There is no sound from my computer there is a picture of headphones when i press the volume button but no sound
  • 54 Answers
Go ahead and refresh the sound drivers from device manager. see if it works or not.
Posted on Apr 29, 2010
No sound on computer
hi nina.this could be a lot of reasons why you have no sound.
Update the audio driver using Device Manager as follows:
  1. Connect to the Internet.
  2. Click Start , and type device manager into the Start Search field. ...
  3. Double-click Sound, video and game controllers. ...
  4. Right-click the name of the audio device listed under Sound, video and game controllers.
  5. Select Update Driver Software...
  6. If your computer is having problems playing sound, try using the Playing Audio troubleshooter to fix the problem. It checks for common problems with your volume settings, your sound card or driver, and your speakers or headphones. ... Under Hardware and Sound, click Troubleshoot audio playback.
  7. If you hear sound through the headphones, the sound hardware on the computer is working, and the issue is probably related to the speakers or speaker cables. Disconnect the headphones and reconnect the speakers. When done, test again forsound using the same steps as above with the volume control slider.
  8. If you are running Microsoft Windows, make sure the speaker setup is correct by following the steps below. Select Hardware and sound or just Sound in the Control Panel window. In Windows XP and older, click Manage audio devices under Sound. On the Playback tab, select your speakers and click the Configure button..
  9. or go to this link if you need mote help.
No sound on computer Google Search
Nov 05, 2017 | Computers & Internet
Tip
How do I make my iTouch Louder
<p>He the volume of the iPod Touch can be affected in some way, the definition of musical sound check the volume limit set in the settings device preferences. The tool of sound check, which can also be found on iTunes, check your iTouch music and video library for the stabilization of the equalizer song for a constant level, the volume limit reduces the volume to grow beyond a set point, which helps the potential adverse effects of hearing loss caused by loud music. <br /> <p><br /> <p>1. Press the button to the left of the iPod Touch. The volume switch top left of the iPod Touch increases the sound volume, and gives a volume icon on the screen as it grows. Accident on the volume button for the iTouch, it seemed sound problems. Touch the "Music" icon to start playing the song, press the volume for music to grow. <br /> <p><br /> <p>2. Adjust the volume control settings. Tap Settings on the iPod screen Touch, Touch "Music" and tap "volume limit." Slide the tab to the right of way to reduce the volume bar to change the limit of the maximum. Press the Home button to save and Settings. <br /> <p><br /> <p>3. Sound Check off. Tap "Music" in the Settings window and slide the guide Sound Check to the left to the sound check feature off. A Sound check song keeps playing very hard at the same level. While the function prevents sudden jumps in volume, can also lead to a series of songs to play very soft, depending on the quality of the music. <br /> <p><br /> <p>4. Adjust the volume to your headphones. Press the "+" button on your Apple headphones, the volume of a music or video playback to increase. If a song or video does not play, the volume control adjusts the volume on the iTouch. <br />
on Aug 05, 2011 | Computers & Internet
Why can't I get sound on my tablet?.
There are a few ways to solve this problem.
Firstly, turn the device off.
2. Make sure your headphones are plugged ALL the way in (you should hear a click sound)
3. Press the on/off button and the volume up button at the SAME TIME
4. Once the screen is on let the on/off button go
5. DO NOT let the volume up button go
6. Wait until the tablet has finished loading all settings up.
7. Let volume up button go.
It should work now.
Jul 03, 2015 | Compaq Presario 700 470024-192 Notebook
Volume too low
are you using the monitor's volume or are you using speakers? If its monitor volume, I would say go into the main menu of the monitor by pressing the menu button. Then go to the volume setting and raise the level. If the volume level is already on the highest, you may want to consider using another solution to monitor sound, such as speakers or headphones connected to your computer.
Oct 18, 2012 | ASUS Vw223t 22" Widescreen LCDFlat Panel...
My view sonic monitor has no sound
Troubleshooting Sound Issues Verify that the audio cable is connected to the AUDIO OUT or LINE OUT output on the Sound Card and plugged into the AUDIO IN or LINE IN of the Monitor.   Make sure there are no cables connected to the Headphone Jack (located next to the AUDIO IN port) on the monitor. If there is, please disconnect that cable and try the speakers again. Connecting a cable to the Headphone Jack disables the speakers. If there is no cable connected into the Headphone Jack, test a pair of headphones into that jack to see if you can hear sound out of the headphones. If you are able to hear sound out of the headphones, disconnect the headphones and try the speakers again.   Verify that the Mute on the monitor is not on or the Volume is not turned down.    Verify that the Mute on the computer is not on or the Volume is not turned down.<    If there is still no audio from the monitor's speakers, connect the Audio cable to another audio source like a portable CD player or tape player headphone output. If audio can be heard through the monitor's speakers, then there may be an issue with the computers sound card.    Connect another set of computer speakers (if available) or headphones to the AUDIO OUT or LINE OUT output on the Sound Card. If NO audio can be heard then there is an issue with the sound card. Verify with the computer's manufacturer for additional assistance.   LCD TVs Troubleshooting No Sound from a LCD TV No Sound when using RGB (when connected to a PC) Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the computer. Note: On the N1700W use the GREEN mini-jack; on this model Audio is SHARED between DVI and RGB, there is only 1 audio channel for data connections. The N1700w is designed to take a 1.0v RMS audio signal for optimal sound quality.   Confirm that both the LCD TV Mute and Windows Mute are off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the monitor or remote to confirm the Volume is not set to zero.   Confirm that PC volume is sufficient by using Windows/Macintosh Volume adjustment settings.   Try plugging another audio source such as a CD or Cassette Player directly into the Audio port on the LCD TV to confirm the speakers work, or try plugging headphones or external speakers into the sound card on the Computer. If the Headphones or External Speakers do not work, contact the manufacturer of your Computer for further support. No Sound when using S-Video/Composite/ Component Video Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the S-Video, Composite, or Component Video device.   Confirm Mute is off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the LCD TV or Remote to confirm the Volume is not set to zero.   Try plugging headphones or external speakers into the audio port on the S-Video, Composite, or Component Video device. If the Headphones or External Speakers do not work, contact the manufacturer of your S-Video, Composite, or Component Video device.   Note: Some ViewSonic monitors do not include speakers.
Nov 23, 2010 | ViewSonic E70f 17" CRT Monitor
Sound will not play through headphones
Try here:http://www.computing.net/answers/windows- xp/headphones-amp-speakers-switching/55486.html Also:http://www.vistaheads.com/forums/microsoft-public-windows-vista-music-pictures-video/133605-sound-doesnt-switch-automatically-headphones-when-plugged.html Also:http://www.vistax64.com/sound-audio/198039-sound-doesnt-switch-speakers-headphones.html scroll down the page for the discussion.
Oct 18, 2009 | Philips (33-01-031) Headphones
No sound_RCA_model L23W10_Only Ear Phone Jack Provides Sound
Hello... I found the following in the user manual for this TV. Also, some RCA models have a speaker switch on the back of the TV. If none of this solves the problem, your TV may need service. I hope this helps...
Sound problems, picture okay
• Maybe the sound is muted. Try pressing the volume up button to restore sound.
• If using S-Video or Y Pb Pr, remember to also connect the component's left and right audio output jacks to the TV's AUDIO jacks.
• Make sure the Volume option in the Sound menu is turned up.
• Make sure headphones aren't connected to the headphones jack.
Nov 17, 2017 | RCA L23W10 23 in. LCD Television
MacBook Sound Problems
This also happened to me after unplugging some headphones. After reading this, I opted for putting the headphones back in instead of a toothpick. This fixed it.
Sep 11, 2008 | Apple Mac/iMac&iPod Speakers-(Bondie-Blue)...
No Volume
The earphones input are in bad conditions you need to change it,or try put in the earphones and put out until the picture of the earphones go out.
Aug 17, 2008 | Samsung HLN5065W 50" Rear Projection...
Problems changing volume & sound horrible
Your player is flipped. It thinks that it's connected to an external device, and acts as if it in line out output. When outputing to line out, you really don't have volume control, and you hear it right with the headphones, you would be missing some amplification. Try to reverse the actions that choose line output: Press and hold BACK. The Home menu appears. Press the arrows to select the settings icon(looks like a suitcase), and then press play/pause. Press the up/down buttons to select Audio Output and press play/pause. Now you should see "line out" selected. move the arrows to another setting - headphones if available, and press play/pause. Now unless something is really wrong with your player it should work. If it doesn't, use your warranty if valid, send for repair. Good luck
Jun 23, 2006 | Sony Network Walkman NW-A3000 MP3 Player
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
