Question about Acer H233H bmid Monitor
I seem to have a 1 inch black order around my screen once i set it to recommended settings, i also am using my DVI port so i cant and wont use that for my port. Any fix?
  • 61 Answers
Try different setting that works.
I set my monitor to the settings that pleased me!
Posted on Apr 30, 2010
Monitor has permanent vertical bars down the right side of the display
Hi there! If you've ruled out any "bad caps" as well as tested both the VGA & DVI inputs, then I would speculate that the actual screen itself has gone bad. If this is indeed the case, then I'd recommend popping for a replacement monitor. By the way, if you own a mid-sized flat panel LCD TV which has HDMI ports on it, you can use that for your monitor instead.. If your video card on the computer doesn't (natively) have an HDMI-out jack, then you can order a "DVI-HDMI" adapter on-the-CHEAP at www.monoprice.com. -- That's where I get all my "specialty adaptors". They truly have the best prices around!
I hope I've helped you at least a bit! I wish you the best of luck!
HDMI Cable Home Theater Accessories HDMI Products Cables Adapters Video...
Jun 22, 2017 | Dell 2007Fpb Computer Monitors
Dual monitors t3516
Is it just like this with NO graphics card installed?
http://products.pacificgeek.com/emachines_t3516_celeron_d_3_20ghz_512mb_120gb_cdrw_dvd_xp_1013070674.php
If so, Not happening.
The I/O area is to the left side. (Input/Output area)
In this rectangular area you see;
1) PS/2 mouse port, and PS/2 keyboard port, at the top.
2) Orange port below them.
3) Black port below it.
4) Down below all of the above is the blue VGA port.
If you do not have a graphics card, your monitor is plugged into this blue VGA port.
If so you are using Integrated Graphics. Another term used is OnBoard graphics. ON the motherBOARD.
Do Not try to use a splitter cable, and run two monitors off of this VGA port. Ain't happening.
See the four long slots at the bottom of the computer? The bottom one has the Ethernet adapter card in it?
A graphics card, (Video card. Same/same), is installed on the motherboard, and the end of it sticks out one of those 3 unoccupied slots.
Each of those slots are known as Expansion Bay Slots.
When you choose what slot you want, you remove the Expansion Slot cover, for that slot.
My sources indicate the motherboard is an Intel D101GGC motherboard,
http://www.e4allupgraders.info/dir1/motherboards/socket775/D101GGC.shtml
There are 2 white PCI slots at the bottom.
There is 1 black PCI-Express x1 slot above them.
There is a longer black PCI-Express x16 slot above it.
The PCI-Express x16 slot is for a graphics card. It is the best graphics card slot on your motherboard.
(The white PCI slots are lame. The PCI-Express x1 slot, is NOT used for a graphics card)
Suggest you use a PCI Express graphics card for your computer, and run two monitors at the same time.
From here it depends on what the two monitors are. Do you have two monitors that use a VGA cable?
Example of a VGA cable, and a VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
Or do you have a monitor that uses a VGA cable, and a monitor that uses a DVI cable?
Example of DVI connectors,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
Or do you have one monitor with a VGA cable, and a monitor that has a DVI cable?
Post in a Comment as to the monitor manufacturer name, and model number.
[ For example I am using an HP 2009m (20 inch widescreen), and a 26 inch RCA EN-V HDTV, as dual monitors ]
This is an example of a very economical PCI Express graphics card, that will run dual monitors,
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130755
You can use a monitor with a VGA cable (Blue port), and a monitor with a DVI cable.
You can use two VGA monitors, with using a VGA to DVI adapter, for one of the monitors.
You can use two DVI monitors, with using a DVI to VGA adapter, for one of the monitors.
Already have a graphics card, and two monitors connected to it?
1) Right-click on an empty area of your desktop screen.
2) At the bottom of the list left-click on Properties.
3) In the Display Properties window, left-click on the Settings tab.
4) Left-click on the rectangular monitor icon, that has the 2 in it.
5) Go below to the left, and left-click on the empty square next to-
Extend my Windows desktop onto this monitor
6) Go below to the right, and left-click on Apply.
7) Go below to the left, and left-click on OK.
Your desktop screen is on your second monitor.
Need guidance past this post in a Comment.
Regards,
joecoolvette
Jun 09, 2012 | Computers & Internet
I have a Dell Inspiron 531S, I have both two different monitor slot, does my PC support dual monitor systems?
Yes.
The area on the back of the computer, that has two ports to connect a monitor, is a Graphics Card.
It is a PCI-Express graphics card, and is plugged into a PCI-Express x16 slot on the motherboard.
(Expansion Slot)
It has a blue VGA port, white DVI port, and black S-Video port.
The area on the upper left with a blue outline around a VGA port, is a VGA port connected directly to the motherboard. It is Integrated Graphics.
You CANNOT use Integrated Graphics, and a graphics card at the same time.
It's either use the Integrated Graphics VGA port, OR use the graphics port/s on the graphics card.
BIOS will Not support using both Integrated Graphics, and a graphics card.
HOWEVER, you can use the VGA port, and the DVI port when using two monitors.
You will be only using just the graphics card.
Example of a VGA port, (Connector), and VGA cable,
Example of a DVI port, and DVI cable,
http://en.wikipedia.org/wiki/DVI_connector
1) Whatever monitor you have that has a VGA cable, plug it into the blue VGA port on the graphics card.
(There are VGA monitors {CRT} that resemble a small TV. VGA cable is usually attached.
There are also LCD flat screens that have a VGA connector, for a VGA cable, and may also have both a VGA, and a DVI connector.
To digress for a moment;
VGA is Analog. It uses an Analog video signal.
DVI is digital. It uses a Digital video signal.
A computer naturally puts out a digital video signal. This digital signal has to be converted by the computer, into analog for an analog monitor. This slows the graphics process down. This is one reason it is best to use digital )
2) Plug a monitor with a DVI cable into the white DVI port on the graphics card.
3) Turn the monitors on.
4) Turn the Inspiron 531s on.
5) When Windows has loaded, right-click on an empty area of your desktop computer screen.
Now left-click on Properties at the bottom of the list.
Left-click on the Settings tab.
6) You are now looking at a small window that has two monitor icons in it.
Monitor 1 icon, and monitor 2 icon.
Monitor 1 icon is your Primary Display.
Monitor 2 icon will be for the Secondary Display you are adding.
Note how monitor 1 icon is sitting to the Left, and monitor icon 2 is sitting to the Right.
This is how your monitors are supposed to be arranged on your computer desk.
If the second monitor is on the Left on your computer desk, you need to move the icons around.
Move monitor 2 icon to the Left.
Left-click on the icon, hold the left mouse key down, and drag the monitor 2 icon over to the left side of monitor 1 icon. (All the way over, or it will snap back to where it was)
It may matter to you how your monitors are arranged. It may not. Once you read the following it may help you decide.
7) Left-click on monitor icon 2 if you have not already done so.
Go down to where it states, "Extend my Windows desktop onto this monitor"
8) Left-click once in the empty square, to the left of Extend my Windows desktop onto this monitor.
9) Now left-click on Apply at the bottom Right corner.
10) Finally left-click on OK at the bottom Left corner.
You should now see your desktop screen on both monitors.
When using the internet on both monitors, you have to drag the screen from the Primary monitor to the Secondary monitor.
Go to the left side of the screen. Left-click right on the edge of the blue frame. Hold the left mouse key down after you click, and drag the screen across to the left.
Doesn't work?
Go to the right side, click on the blue frame, and drag the screen to the right.
This is why it may matter how the monitors are arranged on your computer desk.
It's kind of eerie your first time dragging the screen across.
You will also find out why it is best to use two similar monitors, when using dual monitors. The pixel resolution is different for both monitors, if they are different from each other.
For additional questions please post in a Comment.
Regards,
joecoolvette
Just to add:
http://support.dell.com/support/edocs/systems/inspd531/en/OM/appendix.htm
Aug 15, 2011 | Dell Inspiron 531s Desktop Computer
Connect the hdmi out put of a bush hd set top box
its telling you that you cant use the format that your source is set up for .. like 1080P wont play on a monitor that wont support that ..also hdmi requires an exchange of information between units before it will allow 1080 resolution (thats to prevent recording of high resolution material) the adapter may block that exchange .. if you set the source to 720 or less resolution then its likely to start working .. problem is .. if you cant see it how do you set it .. if your remote has an obvious button for that then you can just try selecting different modes and wait 10 seconds to see if it works .. if its not obvious then perhaps you can temporarily use svideo or composite in order to set up the source machine ..
Jan 27, 2010 | Televison & Video
Can i hook my acer aspire laptop up to my big screen tv and watch movies on it?
If you have a DVI port built in that will give an output resolution that will look good on a big screen. Standard VGA out will not look so great on an big screen - probably blurry and low detail on menus and text without changing settings.
If you do not have a DVI you could look at a ExpressCard with DVI out or and Dock solution that has DVI- http://tinyurl.com/ya6ftfe
Sqeeksquad has recommend to me once a Expresscard solution that will allow you to add PCI-Express video card but this was fairly expense as would have been half way to a new laptop.
Jan 01, 2010 | Acer Aspire 5500 5570-2609 Laptop
L.C.D stopped running my P.c
TRY A NEW VGA CABLE ,,,,,
May 14, 2009 | Computers & Internet
I would like to connect my Sanyo PLV-Z2 project to a DVD player with HDMI output in order to higer quality. I used a HDMI->DVI cable and connected DVI to Z2. I set the input 2 as RGB-HDCP. However it does...
I have the same unit (2 of them actually.) I have spent a lot of time on this very issue. The problem is that although the unit is "supposed" to be HDCP (digital copy protection) compatible, it is not fully. I've found that with some DVD players it will work for a minute or two and then go black, and with others, it will flash on and off, and with some it will never do anything but black. I have only found 2 ways around this. 1 is to use a computer (which does not use the HDCP) windows Vista/windows7 might have the same problems, but XP/2000/Linux work perfectly. The other solution that worked was to use a Playstation3 which seems to work perfectly with it playing DVDs and BlueRays.
Feb 23, 2009 | Sanyo PLV-Z2 Multimedia Projector
I just received a (refurbished) Pavilion Elite m9350f. During setup, I attempted to connect my old VGA monitor. It would only be recognized by using the adapter for the one DVI port. When it was hooked up...
plug monitor into VGA port, start machine, go into the bios settings and load optimised defaults press F10 then reboot, if the problem persists its your graphics card or monitor
Nov 13, 2008 | Computers & Internet
Annalog power safe mode
Could be a could a couple of things
#1 Ensure the video cable is connected to the correct jack on the tower (Some systems have both an integrated video card and an Expansion card. See if there are 2 blue 15 pin vga ports, if there are 2, connect to the other one.
#2 You may be using DVI (White connection) and have the imput select set to D-Sub (Analog) Use the input select button on the monitor to sleect DVI
Jul 06, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Problem with DVI Port
to fix that problem you have to switch to DVI input.but you will not recieve sound.
Oct 21, 2007 | Protron PLTV-37 37 in. LCD Television
Acer H233H bmid Monitor Logo
71 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
