Question about Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model
Trouble installing mower deck
I replaced the blades and have one washer and one spring clip left over. I can't locate my manual to find where it goes. Will you please down load a manual or at least the part that shows all of the connections?
  • 3 more comments
  • inspector937 Apr 29, 2010
    The tractor is a Craftsman DGS 6500. It has a 26 H.P. V Twin engine. Manufactured 11 2006.
    The mower deck has only "Precision Plus Cutting System 54" as identification.
    Model # 917. 287460
    I guess I wasn't clear. I didn't have a problem assembling the mower deck. My problem is attaching the deck to the tractor. There is one point of connection I'm missing.
    I should find the solution in the diagrams you sent. Thank you Tom
  • 4,070 Answers
You need to give your model number so I can find a manual.
Posted on Apr 28, 2010
Blade still running after lever is disenagaged on Sears Craftsman LT2000 2010 riding mower.
the moveable arm that the blade engage pulley is attached to has a hole for a spring as well as the deck (or at least an attached immoveable bracket). spring goes there to bring the blades to a stop when putting the lever in the off possition.
Jun 09, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mfirefighter173@aol.comhave a craftsman 17 hp lawn tractor and dont know were to put the spring that engages the mower blades, had to take apart to put in new mandril and cant seem to find were to put this...
There are four pulleys on the deck. Two for the blades, one idler, and one tensioning. The two smaller ones are the idler and tensioning. The tensioning is the one on the right. The post coming out the top of the pulley is where the spring goes, it slides over the top and a clip goes throught the hole at the top of it to retain the spring.
I hope this helps.
Aug 18, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
When i engaged the blades - they didn't - found clutch cable detattched - dont know where to reattach it
The blade engage cable attaches to the tensioning pulley. It is the one forward and a little left of the the right blade pulley. The spring on the end of the cable slides over the top and is retained by a clip that slides throught the hole in the top of the rod. If you can not find the clip on the mower deck then you will need to replace it (about the same size as the one holding the cable in place on the post at the back of the deck). or you will need to improvise a substitute until you can obtain a clip. May be able to find an appropriately sized clip at a hardware store. If not, let me know and I will tell you how to order one.
I hope this helps get you mowing.
Jul 27, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blade engager is disconected under the mower where the cable comes out. theres a spring at the end of the cable and i do not know where it hooks.
There are four pulleys on your deck. The two larger ones drive the blades, the two smaller ones are idler and tension. The idler is on the left, the tensioner is on the right. On top of the small one on the right, in and forward of the one that drives the right blade, this is the tension pulley. With the deck fully lowered, feel the skinny metal piece that rises out of the middle of it, at the top there is a hole. A bee clip goes in the hole. The spring on the end of the cable hooks over this rod and the clip keeps it in place. Your clip either has broken or become dislodged. Look on the mower deck for it. If you can not find it the clip is very similar in size to the one that holds the cable in place on the back of the deck. If necessary, remove this one and test fit it in the hold above the tensioner pulley and go to the hardware store for a replacement.
If youare unable to locate a replacement, let me know and I will describe for you how to order one.
Jul 25, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Found large spring at end of cable unattached lying on top of deck cover. Where does the spring attach in order to engage the blades on the riding mower? The lever is very loose and when checking, I found...
There are 4 pulleys on your deck. Two for the blades, these are the big ones on the outsides. To the insides there are two, one on left side is an idler and the one on the right is a tenioning pulley that hooks to the blade engage lever throught the cable you found. Look on top of this pulley and see if it has a piece sticking up. If so the spring at the end of the cable attaches here. Slide it over. You also need to find the clip that goes through the little hole in the end that keeps it from sliding off. Make sure that the cable is properly routed and attached near the back of the deck. If it is still attached, good, if not you will have to find that pin also.
If this is helpful, please rate.
Jul 10, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Removed mower deck with no problems. Cannot re-attach. Do you have a step by step instruction for this process?
1. Raise attatchment lift lever to its highest position
2. Slide the mower deck under the tractor with deflector shield (grass Chute) to right side of tractor
3. Lower lift lever to its lowest position
4.. Connect the front links to the mower deck and secure with the retainer springs.
5. Connect thye suspension arms to the rear deck brackets and secure with their retainer springs.
6. Connect the anti-sway bar to the chassis bracket and secure with the retainer spring.
7. Push the clutch cable housing guide into the bracket, and slide the collar onto the guide and
secure it with the large retainer spring.
8. Place the flat washer and clutch spring on the idler pulley bolt and secure them with the small
retainer spring.
9. Re-install the blade belt onto the engine pulley it goes on.
Apr 23, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mowing deck pullies, mounting and spring application.
Download the product manual from the Sears website. Murray manufactured these tractors so you can download the manual from the Murray website also. Procedure for replacing the mower deck belt is quite simple. No need to remove the deck. Spring location also on diagrams. Mower deck parts diagram breaks down the whole assembly. Easier way to remove pulleys is using an impact wrench, otherwise hold the blade while removig the nut that holds the pulley in place. Use a heavy glove to hold the blade for safety!
Sep 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cutting unevenly
Set the mower on a known flat piece of concrete. Now look at the deck and the support connections where the deck hangs from from the mower. Should be adjustments such as pins with clips or threaded bolt hangers which will allow you to raise or lower the corner of the deck which is low or high. Conversely you could have put a blade in upside down or left out a washer making one blade higher than the other. Usually an owner's manual will detail this process. As you just changed your blades, as opposed to wear and tear, likely you did not put it back together exactly as you took it apart.
Jul 06, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
