Question about Dell Wireless Keyboard Optical Mouse w0147
How do I resync my bluetooth wireless mouse to the laptop
  • irish2535
    irish2535 May 11, 2010
    What brand/model is your mouse?
    Problem Solver:
  • 9 Answers
Check on the sides/bottom of the mouse and there should be a small button. Press the button and it will re-sync your mouse and should take care of the problem. Let me know if this works or if I can help further.
Posted on Apr 29, 2010
How to connect to laptop
Using a wireless mouse with a laptop is a convenient way to avoid using the laptop's built in mouse.
Moreover, even if you use an external mouse, carrying a wireless mouse is easier than the wired version.
Here is how to use a wireless mouse with a laptop.
Ensure that your laptop is compatible with a wireless mouse.
Most wireless mice use Bluetooth technology.
Any Bluetooth enabled laptop can connect to a Bluetooth wireless mouse.
Unpack your mouse and insert batteries to the battery chamber.
While doing so, make sure that the positive side of the battery is inserted into the positive niche in the compartment.
Place the mouse in a way that makes it easy for you to use and less stressful for your fingers.
Use a wireless receiver if your laptop does not have an built in wireless receiver (either Bluetooth or 802.11b).
It should be kept at least eight inches away from the laptop or any other object that would cause any interference.
Insert the drivers, if any, for the mouse to function properly.
Connect your receiver to the laptop by plugging in the mouse's USB connector to the USB port of the laptop.
If you do not have any free USB ports, simply use an external USB hub for more ports.
Apr 20, 2013 | HP Wireless Optical Mouse
How to install wirless mouse
It depends on the wireless technology used by the mouse.
1. Infrared
If your mouse used Infrared for communicating with your PC, you will have to place an Infrared receiver on your desk, in line with the mouse you want to install. You will definitely have to install the drivers supplied with the mouse/Infrared receiver.
2. Bluetooth
If the mouse uses Bluetooth, first you either will have to install a Bluetooth dongle on your PC/Laptop (if it doesn't have Bluetooth integrated) or activate the Bluetooth on your PC/Laptop. Then, using the Bluetooth software supplied with the dongle or PC/Laptop, search for new devices and choose the mouse to pair with. You may have to install the software provided with the mouse for if to work.
May 09, 2011 | Computers & Internet
It doesnt work wat so ever every time i log in the crusor get stuck in the middle of the screen
sounds like a mouse issue,
wireless mouse replace the battries and resync with the module,
non wireles mouse ensure its plugged in...
if those dont work its most likely internal to the mouse and needs to be replaced.
Jun 11, 2010 | Dell Inspiron E1505 Notebook
My mouse logitech V220 just keeps darting all over the place when typing
Resync the Mouse... there maybe a button on the bottom of the mouse to resync with the wireless adapter. Or simply switch USB ports and it will reinstall and that should correct it :)
Jan 01, 2010 | Logitech V220 Cordless Optical Notebook...
Synchronize new wireless mouse with my laptop - both Mac
Go to system preferences then to keyboard and mouse then click on the bluetooth tab, at the bottom right of the screen is "Set Up New Device" click on this and the Bluetooth Setup Assistant will come up. Follow the instructions and you will be able to setup your mouse. Hope this helps.
Oct 17, 2009 | Apple Wireless Mighty Mouse
Add a mouse
Yes.
Most wireless mice come with a small wireless USB dongle that you plug into a USB port.
If your laptop supports bluetooth, you can get a bluetooth mouse, and you wont need to plug anything into your USB port.
Have a look at the logitech nano mouse.
May 24, 2009 | eMachines E620-5885 Notebook PC
How to connect blue tooth mouse to dell inspirom 1520
Hold on... are you sure that you have a bluetooth mouse or do you have a wireless mouse with "pen drive" like dongle? If it is with a dongle, it probably is a common wireless mouse which operates on its own wireless frequecy. You may have a driver CD that comes with the mouse or it simply works "plug and play". However, there are bluetooth mouse too, in this case you just need to turn on your bluetooth on the PC and pair the mouse with your PC just like any other bluetooth device. In either case, a LAN card in not involved. Hope this helps.
Apr 04, 2009 | Dell Inspiron 1525 Notebook
Bluetooth
usally laptops have bluetooth not desktops ,,,,bluetooth is not the same as wireless ,,i know they work similar bluetooth is for short distance...when u set a blue tooth mouse up u must have bluetooth usb plugged into ur computer ...that usb adapter will act as your mouse connection ......
Dec 09, 2007 | Microsoft Wireless Optical Mouse
Dell Wireless Keyboard Optical Mouse w0147 Logo
391 people viewed this question
Alun Cox
