-111FD 50 in. Plasma TV
First of all...i have a 60" standard definition mitsubishi tv...i know its old but for some reason all the video only shows up on the left side...is there anything i can do to fix it?
Hello. Thanks for selecting fixya! Many models of this TV offer you PIP (Picture inside Picture) and POP (Picture outside Picture) for your convenience. You can also split the TV in half with one channel on one side and another channel on the other side. It is possible that you might find a fix to your problem by experimenting with your PIP and or POP buttons on the remote. Good luck with it.
Nov 05, 2009 | Televison & Video
The tv screne picture on my insignia tv is off centered and is split in two
I suppose your TV has a PIP function.
  • check if u have a PIP function on your remote control or
  • Go to the Menu n in the display see if u can see the PIP function or the Aspect Ratio function like 4:3 or 16:9.
  • You have to switch it to standard or normal view to change to one full picture.
Jun 04, 2009 | Insignia NS-LCD19 19 in. LCD TV
Picture-In-Picture does not work (32" LG LCD)
my friend told me that if Tv is purchased from Canada will not work in Saudi Arabia but why?
Mar 18, 2009 | LG 32LG30 32 in. LCD HDTV
Ilo problem
What I hear you saying is that your main television tuner shows lines only while the PIP is functioning properly. The PIP works by using a separate tuner from the main tuner of your television (like a vcr tuner). Since the PIP works then it appears that your main tv tuner is not working anymore. It will probably have to be replaced. I recommend looking at our online technician list for a professional near you.
Good luck :)
Jun 20, 2008 | iLO 3200 32 in. LCD Television
Pip position
Hi there
The PIP ( picture in picture ) is only to determine where the Menu block itself will show on your screen.
Try the Vertical and Horisontal shift in the Menu Options.
Oct 23, 2007 | BenQ PB6100 Multimedia Projector
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
113 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
